HP Printers - Installing a Mac Print Driver Using Apple Software Update
This document is for HP printers that have drivers available through Apple Software Update and Mac computers.
Install the best available HP print driver and software on your Mac using Apple Software Update. Before installing the software, turn on the printer and make sure it is connected to the computer you want to print or scan from, either with a USB cable or through your local Wi-Fi or wired network.
Since October 2016, HP printer software packages are no longer delivered through Apple Software Update. Visit 123.hp.com to download the latest HP software for your printer. Alternatively, if your printer supports Apple AirPrint, you do not need a driver to print from your Mac or iOS device. For more information, go to About AirPrint (in English).
