HP ProDesk 400 G2 Small Form Factor Business PC Product Specifications
Product description
The HP ProDesk 400 G2 Series offers expandable desktop PC options that meet your everyday business needs with enough room to grow.
Product features
Feature
Intel® 8 Series (H81 Express) Chipset
Graphics
Intel HD Graphics on all models (integrated on processor)
  • AMD Radeon HD 8350 (1GB) PCIe x16
  • AMD Radeon HD 8490 DP (1GB) PCIe x16
  • NVIDIA NVS 310 x 16 1st (no cbl)
  • NVIDIA NVS 315 1GB PCIe x1
HD content required to view HD images.
Discrete graphics options cannot be configured with 180W power supply and Quad-Core Processor.
Adapters and cables
  • HP DMS-59 to Dual DisplayPort Cable
  • HP DMS-59 to Dual DVI Cable
  • HP DMS-59 to Dual VGA Cable
  • HP DisplayPort to DisplayPort Cable
  • HP DisplayPort to DVI-D Adapter
  • HP DisplayPort to HDMI Adapter
  • HP DisplayPort to VGA Adapter
  • HP Serial Port Adapter
  • HP Parallel Port Adapter
  • HP DisplayPort Cable
Storage
SATA Drives:
  • 2 TB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5”
  • 2 TB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5” - 2nd hard drive
  • 1 TB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5”
  • 1 TB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5” - 2nd hard drive
  • 500 GB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5”
  • 500 GB, 7200 RPM, SATA 6.0 Gb/s, SMART IV, 3.5” - 2nd hard drive
  • 500GB, 7200 RPM SATA SED, 2.5” (with 3.5” adapter when installed in MT)
  • 500GB, 7200 RPM SATA SED, 2.5” (with 3.5” adapter when installed in MT) - 2nd hard drive
Hybrid Drives:
  • 1 TB SATA 6G 2.5” (8 GB cache) SSHD Drive (with 3.5” adapter when installed in MT)
  • 1 TB SATA 6G 2.5” (8 GB cache) SSHD Drive (with 3.5” adapter when installed in MT) - 2nd hard drive
  • 500 GB SATA 6G 2.5” (8GB cache) SSHD Drive (with 3.5” adapter when installed in MT)
  • 500 GB SATA 6G 2.5” (8GB cache) SSHD Drive (with 3.5” adapter when installed in MT) - 2nd hard drive
  • 500 GB SATA 6G 2.5” (8GB cache) SSHD Drive w/caddy
  • 500 GB SATA 6G 2.5” (8GB cache) SSHD Drive w/caddy- 2nd hard drive
Solid State Drives:
  • 128 GB SATA 6G 2.5” SSD (with 3.5” adapter when installed in MT)
  • 128 GB SATA 6G 2.5” SSD (with 3.5” adapter when installed in MT) - 2nd hard drive
Self-Encrypting Drive:
  • 500GB 7200 RPM SATA 2.5 SED HDD
Self-Encrypting Solid State Drives
  • 500GB 2.5” FIPS 140-2 Self-Encrypting (SED) Solid State Drive - 2nd hard drive
  • 256GB SATA 2.5” Opal2 Self-Encrypting (SED) Solid State Drive SSD
  • 256GB SATA 2.5” Opal2 Self-Encrypting (SED) Solid State Drive - 2nd hard drive
  • 256 GB SATA 2.5” Self-Encrypting (SED) Solid State Drive (with 3.5” adapter when installed in MT)
  • 256 GB SATA 2.5” Self-Encrypting (SED) Solid State Drive (with 3.5” adapter when installed in MT) - 2nd hard drive
  • 128GB SATA 2.5” Opal2 Self-Encrypting (SED) Solid State Drive
  • 128GB SATA 2.5” Opal2 Self-Encrypting (SED) Solid State Drive- 2nd hard drive
  • 120GB SATA 2.5” Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500)
  • 120GB SATA 2.5” Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) - 2nd hard drive
  • 120GB SATA 2.5” Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) w/ caddy
  • 120GB SATA 2.5” Opal1 Self-Encrypting (SED) Solid State Drive (Pro 1500) w/ caddy - 2nd hard drive
Frame/Carrier
  • HP Slim Removable SATA HDD Frame/Carrier
Optical Disc Drives
  • Slim DVD-ROM
  • Slim BDXL Blu-ray Writer
  • Slim SuperMulti
Media Card Reader**
  • Media Card Reader
*For hard drives and solid state drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) and 30 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
**Card sold separately
Memory
Form factor: Small Form Factor
Type: DDR3 non-ECC up to 1600 MT/s
Maximum: 16GB
Number of Slots: 2 DIMM
For systems configured with more than 3 GB of memory and a 32-bit operating system, all memory may not be available due to system resource requirements. Addressing memory above 4 GB requires a 64-bit operating system. Memory modules support data transfer rates up to 1600 MT/s; actual data rate is determined by the system's configured processor. See processor specifications for supported memory data rate.
Networking/Communications
Ethernet (RJ-45):
  • Realtek RTL8151GH-CG GbE LOM (standard)
  • Intel Ethernet I210-T1 PCIe x1 Gb Network Interface Card (optional)
Wireless*:
  • Intel® Dual Band Wireless-N 7260 802.11 a/b/g/n PCI Express (optional)
  • HP WLAN 802.11 a/b/g/n 2x2 Dual Band PCIe x1 WLAN/Bluetooth Card (optional)
  • Intel 7260 802.11 a/b/g/n PCIe x1 WLAN Card (optional)
* Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
Audio/Multimedia
  • HD audio with Realtek ALC221 codec (all ports are stereo)
  • DTS Studio+ sound audio management technology
  • Microphone and headphone front ports (3.5 mm)
  • Line-out and Line-In rear Ports (3.5 mm)
  • Multi-streaming capable
  • Internal speaker (standard)
Keyboards and pointing devices
Keyboard:
  • HP PS/2 keyboard
  • HP USB keyboard
  • USB Smart card (CCID) keyboard
  • HP USB and PS/2 Washable Keyboard
  • HP Wireless Keyboard and mouse combo*
Mice:
  • HP PS/2 mouse
  • HP USB mouse
  • HP USB 1000dpi laser mouse
  • HP USB and PS/2 washable mouse
* Keyboard contains 25% post-consumer recycled plastic material
Power supply
Specification
Standard efficiency
240W active PFC
High efficiency*
  • 240W active PFC
  • 82/85/82%efficient at 20/50/100% load (115V)
  • 82/85/82% efficient at 20/50/100% load (230V)
Rated voltage range
100 - 240 VAC
Rated line frequency
50/60 Hz
Operating line frequency range
47 - 63 Hz
Rated input current
4A/200 VAC, 8A/100 VAC
Rated input current with energy efficient* power supply
4A
Current leakage (NFPA 99)
< 275 µA @ 120V
Graphics specifications
AMD Radeon HD 8470 graphics card
Specification
Form factor
Full height
Graphics controller
AMD Radeon HD 8470
Core clock
775 MHz
Memory clock
900 MHz
Memory
2GB, DDR3, 64-bit wide
Bus type
PCIe Gen2
Maximum power
< 30 W
Power source support
12 V and 3.3 V
3D API support
DX11
HDCP support
Yes
Display maximum resolution
  • Digital 2560 x 1600
  • Analog 2048 x 1536
Supported graphics APIs
DX11, OpenGL, full 1080p BD (H264) playback in hardware, HDMI 1.4 support
Supported Display Resolutions and Refresh Rates
Other resolutions may be available but are not recommended as they may not have been tested and qualified by HP.
Resolution
Refresh Rates
800 x 600
60 Hz
1024 x 768
60 Hz
1280 x 720
60 Hz
1280 x 768
60 Hz
1280 x 1024
60 Hz
1360 x 768
60 Hz
1440 x 900
60 Hz
1600 x 900
60 Hz
1680 x 1050
60 Hz
1920 x 1080
60 Hz
NVIDIA NVS 310 graphics card
Specification
The NVIDIA® NVS™ 310 Graphics Card is a PCI Express low profile form factor graphics add-in card targeted as an active low cost graphics solution for the corporate business and enterprise markets.
The NVIDIA® NVS™ 310 graphics card is an ideal solution for customers requiring a small form factor graphics add-in card for either standard or small form factor PC designs.
Performance and Features
The NVIDIA® NVS 310 Graphics Card offers 512 MB of ultrafast DDR3 memory and is capable of supporting up to 2 displays.
DisplayPort connector supports multimode technology to support connection to DVI-D, VGA and HDMI monitors with optional adapters in kits NR078AA, FH973AT, BP937AA, AS615AA.
For a DisplayPort to DisplayPort connections use the optional DisplayPort Cable Kit VN567AA.
Form factor
Low Profile: 2.713 × 6.15 in
Graphics controller
NVIDIA NVS 310
Memory clock
875 MHz
Memory size
512MB DDR3
Memory bandwidth
14GB/s
Maximum power
19.5 W
Up to 2560 x 1600 (digital display) per display
Display output
Up to 2 displays in the following configurations
  • Displayport output:
    • Drives two DisplayPort enabled digital display at resolutions up to 2560 × 1600 at 60 Hz with reduced blanking, when connected natively using the 2 DisplayPort connectors on the NVS 310 graphics card.
    • Supports 2 monitors up to resolution of 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort Multi-Stream topology technology.
  • DVI-D output:
    • Drives two digital display at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort to DVI-D single-link cable adaptors.
    • Drives two digital display at resolutions up to 2560× 1600 at 60 Hz with reduced blanking using DisplayPort to DVI-D dual-link cable adaptors.
  • HDMI output:
    • NVS 310 is capable of driving two high definition (HD) panels up to resolutions of 1920 × 1080P at 60 Hz using DisplayPort to HDMI cable adaptors.
  • VGA display output:
    • Drives two analog display at resolutions up to 1920 × 1200 at 60 Hz using DisplayPort to VGA cable adaptors.
Resolution
Maximum Refresh Rates (Hz) by Connection
DisplayPort to VGA
DisplayPort to HDMI
DisplayPort
640 x 480
85
60
60
60
800 x 600
85
60
60
60
1024 x 768
85
60
60
60
1280 x 720
85
60
60
60
1280 x 1024
85
60
60
60
1440 x 900
75
60
60
60
1600 x 1200
60
60
60
60
1680 x 1050
60
60
60
60
1920 x 1080
60-R
60-R
60
60
1920 x 1200
60-R
60-R
60
1920 x 1440
60
2048 x 1536
60
2560 x 1600
60
NVIDIA NVS 315 1GB PCIe x 16 Graphics card
Specification
Get efficient dual-display graphics performance in a PCI Express low-profile graphics card with the NVIDIA NVS 315 PCIe x16 1 GB Graphics Card, an ideal desktop graphics solution for professional business and commercial applications.
The NVIDIA® NVS 315 Graphics Card offers 1 GB of ultrafast DDR3 memory and is capable of supporting up to 2 displays.
Form factor
Graphics controller
NVIDIA NVS 315
Memory clock
875 MHz
Memory size
512MB DDR3
Memory bandwidth
14GB/s
Connectors
DMS-59 , with support for dual VGA, dual DVI or dual Display Port with the appropriate adapter cable
Up to 2048 x 1536 VGA; 1920 x 1200 DVI; 2560 x 1600 DisplayPort
Display output
  • Dual DVI : Drives two DVI displays using optional HP DMS59 DVI Dual-head Connector Cable DL139A
  • Dual DisplayPort : Drives two DisplayPort using optional HP DMS-59 to Dual DisplayPort kit XP688AA
  • Dual VGA : Drives two analog using the included HP DMS-59 to Dual VGA Cable
other resolutions may be available but are not recommended as they may not have been tested and qualified by HP
Resolution
Analog Connection
Digital Connection
640 x 480
85
60
720 x 480
85
60
720 x 576
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 768
85
60
1280 x 1024
85
60
1440 x 900
75
60
1600 x 1024
85
60
1600 x 1200
85
60
1680 x 1050
75
60
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
N/A
2048 x 1536
75
N/A
2560 x 1440
N/A
60*
2560 x 1600
N/A
60*
* Display Port Only
NVIDIA GeForce GT630 graphics card
Specification
The NVIDIA GeForce GT630 DP (2GB) PCIe x16 Card Graphics Card provides a full height, PCI Express x16 graphics add-in card solution based on the NVIDIA Kepler Architecture GPU. The card is designed to support three display connections through its DVII, and two DisplayPort connectors.
An ideal solution for desktop PC customers seeking enhanced 2D and advanced 3D graphics performance, the NVIDIA GeForce GT630 DP (2GB) PCIe x16 Cards are an excellent choice for business users who want run multiple displays from a single graphics board. Engage in Web conferencing or video or photo editing, while improving your everyday business PC experience with better graphics and excellent visual display quality.
The NVIDIA GeForce GT630 DP (2GB) PCIe x16 Cards deliver superior PCI Express (PCIe) Gen 3 features including:
  • Unprecedented flexibility for new applications and enhanced performance
  • Support for NVIDIA surround technology
  • Run multiple displays from a single graphics card
  • Full 16 lane PCIe Generation 3 bus support with peak bandwidth support
  • Wireless Display ready for future support
Form factor
PCIe x16 Card
Graphics controller
NVIDIA Kepler architecture GPU
Core clock
875 MHz
Memory clock
891 MHz
Memory size
2 GB DDR3 128 bit
Memory bandwidth
28.5 GB/s
2560 x 1600 digital, 2048 x 1536 analog
Display support
Integrated 400 MHz RAMDAC
Resolution
Analog Connection
Digital Connection
640 x 480
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 1024
85
60
1440 x 900
75
60
1600 x 1200
85
60
1680 x 1050
75
60
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
60
2048 x 1536
75
60
2560 x 1600
N/A
60
AMD Radeon HD 8350 1GB PCie x16 DH graphics card
Specification
Get stable 2D and advanced 3D graphics performance from the AMD Radeon HD 8350 1 GB PCIe x16 DH Graphics Card, a low profile, PCI Express x16 graphics add-in card based on the AMD Radeon HD 8350 GPU, great for Web conferencing or video and photo editing.
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8350
Core clock
GPU engine operates at 523 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
875 MHz
HDCP support
Yes
  • Digital: 1920 x 1200
  • Analog: 2048 x 1536
Analog Connection
Digital Connection
640 x 480
85
60
720 x 480
85
60
720 x 576
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 768
85
60
1280 x 1024
85
60
1440 x 900
75
75
1600 x 1024
85
60
1600 x 1200
85
60
1680 x 1050
75
75-R
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
N/A
2048 x 1536
75
N/A
2560 x 1440
N/A
N/A
2560 x 1600
N/A
N/A
AMD Radeon HD 8490 1GB PCie x16 graphics card
Specification
Get impressive graphics and high resolution dual-display performance in a low profile, PCI Express x16 graphics add-in card based on the AMD Radeon HD 8490 Graphics Processor. Improve your everyday PC, Web conferencing, and video or photo editing.
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8490
Core clock
GPU engine operates at 875 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
900 MHz
HDCP support
Yes
  • Digital: 2560 x 1600
Analog Connection
Digital Connection
300 x 200
85
60
320 x 240
85
60
400 x 300
85
60
640 x 480
85
60
720 x 480
85
60
720 x 576
85
60
800 x 600
85
60
1024 x 768
85
60
1280 x 720
85
60
1280 x 768
85
60
1280 x 1024
85
60
1440 x 900
75
75
1600 x 900
85
60
1600 x 1024
85
60
1600 x 1200
85
60
1680 x 1050
75
75-R
1920 x 1080
85
60-R
1920 x 1200
85
60-R
1920 x 1440
85
N/A
2048 x 1536
75
N/A
2560 x 1440
N/A
60
2560 x 1600
N/A
60
AMD Radeon R7 240 2GB FH PCIe x16 GFX Graphics Card
Specification
Form factor
Full Height
Graphics controller
AMD Radeon R7 240
Core clock
730MHz
Memory
2GB, DDR3
Memory clock
1800MHz
Frame Buffer
128-bit wide frame buffer
Bus Type
PCI Express 3.0 interface
Max. Power
32.71 W
Power Source Support
12V and 3.3V
HDCP support
Yes, All digital outputs support HDCP (High-Bandwidth Digital Content Protection)
  • Digital 1920 x 1200
  • Analog 2048 x1536
Compliance
Compliant with all listed and with all applicable ACPI, AGP Forum, ANSI, DDWG, HP, Intel, ITU, Microsoft, PCI SIG, SMPTE, and VESA APIs, standards, requirements, implementation guides, and ECRs.
SUPPORTED DVI-D (DIGITAL) AND DISPLAYPORT DISPLAY MODES
Resolution
Refresh Rates
640 x 480
60 Hz
720 x 480
60 Hz
720 x 576
60 Hz
800 x 600
60 Hz
1024 x 768
60 Hz
1280 x 720
60 Hz
1280 x 768
60 Hz
1280 x 1024
60 Hz
1440 x 900
60 Hz
75 Hz
1600 x 1024
60 Hz
1600 x 1200
60 Hz
1680 x 1050
75 Hz
1920 x 1080
60 Hz
AMD Radeon R9 255 2GB PCIe x16 GFX
Specification
Form factor
PCie x16
Graphics controller
AMD Radeon R9 255
Core clock
900 MHz
Memory
2GB, (4 pcs of 4Gb 128Mx32 GDDR5)
Memory clock
1150MHz
Frame Buffer
Bus Type
Max. Power
N/A
12V and 3.3V
HDCP support
Compliance
Supports Microsoft DirectX 11.1, OpenGL 4.3 and OpenCL 1.2 APIs.
Resolution
Refresh Rates
320 x 200
60 Hz
320 x 240
60 Hz
400 x 300
60 Hz
480 x 360
60 Hz
512 x 384
60 Hz
640 x 350
60 Hz
640 x 400
60 Hz
640 x 480
60 Hz
720 x 480
60 Hz
720 x 576
60 Hz
800 x 600
60 Hz
1024 x 768
60 Hz
1152 x 864
60 Hz
1280 x 720
60 Hz
1280 x 768
60 Hz
1280 x 960
60 Hz
1280 x 1024
60 Hz
1440 x 900
60 Hz
75 Hz
1600 x 900
60 Hz
1600 x 1024
60 Hz
1600 x 1200
60 Hz
1680 x 1050
75 Hz
1680 x 1080
60 Hz
1920 x 1080
60 Hz
2560 x 1440
60 Hz
2560 x 1600
60 Hz
Memory specifications
Specification
System memory support
The HP ProDesk 400 G2 Business PC supports the 4th generation Intel® Core™ processor family. Based on a new PC micro-architecture, the processor is designed for a two-chip platform consisting of a processor and Platform Controller Hub (PCH). Unlike previous generations, the 4th generation Intel® Core™ processor includes an Integrated Memory Controller (IMC). The IMC supports DDR3/DDR3L protocols with two independent, 64-bit wide channels each accessing one or two DIMMs.
  • Two channels of non-ECC DDR3/DDR3L unbuffered dual in-line memory modules (UDIMM) or DDR3/DDR3L unbuffered small outline dual in-line memory modules (SO-DIMM) with a maximum of two DIMMs per channel
  • Single-channel and dual-channel memory organization modes
  • Data burst length of eight for all memory organization modes
  • Memory data transfer rates of up to 1600 MT/s; actual supported data transfer rate determined by the configured processor.
  • 64-bit wide channels
  • DDR3/DDR3L system memory I/O voltage of 1.5V
  • Theoretical maximum memory bandwidth of:
    • 21.3 GB/s in dual-channel mode assuming 1333 MT/s
    • 25.6 GB/s in dual-channel mode assuming 1600 MT/s
Platform memory support
Microtower (MT) platforms support up to two (2) industry-standard DDR3-SDRAM DIMMs.
You must shut down the computer and disconnect the power cord before adding or removing memory modules. Regardless of the power-on state, voltage is always supplied to the memory modules as long as the computer is plugged in to an active AC outlet. Adding or removing memory modules while voltage is present may cause irreparable damage to the memory modules or system board.
High definition audio specifications
Specification
Type
Integrated
HD stereo codec
Realtek 2-channel ALC221 codec
Audio I/O ports
  • Front microphone-In (150-K ohm Input Impedance)
  • Rear Line-In/Microphone input (150-K ohm Input Impedance, function is configurable by audio driver)
  • Rear Line-Out* (190 ohms Output Impedance, expects at least a 10-K ohm load)
  • Front Headphone-Out (0.5 Ohm Output Impedance, expects at least a 32 ohm load)
  • Front Microphone/Headphone jack is re-task able to provide Microphone input, line-in or Headphone output to support connecting two headphones to the front of the system. When configured as a second front headphone output, both front headphone outputs are always driven with the same signal.
  • All ports are 3.5mm
Internal speaker amplifier
1.5W amplifier for the internal speaker only. External speakers must be powered externally. Rear Line-in audio port is re-taskable as either Line-in or Microphone-In.
Multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes – Uses OS soft wavetable
Analog audio
Yes
Number of channels on line-Out
Stereo (Left & Right channels)
Internal speaker
Yes
External speaker jack
Yes
Hard disk and solid state storage specifications
2TB 7.2K rpm SATA 6.0Gb/s 3.5” Hard Disk Drive
Specification
Unformatted Capacity
2 TB
Rotational speed
7,200 rpm
Interface
SATA 6 Gb/s
Cache, Multisegmented (MB)
64 MB
Seek time (typical reads)
Read:
< 8.5 ms
Write:
< 9.5 ms
Height (nominal)
26.11 mm (1.028 in)
Width (nominal)
101.6 mm (4.0 in)
Depth
146.99 mm (5.787 in)
626 g (1.38 lb)
Operating temperature
5° to 55°C (41° to 131° F)
1TB 7.2K rpm SATA 6.0Gb/s 3.5” Hard Disk Drive
Specification
Capacity
1,000,204,886,016 bytes
Rotational Speed
7,200 rpm
Interface
Serial ATA 3.0 (6.0 Gb/s)
Buffer Size
32 MB
Logical Blocks
1,953,525,168
Seek time (typical reads, includes controller overhead, including settling)
Single track:
2.0 ms
Average:
11 ms
Full-Stroke:
21 ms
Height (nominal)
2.54 cm (1 in)
Width (nominal)
Media diameter:
8.89 cm (3.5 in)
Physical size:
10.2 cm (4 in)
5° to 55° C (41° to 131° F)
500GB 7.2K rpm SATA 6.0Gb/s 3.5” Hard Disk Drive
Specification
Capacity
500,107,862,016 bytes
Rotational speed
7,200 rpm
Interface
Buffer size
16MB
Logical blocks
976,773,168
Average:
11 ms
Full-Stroke:
21 ms
Height (nominal)
2.54 cm (1 in)
Width (nominal)
Media diameter:
8.89 cm (3.5 in)
Physical size:
10.2 cm (4 in)
500GB 7200 RPM SATA 2.5” Self-Encrypting (SED) Hard Disk Drive
Specification
Capacity
Rotational Speed
7,200 rpm
Drive Type
Self-Encrypting Drive (SED) with SATA interface
Interface
SATA 6 Gb/s
Segmented Buffer with write cache
32768 KB - A portion of buffer capacity used for firmware
Number of Sectors
976,773,168
Seek Time (typical reads)
Single Track:
1.0 ms
Sustained sequential write:
13 ms
Full-Stroke:
25 ms
Media Diameter
63.5 mm (2.5 in)
Height
6.8 mm, ±0.2mm (0.267 in)
Width
69.85 mm, ±0.25mm (2.75 in)
Length
100.2 mm, ±0.25mm (3.945 in)
3.35 oz/95 g (max)
Operating Temperature
1TB SATA 6G 2.5” 8GB Solid State Hybrid Drive (SSHD)
Specification
Formatted capacity
1 TB
Spindle Speed
5,400 rpm +/- 0.2%
Drive Type
Solid State Hybrid Drive (SSHD) technology with NAND Flash
Interface
Serial ATA (SATA)
Cache Buffer
64 MB
NAND Flash Commercial Multilevel Cell (cMLC)
8 GB
Number of Sectors
976,773,168
Single Track:
2.0 ms
Average:
12 ms
Height
9.5 +/- 0.2 mm (0.374 +/-.008 in)
Width
69.85 +/- 0.25 mm (2.750 +/- 0.010 in)
Length
100.35 +0.20 / -0.25 mm (3.951 +0.008 / -0.010 in)
115 g (0.254 lb) (max)
0° to 60° C (32° to 140° F)
500 GB SATA 6G 2.5” 8GB Solid State Hybrid Drive (SSHD)
Specification
Formatted capacity
500GB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Interface
Serial ATA (SATA)
Cache buffer
64MB
8GB
Number of sectors
976,773,168
Single track:
2.0 ms
Average:
12 ms
Height
6.8 +/- 0.2 mm (0.268 +/-.008 in)
Width
Length
95 g (0.209 lb) (max)
5° to 55° C (41° to 131° F )
128 GB Solid State Drive
Specification
128 GB*
Architecture
Multi Level Cell (MLC) NAND
Interface
SATA 6 GB/sec
Dimensions (W x H x D)
6.985 x 0.7 x 10.05 cm (2.75 x 0.276 x 3.96 in)
73 g (0.16 lb)
Bandwidth Performance
Sustained Sequential Read:
Up to 450 MB/ss
Sustained Sequential Write:
Up to 260 MB/s
Random Read (4KB):
Up to 46K IOPs
Random Write (4KB):
Up to 56K IOPs
Latency
Read:
55ms (TYP)
Write:
55ms (TYP)
Power
DC power requirement:
Min 4.5 V; Max 5.5 V
Total power consumption:
160 mW (Active) ; < 85 mW; (Idle)
Useful Drive Life
1.2 million device hours**
Environmental
(all conditions, non-condensing)
Operating Temperature:
0° to 70° C (32° to 158° F)
Relative Humidity (operating):
5% to 95%
Shock:
1,500 G/1.0 msec
Regulations
UL, CSA, EN 60950-2000, CISPR Pub 22 Class B, CNS 13438, AS/NZS
CISPR 22:2002 Class B, Korea KCC, CE Mark
* For solid state disk drives, GB means 1 billion bytes. 128GB is the unformatted capacity of this drive before a portion of the drive is reserved for flash management features. Actual capacity will vary by content.
** The product achieves a mean time between failure (MTBF) based on population statistics not relevant to individual units.
500GB 2.5” FIPS 140-2 SED Solid State Drive
Specification
Formatted capacity
500 GB
Architecture
Self-Encrypting (SED) Solid State Drive with SATA interface.
Interface
Serial ATA (6.0 Gb/s)
Form Factor
2.5 inch
Height
6.80 mm ± 0.20
Width
69.85 mm ± 0.25
Length
100.35 mm ± 0.25/0.20
< 95 g (0.209 lb)
Sustained data transfer rate OD
100 MB/s max
I/O data-transfer rate
600 MB/s max
Power
Power consumption:
Spinup (max): 1.00A
Idle, active: 0.70W
Sleep 0.18W
Environmental
Relative Humidity:
5% to 95%
Shock:
Maximum 400 G/2 ms
256GB SATA 2.5” Opal2 SED Solid State Drive
Specification
256 GB
500,118,192 (User Addressable Sectors)
Architecture
Self-Encrypting (SED) Solid State Drive with NAND Flash and SATA interface.
Trusted Computing Group(TCG) OPAL compliant encrypted solid state drive
Interface
Form Factor
2.5 inch
Height
6.80 mm ± 0.20
Width
69.85 mm ± 0.25
Length
100.20 mm ± 0.25
Up to 55 g
Up to 520 MB/s
Up to 500 MB/s
Power
Power consumption:
Active: 0.78A / 3.891W
Idle: 0.005A / 0.026W
Mean Time Between Failure (MTBF)
1,500,000 hours
Environmental
Relative Humidity:
5% to 95%
Shock:
1,500 G/0.5 ms
Specification
256,186,271 user addressable sectors
Architecture
Self-Encrypting (SED) Solid State Drive with 25nm MLC NAND Flash and SATA interface
Interface
Serial ATA 2.0 (3.0 Gb/s)
NAND Flash
25nm MLC NAND Flash
Height
7mm (.275 in)
Width
69.85 mm (2.75 in)
Length
100.5 mm (3.95 in)
0.161 lb (73 g)
Sustained Sequential 128k Read:
Up to 450 MB/s
Sustained Sequential 128k Write:
Up to 260 MB/s
Random 4k Read:
Up to 46K IOPs
Random 4k Write:
Up to 56K IOPs
Latency
Read:
55 μs
Write:
55 μs
Power
SATA power consumption:
160 mW (active average); <85 mW (idle average)
Useful Drive Life
72TB written, up to 40GB/day for 5 years
Environmental
Relative Humidity:
5% to 95%
Shock:
1,500 G/1 ms
180GB SATA 2.5” Opal1 SED Solid State Drive (Pro 1500)
Specification
351,651,888 Unformatted Capacity (Total User Addressable Sectors in LBA mode)
Architecture
Self-Encrypting (SED) Solid State Drive with 20nm MLC NAND Flash and SATA interface
Interface
NAND Flash
20nm MLC NAND Flash
Form Factor
2.5 inch
Thickness
7 mm
Up to 78 g
Up to 540 MB/s
Up to 490 MB/s
Random 4k Read:
Up to 41K IOPs
Random 4k Write:
Up to 80K IOPs
Power
195 mW (active average); 125 mW (idle average)
1,200,000 hours
Environmental
Relative Humidity:
5% to 95%
Shock:
1,500 G/0.5 ms
128GB SATA 2.5” Opal2 SED Solid State Drive
Specification
128 GB
250,069,680 (User Addressable Sectors)
Architecture
Trusted Computing Group(TCG) OPAL compliant encrypted solid state drive.
Interface
Form Factor
2.5 inch
Height
6.80 mm ± 0.20
Width
69.85 mm ± 0.25
Length
100.20 mm ± 0.25
Up to 55 g
Up to 520 MB/s
Up to 340 MB/s
Power
Power consumption:
1,500,000 hours
Environmental
Relative Humidity:
5% to 95%
Shock:
1,500 G/0.5 ms
120GB SATA 2.5” Opal1 SED Solid State Drive
Specification
234,442,648 Unformatted Capacity (Total User Addressable Sectors in LBA mode)
Architecture
Interface
NAND Flash
20nm MLC NAND Flash
Form Factor
2.5 inch
Thickness
7 mm
Up to 78 g
Up to 540 MB/s
Up to 480 MB/s
Random 4k Read:
Up to 41K IOPs
Random 4k Write:
Up to 80K IOPs
Power
1,200,000 hours
Environmental
Relative Humidity:
5% to 95%
Shock:
1,500 G/0.5 ms
1TB 10K SATA 6.0Gb/s 3.5” Hard Disk Drive
Specification
Capacity
Rotational Speed
7,200 rpm
Interface
Serial ATA 2.0 (6.0 Gb/s)
Buffer Size
16 MB
Logical Blocks
976,773,168
Thickness
7 mm
Up to 78 g
Seek Time
Single Track:
2.0 ms
Average:
12 ms
Full-Stroke:
25 ms
Height (nominal)
9.5 mm (0.374 in)
Width (nominal)
Media diameter:
63.5 mm (2.5 in)
Physical size:
70 mm (2.75 in)
Removable storage specifications
HP Slim SuperMulti DVD Writer Drive
Specification
Height
12.7 mm height
Orientation
Either horizontal or vertical
Interface type
SATA/ATAPI
Disc recording capacity
Up to 8.5 GB DL or 4.7 GB standard
128 x 12.7 x 127 mm (5.04 x 0.5 x 5.0 in) without bezel
Weight (maximum)
190 g (0.42 lb)
Write speeds
DVD-RAM
Up to 5X
DVD-R DL
Up to 6X
DVD+R
Up to 8X
DVD+RW
Up to 8X
DVD+R DL
Up to 6X
DVD-R
Up to 8X
DVD-RW
Up to 6X
CD-R
Up to 24X
CD-RW
Up to 24X
Read speeds
DVD-RAM
Up to 5X
DVD-RW, DVD+RW
Up to 8X
DVD-R DL, DVD+R DL
Up to 8X
DVD+R, DVD-R
Up to 8X
DVD-ROM DL, DVD-ROM
Up to 8X
CD-ROM, CD-R
Up to 24X
CD-RW
Up to 24X
Access time (typical reads, including settling)
Random
DVD-ROM: 170 ms (typical), CD-ROM: 170 ms (typical)
Full Stroke
DVD-ROM: 320 ms (typical), CD-ROM: 320 ms (typical)
Stop Time
6 seconds (typical)
Power
Source
Slimline SATA DC power receptacle
DC Power Requirement
5 VDC ± 5%-100 mV ripple p-p
DC Current
5 VDC (< 1000 mA typical, 1600 mA maximum)
Environmental conditions (operating - non-condensing)
Temperature
5° to 50° C (41° to 122° F)
Relative Humidity
10% to 80%
Maximum Wet Bulb Temperature
29° C (84° F)
HP Slim Blu-ray BDXL Drive
Specification
Height
12.7 mm height
Orientation
Interface type
SATA/ATAPI
Up to 128 GB QL, 100 GB TL, 50 GB DL or 25 GB standard SL
Weight (maximum)
Up to 170 g (0.37 lb) without bezel
Triple-layer
Quadruple-layer
Write speeds
BD-R
Up to 4X
Up to 4X
BD-RE
Up to 2X
Not supported
Single-layer
Double-layer
BD-R
Up to 6X
Up to 6X
BD-RE
Up to 2X
Up to 2X
DVD-R
Up to 8X
Up to 6X
DVD-RW
Up to 6X
Not supported
DVD+R
Up to 8X
Up to 6X
DVD+RW
Up to 8X
Not supported
DVD-RAM
Up to 5X
CD-R
Up to 24X
CD-RW
Up to 24X
Triple-layer
Quadruple-layer
BD-R
Up to 4X
Up to 4X
BD-RE
Up to 4X
Not supported
Single-layer
Quadruple-layer
BD-ROM
Up to 6X
Up to 6X
BD-R
Up to 6X
Up to 6X
Read speeds
BD-RE
Up to 6X
Up to 6X
DVD-ROM
Up to 8X
Up to 8X
DVD-R
Up to 8X
Up to 8X
DVD-RW
Up to 8X
DVD+R
Up to 8X
Up to 8X
DVD+RW
Up to 8X
BDMV (AACS Compliant Disc)
Up to 6X/2X (Read/Play)
DVD-RAM
Up to 5X
DVD-Video (CSS Compliant Disc)
Up to 8X/4X (Read/Play)
CD-R/RW/ROM
Up to 24X
CD-DA(DAE)
Up to 20X/10X (Read/Play)
Random
BD-ROM: 205 ms (typical), DVD-ROM: 185 ms (typical), CD-ROM: 165 ms (typical)
Full Stroke
BD-ROM: 350 ms (typical), DVD-ROM: 345 ms (typical), CD-ROM: 340 ms (typical)
Power
Source
DC Current
5 VDC -1200 mA typical, 2000 mA maximum
Temperature
Relative Humidity
10% to 80%
29° C (84° F)
HP Slim DVD-ROM Drive
Specification
Height
12.7 mm height
Orientation
Interface type
SATA/ATAPI
Weight (maximum)
Read speeds
DVD+R/-R/+RW/-RW/+R DL /-R DL
Up to 8X
DVD-ROM
Up to 8X
CD-ROM, CD-R
Up to 24X
CD-RW
Up to 24X
Random
Full Stroke
Power
Source
DC Current
5 VDC - < 1000 mA typical < 1600 mA maximum
Environmental (all conditions non-condensing)
Temperature
Relative Humidity
10% to 80%
29° C (84° F)
Networking and communications specifications
Intel 7260 802.11 a/b/g/n PCIe x1 WLAN Card *
Specification
Dimensions (L x H)
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
Atheros AR9462
System interface
PCI-Express Mini Card
Network standard
802.11 a/b/g/n
Frequency band
Wi-Fi:
  • 802.11a/n – 4.9 – 4.95 GHz (Japan), 5.15 – 5.25 GHz, 5.25 – 5.35 GHz, 5.47 – 5.725 GHz, 5.825 – 5.850 GHz
  • 802.11b/g/n 2.402-2.482 GHz
-10° to 70°C, operating (14° to 158°F, operating)
Storage temperature
-40° to 80°C, non-operating (-40° to 176°F, non-operating)
Humidity
10-90% operating
5-95% non-operating
Operating voltage
3.3 V ±9% I/O supply voltage
Power consumption
Platform/WLAN Mode
Power consumption
Wi-Fi
Transmit mode
2 W
Receive mode
1.6 W
Idle mode (PSP) (WLAN associated)
250mW
Idle mode (WLAN unassociated)
100mW
Radio disabled
75mW
Output power
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
Security
  • IEEE and WiFi compliant 64 / 128 bit WEP encryption for a/b/g mode only
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through CCX4 and CCX Lite
  • WAPI
Antenna
2 transmit; 2 receive (2x2)
Realtek RTL8151GH-CG GbE LOM Network Adapter
Specification
Connector
RJ-45
System interface
Integrated on PCA
Controller
Realtek RTL8151GH-CG Gigabit Ethernet Controller
Memory
16 KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mbps
IEEE compliance
  • 802.1P
  • 802.1Q
  • 802.3
  • 802.3ab
  • 802.3az
  • 802.3u
Bus architecture
PCI express
Data transfer mode
PCIe-based interface for active state operation (S0 state)
Power requirement
Requires 3.3V and 1V or just 3.3V with integrated regulators
Power consumption 0.425 W
Network transfer mode
  • Full-duplex
  • Half-duplex (not supported for the 1000BASE-T transceiver)
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mbps
  • 10BASE-T (full-duplex) 20 Mbps
  • 100BASE-TX (half-duplex) 100 Mbps
  • 100BASE-TX (full-duplex) 200 Mbps
  • 1000BASE-T (full-duplex) 2000 Mbps
Environmental
  • Operating temperature: 0° to 70°C (32° to 158°F)
  • Operating humidity: 60% RH
Management
WOL, auto MDI crossover, PXE, Muti-port teaming, Advanced cable diagnostic
Intel ethernet I210-T1 gigabit network adapter
Specification
Connector
RJ-45
System interface
PCI express x1
Controller
Intel® I210 Gigabit Ethernet Controller
Memory
Integrated Dual 48K configurable transmit receive FIFO Buffers
10/100/1000 Mb/s
IEEE compliance
  • 802.1P
  • 802.1Q
  • 802.2
  • 802.3
  • 802.3AB
  • 802.3u
  • 802.3x flow control
Bus architecture
PCI-E 2.1
Data path width
X1, 250 MB/s, Bi-directional interface
Data transfer mode
Bus-master DMA
Hardware certifications
FCC, B, CE, TUV-c, TUVus Mark Canada and United States, TUV-GS Mark for European Union
Power requirement
Aux 3.3 V, 3.0 Watts in 1000 base-T and 1.0 Watts in 100 Base-T
Boot ROM support
  • Yes
  • 1000BASE-T (full-duplex) 2000 Mbps (actual rate limited by PCI bus)
Environmental
  • Operating temperature: 0° to 55°C (32° to 132°F)
  • Operating humidity: 85% at 55°C (131°F)
Management
WOL, PXE, DMI, WFM 2.0
Intel dual band wireless-N 7260 802.11 a/b/g/n (2x2) wireless network interface connection
Specification
Wireless LAN standards
IEEE 802.11a/b/g/n
Interoperability
  • Wi-Fi certified (802.11 a/b/g/n WMM, WPA, WPA2 and WPS)
  • Cisco Compatible Extensions Program compliant with Microsoft Windows 7, Windows Vista and XP.
WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista.
Frequency band
802.11b/g/n:
  • 2.402-2.482 GHz
802.11a/n:
  • 4.9 - 4.95 GHz (Japan)
  • 5.15 - 5.25 GHz
  • 5.25 - 5.35 GHz
  • 5.47 - 5.725 GHz
  • 5.825 - 5.850 GHz
Antenna structure
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11b: 1, 2, 5.5, 11 Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11n: MCS 0 ~ MCS 15, (20MHz, and 40MHz)
Modulation
  • Direct Sequence Spread Spectrum
  • CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • AES-CCMP: 128 bit in hardware
  • WPA2 certification
  • IEEE 802.11i
  • Cisco certified extensions, all versions through CCX4 and CCX Lite
  • WAPI
Check latest software/driver release for updates on supported security features.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access point required)
Roaming
IEEE 802.11 compliant roaming between band Access Points
Output power
Maximum output power may vary by country according to local regulations.
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Idle mode: 250 mW (WLAN associated) In power save polling mode and on battery power.
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio off: 100 mW (WLAN unassociated)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity
Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
  • 802.11g:- 90 dBm (6 Mbps), -89 dBm (9 Mbps), -87 dBm (12 Mbps), -85 dBm (18 Mbps), -82 dBm (24 Mbps), -79 dBm (36 Mbps), -76 dBm (48 Mbps), -74 dBm (54 Mbps)
  • 802.11b:- 95 dBm (1 Mbps), -93 dBm (2 Mbps), -91 dBm (5.5 Mbps), -88 dBm (11 Mbps)
Antenna connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form factors
PCI-Express Half-MiniCard
3.1 g (0.0068 lb)
Dimensions
Operating voltage
3.3V +/- 9%
Temperature
  • Operating:-10° to 70° C (14° to 158° F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 90% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED Activity
  • LED Amber - Radio Off
  • LED White - Radio On
Specification
IEEE 802.11a/b/g/n
Interoperability
  • Wi-Fi certification
  • BQE certification of the Bluetooth component
  • CCXv1, v2, v3, v4, v5 CCX certified (Cisco Client Extensions)
Frequency band
802.11b/g/n:
  • 2.402-2.482 GHz
802.11a/n:
  • 5.15 - 5.25 GHz
  • 5.25 - 5.35 GHz
  • 5.47 - 5.725 GHz
  • 5.825 - 5.850 GHz
Antenna structure
Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications.
Data rates
  • 802.11n: card will support rates for NSS=1 and NSS=2 for RX and TX for 20 and 40 MHz channels. Short and long guard interval shall be supported.
Security
  • IEEE 802.11i
  • WAPI
Roaming
Output power
  • +13.5 dBm minimum
  • Maximum output power must be able to achieve modular regulatory certification peak gain of +3dBi at 2.4GHz and +5dBi at 5GHz
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Radio off: 75 mW (WLAN unassociated)
Bluetooth Power Consumption
  • Peak operating: 330 mW
  • Receive: 230 mW
  • USB selective suspend: 17 mW
Power Management
  • ACPI and PCI Express bus compliant power management
  • Supports USB selective suspend and resume of the Bluetooth component through the USB control signals.
802.11b
Sensitivity (dBm)
Rate (Mbps)
Modulation and Coding Rate
-95
1
BPSK
-93
2
QPSK
-91
5.5
CCK
-88
11
CCK
802.11a/g
Sensitivity (dBm)
Rate (Mbps)
-90
6
BPSK - ½
-89
9
BPSK – ¾
-87
12
QPSK – ½
-85
18
QPSK – ¾
-82
24
16 QAM – ½
-79
36
16 QAM – ¾
-76
48
64 QAM – 2/3
-74
54
64 QAM – ¾
802.11n
Sensitivity (dBm)
Rate (Mbps)
-69
150
64 QAM – 5/6
-66
300
64 QAM – 5/6
Form factors
3.212 g (0.1133 oz)
Dimensions
26.65 x 29.85 x 1.067 mm (1.04 x 1.17 x 0.042 in)
Operating voltage
3.3V +/- 9%
Temperature
Humidity
  • Non-operating: 5% to 95% (non-condensing)
Altitude
Physical specifications
Specification
Chassis (W x H x H)
337 x 100 x 380.5 mm (13.26 x 3.93 x 14.98 in)
System volume
12.82 L
System weight
5.905 kg (13.01 lb)
Packaged (H x W x D)
528 x 229 x 499 mm (20.78 x 9.01 x 19.64 in)
Shipping weight
(Packaged – ODD x 1, HDD x 1)
Est. 9.691 kg (21.365lb)
Palletization profile
SEA
  • 4-units per layer
  • 10-layer max
  • 32-units per pallet
Software/OS
Feature
Operating systems
Preinstalled
  • Windows 8.1 Pro (64-bit)*
  • Windows 8.1 (64-bit)*
  • Windows 7 Ultimate (32-bit)**
  • Windows 7 Ultimate (64-bit)**
  • Windows 7 Professional (32-bit)**
  • Windows 7 Professional (64-bit)**
  • Windows 7 Professional (32-bit) (available through downgrade rights from Windows 8.1 Pro)**
  • Windows 7 Professional (64-bit) (available through downgrade rights from Windows 8.1 Pro)**
  • Windows 7 Home Premium (32-bit)*
  • Windows 7 Home Premium (64-bit)*
  • Windows 7 Home Basic (32-bit)*
  • FreeDOS 2.0
For all Preinstalled operating systems HP provides Microsoft WHQL certified (where applicable) drivers on www.hp.com at the time of product announcement.
Web Support
  • Windows 7 Enterprise (32-bit or 64-bit)
For all Supported operating systems HP performs testing of the OS, and makes available all HP value add software (OS dependent). Certified drivers are made available on www.hp.com within 30 days of product announcement.
*Not all features are available in all editions of Windows 8.1. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows 8.1 functionality. See http://www.microsoft.com.
**This system is preinstalled with Windows® 7 Professional software and also comes with a license and media for Windows 8.1 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
Environmental specifications
Temperature range
  • Operating: 10° to 35° C (50° to 95° F)
  • Non-operating: –30° to 60° C (–22° to 140° F)
Relative humidity
  • Operating: 10% to 90% (non-condensing at ambient)
  • Non-operating: 5% to 95% (non-condensing at ambient)
Maximum altitude (unpressurized)
  • Non-operating: 9,144 m (0 to 30,000 ft)
