HP ZBook 14 G2 Mobile Workstation Specifications
Product image
Product features
Feature
Processor*
  • 5th Generation Intel® Core™ i7 5600U (2.6 GHz, 4 MB cache, 2 cores)*
    Up to 3.2 GHz with Intel Turbo Boost Technology
  • 5th Generation Intel® Core™ i7 5500U (2.4 GHz, 4 MB cache, 2 cores)*
    Up to 3.0 GHz with Intel Turbo Boost Technology
  • 5th Generation Intel® Core™ i5 5300U (2.3 GHz, 3 MB cache, 2 cores)*
    Up to 2.9 GHz with Intel Turbo Boost Technology
  • 5th Generation Intel® Core™ i5 5200U (2.2 GHz, 3 MB cache, 2 cores)*
    Up to 2.7 GHz with Intel Turbo Boost Technology
*Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel® architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel® 64 architecture. Processors will not operate (including 32-bit operation) without an Intel® 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
Non-applicable, processor specific
Inel Core i5 with VPRO/Core i7 with VPRO Technology Capable
Intel Core i5 with vPro and Core i7 with vPro technology is a selectable feature that is available on units configured with select processors, a qualified Intel Centrino® WLAN module and a preinstalled Windows operating system. It provides advances in remote manageability, security, energy efficient performance, and wireless connectivity. Intel Active Management Technology 9.0 (iAMT) offers built-in manageability and proactive security for networked mobile workstations, even when they are powered off* or when the operating system is inoperable. It can help identify threats before they reach the network, isolate infected systems, and update mobile workstations regardless of their power state.
*Requires a Windows operating system, network hardware and software, connection with a power source, and a direct (non-VPN) corporate network connection which is either cable or wireless LAN.
Some functionality of Intel Core i5 with vPro/Core i7 with vPro technology, such as Intel Active Management technology and Intel Virtualization technology, requires additional third- party software in order to run. Availability of future "virtual appliances" applications for Intel Core i5 with vPro/Core i7 with vPro technology is dependent on third- party software providers. Compatibility with future "virtual appliances" is yet to be determined.
Graphics
  • Intel HD 5500 Graphics*
  • AMD FirePro™ M4150 FireGL (1 GB dedicated GDDR5)
  • Microsoft DirectX 11.1 (Shader Model 5.0) and OpenGL 4.2 capable
  • AMD Enduro™ Technology supported
* Supports up to 3 independent displays via internal LCD Panel, system DisplayPort, system VGA, or using the HP UltraSlim Docking Station DisplayPort and VGA ports (sold separately).
Internal
Non-Touch
  • 14.0" diagonal LED-backlit HD SVA eDP anti-glare (1366x768)
  • 14.0" diagonal LED-backlit HD SVA eDP anti-glare (1366x768) with camera
  • 14.0" diagonal LED-backlit HD+ SVA eDP anti-glare (1600x900)
  • 14.0" diagonal LED-backlit HD+ SVA eDP anti-glare (1600x900) with camera
  • 14.0" diagonal LED-backlit FHD UWVA IPS eDP anti-glare + PSR (1920x1080)
  • 14.0" diagonal LED-backlit FHD UWVA IPS eDP anti-glare + PSR (1920x1080) with camera
Touch
  • 14.0" diagonal LED-backlit FHD UWVA IPS eDP anti-glare + PSR + touch (1920x1080)
  • 14.0" diagonal LED-backlit FHD UWVA IPS eDP anti-glare + PSR + touch (1920x1080) with camera
  • Touch panel has chemically-strengthened Corning® Gorilla® Glass 3 top cover
External
  • Up to 30-bit (2^30) per pixel "Deep Color"
    (total of 1,073,741,824 color variations)
VGA
Port supports resolutions up to 1920x1200 at 60 Hz, and lower resolutions at up to 75 Hz.
DisplayPort w/MST (Multi-stream Transport)
  • Supports resolutions up to QFHD 3840 x 2160, 24/30-bit color depth at 60 Hz, and WUXGA (1920 x 1200) monitors, with 24/30-bit color depth up to 120 Hz.
DisplayPort Features
  • Multi-stream Transport (MST): Multi-stream Transport is a DP 1.2 feature that allows daisy chaining of DP 1.2 monitors (requires monitor with DP 1.2 MST capability), or the use of DP 1.2 hubs with MST to achieve a maximum of 3 active displays.
DVI-D (single link)
  • DVI support requires a DP-to-DVI adapter (sold separately). Dual-Link DVI is supported with an active USB powered adapter (sold separately).
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage and drives
Z Turbo Drive Storage Bay
  • 320/500 GB*5400 rpm SMART SATA II HDD
*For hard drives GB = 1 billion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
Memory
Primary Storage Bay
Hard Drives
  • 1 TB 7200rpm SMART SATA III
  • 500 GB 7200 rpm SMART SATA III
  • 500 GB 7200 rpm SMART SATA III Self Encrypting Drive
  • 500 GB 5400 rpm SMART SATA III Self Encrypting Drive FIPS 140-2 compliant
Solid State Drive
  • 128/180/240/256/512 GB SATA 6 Gb/sec
  • 180/256 GB SATA 6 Gb/sec Self Encrypting Drive
HP 3D DriveGuard (Windows only)
  • The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Z Turbo Drive Storage Slot (M.2)
  • 256 GB PCIe Solid State Drive
If 256 GB Z Turbo Drive (PCIe SSD) is selected, it will be set as primary storage, and any of the HDD and SSD can be configured as secondary storage.
For hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) of system and up to 30 GB (for Windows 8) disk is reserved for system recovery software.
Networking/Communications
Local Area Network (LAN)
Integrated Intel I218-LM Gigabit Network Connection (10/100/1000)*
Wireless
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
WLAN** (Wireless LAN Options)
  • Intel Dual Band Wireless-AN 7265 802.11a/b/g/n (2x2) + Bluetooth 4.0 Combo Adapter
  • Intel Dual Band Wireless-AC 7265 802.11a/b/g/n (2x2) Wi-Fi + Bluetooth 4.0 Combo Adapter
  • Intel Dual Band Wireless-AC 3160 802.11ac (1x1) Wi-Fi + Bluetooth 4.0 Combo Adapter
WWAN *** (Mobile Broadband) options
  • HP hs3110 HSPA+ Intel® Mobile Broadband Module
  • HP lt4112 LTE/HSPA+ Gobi™ 4G Mobile Broadband Module
  • HP lt4211 LTE/EV-DO/HSPA+ Gobi™ 4G Mobile Broadband Module
Intel® Wireless Display (WiDi)****
Intel® WiDi technology enables users to stream content wirelessly from a compatible computer to a projector, TV or monitor.
*The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
**Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited.
***WWAN is an optional feature and WWAN connection requires wireless data service contract, network support, and is not available in all areas. Contact your service provider to determine the coverage area and availability. Connection speeds will vary based on location, environment, network conditions and other factors. 4G LTE not available on all products, in all regions and only available on products featuring Intel processors.
****Integrated Intel Wi-Di feature is available on select configurations only and requires separately purchased projector, TV or monitor with an integrated or external Wi-Di receiver. For more information on Intel® Wi-Di Display visit www.intel.com/go/wirelessdisplay.
Audio/Multimedia
Audio
  • DTS Studio Sound HD audio (Windows OS only)
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Combo mic-in / stereo headphone-out jack
720p HD* webcam (select models)
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280x720 resolution (720p) and up to 30fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
*HD content required to view HD images.
Keyboard/Pointing devices/Buttons and function keys
Keyboard
Optional backlit keyboard with Function key control to toggle backlit brightness setting - off/full/half brightness The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, function keys, and 19.05 x 19.05 mm key pitch (center-to-center spacing). U.S. and International key layouts are available. Other features include hot keys for instant access to power conservation and brightness.
Pointing devices
  • Touchpad with On/Off button, two-way scroll, gestures, two pick buttons
  • Point stick with two additional point stick buttons
  • Image sensor touchpad for enhanced performance and improved precision on scroll and gesture
Buttons and Function Keys
Separate launch buttons provide easy access to the following features: wireless on/off, volume mute. Function keys provide control of the following features: standby mode, external display, volume down, volume up, HP Power Assistant (Windows 7 only), and display brightness.
Power specifications
Specification
Stand-alone power requirements (AC power)
  • Nominal operating voltage:
    • 19.5 V dc @ 3.3 A
  • Average Operating Power:
    • Windows 7 (64-bit)
      AMD FirePro Graphics: 16.8 W
    • Windows 7 (32-bit)
      AMD FirePro Graphics: 16.28 W
  • Max operating power:
    • < 65 W
Display specifications
14" diagonal LED-backlit HD SVA eDP anti-glare (1366 x 768)
Specification
Outline Dimensions (W x H x D)
32.09 x 20.56 x 0.36 cm (12.6 x 8.09 x 0.14 in)
Active Area
30.94 x 17.395 cm (12.18 x 6.85 in)
320g (0.71 lb) (max)
Diagonal Size
35.6 cm (14.0 in)
Surface Treatment
Anti-glare
Contrast Ratio
300:1 (min)
Refresh Rate
60 Hz
Brightness
200 nit (typical)
Pixel Resolution
  • Format
    1366 x 768 (HD)
  • Configuration
    RGB Stripe
Interface
eDP 1.2 (1 lane)
LCD Mode
TN
PPI
125 ppi
Viewing Angle
SVA 40/40/15/30 (Left/Right/Down/Up)
14" diagonal LED-backlit HD+ SVA eDP anti-glare (1600 x 900)
Specification
Active Area
30.96 x 17.415 cm (12.19 x 6.86 in)
325 g (0.72 lb) (max)
Diagonal Size
35.6 cm (14.0 in)
Surface Treatment
Anti-glare
Contrast Ratio
300:1 (min)
Refresh Rate
60 Hz
Brightness
250 nit (typical)
Pixel Resolution
  • Format
    1600 x 900 (HD+)
  • Configuration
    RGB Stripe
Interface
eDP 1.2 (1 lane)
LCD Mode
TN
PPI
131 ppi
Viewing Angle
14" diagonal LED-backlit FHD UWVA IPS eDP anti-glare + PSR (1920 x 1080)
Specification
32.09 x 20.56 x 0.3 cm (12.6 x 8.09 x 0.12 in)
Active Area
30.93 x 17.4 cm (12.18 x 6.85 in)
340 g (0.75 lb) (max)
Diagonal Size
35.6 cm (14.0 in)
Surface Treatment
Anti-glare
Contrast Ratio
600:1 (min)
Refresh Rate
60 Hz
Brightness
300 nit (typical)
Pixel Resolution
  • Format
    1920 x 1080 (FHD)
  • Configuration
    RGB Stripe
Interface
eDP 1.3+PSR (2 lane)
LCD Mode
IPS/FFS/AHVA
PPI
157 ppi
Viewing Angle
UWVA 85/85/85/85 (Left/Right/Down/Up)
14" diagonal LED-backlit FHD UWVA IPS eDP anti-glare + PSR + touch (1920 x 1080)
Specification
Active Area
Diagonal Size
35.6 cm (14.0 in)
Touch enabled
Yes
TSP Type
Capacitive
Touch point supported
Min 5-point & Max 10-point for Windows 8
Surface Treatment
Anti-glare
Contrast Ratio
600:1 (min)
Refresh Rate
60 Hz
Brightness
300 nit (typical)
Pixel Resolution
  • Format
    1920 x 1080 (FHD)
  • Configuration
    RGB Stripe
Interface
LCD Mode
IPS/FFS/VA
PPI
157 ppi
Viewing Angle
Storage and drives
500 GB 5400 rpm SATA FIPS* Hard Drive
Specification
Drive weight
95 g (0.25 lb)
Capacity
500 GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Transfer rate (synchronous maximum):
600 MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Single Track: 1.5 ms
  • Average: 12 ms
  • Maximum: 22 ms
Cache
16 MB
Rotational speeds
5400 rpm
Logical Blocks
976,773,168
Operating Temperature
0° to 60° C (32° to 140° F) [ambient temp]
Features
ATA Security, TCG Opal SSC 2.0 and FIPS 140-2-level2
*FIPS-certified, hardware-based AES-256 encryption image.
1 TB 7200 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
1 TB
Height
9.5 mm (0.37 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Rotational speed
7200 rpm
Logical blocks
1,953,525,168
Operating temperature [case temp]
0° to 60° C (32° to 140° F) (ambient temp]
Features
ATA Security; S.M.A.R.T., NCQ, Ultra DMA
  • Single Track:: 2 ms
  • Average: 13 ms
  • Maximum: 15 ms
500 GB 7200 rpm SATA Hard Drive
Specification
Drive weight
92 - 95g (0.20 - 0.21lbs)
Capacity
500 GB
Height
7/9.7 mm (0.28/0.38 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Rotational speed
7200 rpm
Logical blocks
976,773,168
0° to 60° C (32° to 140° F) [top cover temp]
Features
  • Single Track:: 1.5 ms ~ 2 ms
  • Average: 12 ms ~ 13 ms
  • Maximum: 18 ms ~ 22 ms
500 GB 7200 rpm SMART SATA 3 Self Encrypting Drive
Specification
Drive weight
95 g (0.21 lbs)
Capacity
500 GB
Height
7/9.5 mm (0.28/0.37 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA Security; TCG OPAL v1.00
300 MB/s (Drive Capability)
  • Average: 13 ms
  • Maximum: 18 ms
Cache
32 MB
SATA 6 Gb/s 512 GB, 2.5-inch Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
512 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Logical blocks
1,000,215,216
0° to 70° C (32° to 158° F) [ambient temp]
Features
ATA Security; DIPM; TRIM; DEVSLP
Performance
  • Maximum Sequential Read:
    505 MB/s
  • Maximum Sequential Write:
    470 MB/s
SATA 6 Gb/s 256 GB, 2.5-inch SATA Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
256 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
    Up to 460 MB/s
    Up to 260 MB/s
Logical blocks
500,118,192
Features
SATA 6 Gb/s 256 GB, 2.5-inch SATA SED Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
256 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
    Up to 550 MB/s
    Up to 500 MB/s
Logical blocks
500,118,192
Features
SATA 6 Gb/s 240 GB, 2.5-inch Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
240 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
    Up to 540 MB/s
    Up to 490 MB/s
Logical blocks
468,862,128
Features
SATA 6 Gb/s 180 GB, 2.5-inch Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
180 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
    Up to 540 MB/s
    Up to 490 MB/s
Logical blocks
351,651,888
Features
SATA 6 Gb/s 128 GB, 2.5-inch Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
128 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
    Up to 550 MB/s
    Up to 350 MB/s
Logical blocks
250,069,680
0° to 70° C (32° to 158° F) [case temp]
Features
Z Turbo Drive 256 GB, M.2 PCIe Solid State Drive
Specification
Drive weight
10 g (0.02 lbs)
Capacity
256 GB
Height
61 mm (0.24 in)
Width
22.1 mm (0.87 in)
Interface
ATA-8, PCIe 2.0
Performance
    730 MB/s
    620 MB/s
Logical blocks
500,118,192
Features
*For hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) of system and up to 30 GB (for Windows 8) disk is reserved for system recovery software.
Security
HP Fingerprint Sensor
Voltage
3.0-3.6V
-10° - 75°C (14° - 167°F)
Current consumption image
36mA
Low latency wait for finger
950 uA
Capture rate
3000 lines/sec
ESD Resistance
IEC 6100-4-2 4B (+/-15KV)
Detection Matrix
200*1 (plus another secondary line); 508 dpi, sensor area 12*3 mm
Audio/multimedia - DTS Sound+
Specification
Implementation
IDT 92HD91
Function Key Volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/Line out
Stereo
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Specification
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling rate(s)
8 kHz - 48kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Integrated Stereo Speakers
Specification
Power rating
2 W
Impedance
4 Ohms
Power
HP 65W Smart AC Adapter
Dimensions
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
280 g (0.62 lb)
Input
100 to 240 VAC
  • Input Efficiency: 87% min at 115/230 VAC
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.7 A at 90 VAC, 0.85 A at 180 VAC
Output power
  • Output power: 65 W
  • DC output: 18.5 V
  • Hold-up time: 5 msec at 115 VAC input
  • Output current limit: <11A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental Design
  • Temperature
    • Operating: 0° to 40° C (32° to 104° F)
    • Non-operating (storage): -20° to 65° C (-4° to 149° F)
  • Altitude: 0 to 3,048 m (0 to 10,000 ft)
  • Humidity: 20% to 80%
  • Storage Humidity: 10% to 90%
EMI and safety certifications
CE Mark- full compliance with LVD and EMC directives; Worldwide safety standards- IEC950, EN60950, UL1950, Class 1, SELV; Agency approvals- C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCIB, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
3-cell HP Long Life (50WHr) Lithium-Ion Polymer
Dimensions (H x W x L)
19.89x10.28x0.84 cm (7.8 x 4.01 x 0.3 in)
280 g
Cells/Type
3-cell Lithium-Ion Polymer
Energy
  • Voltage: 11.1
  • Amp-hour capacity: 4.504Ah
  • Watt-hour capacity: 50Wh
Temperature
  • Operating (charging): 0° to 45° C (32° to 113° F)
  • Operating (discharging): -10° to 60° C (14° to 140° F)
  • Non-operating: -20° to 60° C (-4° to 140° F)
Battery Re-Charge Time
  • System in OFF or Standby Mode: 3 hours
Fuel Gauge LED
No
1 year or 3 years*
*Battery warranty depends on the platform warranty.
Optional Travel Battery Available
No
6-cell HP Long Life (60WHr) Lithium-Ion Polymer
32 x 21.85 x 1.51 cm (12.59 x 8.6 x0.59 in)
603 g
Cells/Type
Energy
  • Voltage: 11.1
  • Amp-hour capacity: 5.4 Ah
  • Watt-hour capacity: 60 Wh
Temperature
  • Operating (Charging): 0° to 45° C (32° to 113° F)
  • Operating (Discharging): -10° to 50° C (14° to 140° F)
Fuel Gauge LED
Yes
1 year or 3 years*
Yes
Wireless
  • HP hs3110 HSPA+ Intel Mobile Broadband Module
  • HP lt4112 LTE/HSPA+ Gobi 4G Mobile Broadband Module
  • HP lt4211 LTE/EV-DO/HSPA+ Gobi 4G Mobile Broadband Module
Intel Wireless Display (WiDi)****
Intel WiDi technology enables users to stream content wirelessly from a compatible computer to a projector, TV or monitor.
****Integrated Intel Wi-Di feature is available on select configurations only and requires separately purchased projector, TV or monitor with an integrated or external Wi-Di receiver. For more information on Intel Wi-Di Display visit www.intel.com/go/wirelessdisplay.
Physical specifications
Specification
Dimensions (H x W x D)
21 x 339 x 237 mm (0.83 x 13.35 x 9.33 in)
  • Weight – w/Touch
    Starting at 1.71 kg (4.21 lb)
    With 3cell 50Whr battery, without hard drive and with 256 GB Z Turbo Drive (PCIe SSD) and FHD touch panel
  • Weight – Non Touch
    Starting at 1.71 kg (3.77 lb)
    With 3cell 50Whr battery, without hard drive and with 256 GB Z Turbo Drive (PCIe SSD) and FHD non-touch panel
Weight varies by configuration and components.
Software/OS
Preinstalled Software with Windows Operating System
Feature
BIOS
Windows 7
  • HP BIOSphere1
  • HP Sure Start2
  • HP BIOS Protection3
  • HP Disk Sanitizer External Edition4
  • BIOS Update via Network
  • Master Boot Record Security
  • Power On Authentication
  • Pre-Boot Security
  • Secure Erase6
  • Absolute Persistence Module7
Windows 8.1
  • HP BIOSphere1
  • HP Sure Start2
  • Pre-Boot Security
  • Secure Erase6
  • Hybrid Boot
  • Measured Boot
  • Secure Boot
MultiMedia
Windows 7
  • CyberLink Power DVD, BD
  • CyberLink YouCam BE
Windows 8.1
Communication
Windows 7
  • HP GPS and Location8
  • HP Connection Manager9
  • Intel® Wireless Display (WiDi) Software for Windows11
Windows 8.1
  • HP Mobile Connect
  • HP Wireless Hotspot10
  • HP Roaming Alert
  • Native Miracast Support12
HP Value Add
Windows 7
  • HP 3D DriveGuard
  • HP ePrint Driver13
  • HP Hotkey
  • HP PageLift14
  • HP Support Assistant
  • HP Recovery Manager
  • HP Recovery Disk Creator
Windows 8.1
  • HP 3D DriveGuard
  • HP Hotkey
  • HP PageLift14
  • HP Registration App
3rd Party
Windows 7
  • Foxit PhantomPDF Express for HP
Windows 8.1
Microsoft Products
Windows 7
  • Buy Office
  • Bing Search
Windows 8.1
  • Buy Office
  • Bing Search
Manageability
Windows 7
  • HP Driver Packs15
  • HP SoftPaq Download Manager (SDM)
  • HP System Software Manager (SSM)15
  • HP BIOS Config Utility (BCU)15
  • HP Client Catalog15
  • HP CIK for Microsoft SCCM15
  • LANDESK Management15
Windows 8.1
  • HP Driver Packs15
For more information on HP Client Management Solutions refer to: http://www.hp.com/go/clientmanagement.
Client Security
Windows 7
  • HP Device Access Manager
Windows 8.1
Windows 7
  • HP Drive Encryption17
  • HP File Sanitizer18
  • HP Security Manager
  • HP SpareKey
  • Microsoft Security Essentials19
Windows 8.1
  • HP SpareKey
  • Microsoft Defender
Standard
Windows 7
  • TPM 1.2
  • Integrated Smart Card Reader
  • Pre-boot Authentication
Windows 8.1
  • TPM 1.2
The Absolute Persistence agent is shipped turned off, and must be activated by customers when they purchase a subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S.
For more information on HP Client Security Software Suite, refer to http://www.hp.com/go/clientsecurity.
1 Available only on business PCs with HP BIOS.
2 HP Sure Start is the first and only self-healing technology solution created to protect against malware and virus attacks aimed at the BIOS.
3 May require a manual recovery step if all copies of BIOS are compromised or deleted.
4 For the use cases outlined in the DOD 5220.22-M Supplement. Only supports traditional Hard Drives.
5 Requires initial user set up.
6 For the methods outlined in the National Institute of Standards and Technology Special Publication 800-88.
7 Absolute agent is shipped turned off, and will be activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
8 GPS access requires an unobstructed path to multiple satellites. Performance may be affected if/when used inside of buildings, bridges or heavily congested metropolitan areas. Requires separately purchased GPS navigation software available from multiple GPS applications.
9 HP Mobile Connect is only available on preconfigured devices with WWAN.
10 The wireless hotspot application requires an active internet connection that is shared with the connecting devices. Wireless hotspot data usage may incur additional charges. Check with your service provider for plan details.
11 Integrated Intel® Wi-Di Display is available on select configurations only and requires a separate projector, TV or monitor with an integrated or external Wi-Di receiver. For more information on Intel® Wi-Di Display visit www.intel.com/go/wirelessdisplay.
12 Miracast is a wireless technology your PC can use to project your screen to TVs, projectors, and streaming media players that also support Miracast. You can use Miracast to share what you’re doing on your PC and present a slide show.
13 Requires an Internet connection to HP web-enabled printer and HP ePrint account registration.
14 Requires Windows 7 or higher.
15 Subscription required.
16 Requires Windows. Data is protected prior to Drive Encryption login. Turning the PC off or into hibernate logs out of Drive Encryption and prevents data access.
17 For the use cases outlined in the DOD 5220.22-M Supplement. Supports standard Hard Drives. Initial setup required.
18 Opt in and internet connection required for updates.
Environmental specifications
Specification
Temperature
Operating:
  • Not writing optical
    0° to 35° C (32° to 95° F)
  • Writing optical
    5° to 35° C (41° to 95° F)
Non-operating:
  • -20° to 60° C (-4° to 140° F)
Relative humidity
  • Operating:
    10% to 90%, non-condensing
  • Non-operating:
    5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
  • Operating:
    40 G, 2 ms, half-sine
  • Non-operating:
    200 G, 2 ms, half-sine
Random vibration
  • Operating:
    0.75 grms
  • Non-operating:
    1.50 grms
Altitude (unpressurized)
  • Operating:
    -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating:
    -15.24 to 12,192 m (-50 to 40,000 ft)
Planned Industry Standard Certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: Select models*
  • EPEAT: Gold target**
  • ICES: Yes
  • Australia / NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KCC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
*Configurations of the HP ZBook 14 that are ENERGY STAR qualified are identified as HP ZBook 14 ENERGY STAR on HP websites and on ENERGY STAR website.
**EPEAT registration varies by country. EPEAT status listed above applies to U.S.
For accessibility information on HP products, please visit: http://www.hp.com/accessibility.
