HP EliteBook 750 G1 Notebook PC - Overview
Product description
HP EliteBook 740 G1 Notebook PC
Product features
Feature
Chipset integrated with processor
Processors
Intel Multi-Core Processors:
  • Intel Core i5-4210U Processor (1.60-GHz, 3MB cache)*, **
  • Intel Core i3-4030U Processor (1.7-GHz, 3MB cache)*, **
Intel's numbering is not a measurement of higher performance. Processor speed denotes maximum performance mode; processor will run at lower speeds in battery optimization mode.
* Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
** Not available with Intel iAMT
Memory
Standard: DDR3L PC3-10600 SDRAM (1333 MHz)* Two SODIMM slots supporting dual-channel memory 4GB, 8GB* SODIMMs
Maximum : Upgradeable to 16384 MB with optional 8192 MB SODIMMs in slots 1 and 2*
Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
* Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB may not all be available due to system resource requirements.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
Graphics
Models with integrated graphics:
  • Intel HD Graphics 4400
740
Internal:
  • 14 in diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
  • 14 in diagonal LED-backlit HD+ anti-glare SVA flat (1600 x 900)
  • 14 in diagonal LED-backlit HD+ SVA flat + touch (1600 x 900)*
  • 14 in diagonal LED-backlit FHD anti-glare UWVA slim (1920 x 1080)
External: Up to 32-bit per pixel color depth
DisplayPort Supports resolutions up to 3200 x 2000 at 60Hz
VGA port Port supports resolutions up to 1920 x 1200 external resolution at 60 Hz
750
Internal:
  • 15.6 in diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
  • 15.6 in diagonal LED-backlit FHD anti-glare SVA slim(1920 x 1080)
  • 15.6 in diagonal LED-backlit FHD SVA slim + touch (1920 x 1080)
DisplayPort Supports resolutions up to 3200x2000 at 60Hz
Keyboards, pointing devices, buttons, and function keys
Touchpad with scroll zone, on/off button with LED indicator, two-way scroll, two pick buttons
The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and includes an all-metal keyboard deck for greater rigidity, as well as HP DuraKeys. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available. Backlit keyboard available as an option.
Internal Storage Device
Hard drives
  • 320/500 GB/1 TB 5400 rpm SATA II Hard Drive
  • 320/500/750 GB/1 TB 7200 rpm SATA II Hard Drive
  • 500 GB 7200 rpm SED (Self Encrypting Drive)
  • 500 GB 5400 rpm FIPS SED (Self Encrypting Drive)
HP 3D DriveGuard (Windows only) The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive.
Solid State Drive:
  • 120 GB M.2 (NGFF) Solid State Drive
  • 128/180/240/256/512 GB 2.5” Solid State Drive
  • 180/256 GB SED Solid State Drive
Power Supply
  • HP 45W Smart AC adapter
  • 45W 2-prong 7.4mm DC jack AC Adapter (Only for Japan)
  • HP 65W EM Smart AC adapter (China and India only)
Power cord is configurable; either 3.2 feet or 6 feet (1.0 or 1.8 meter).
Total length including external AC adapter is 9.2 feet or 12 feet (2.86 or 3.66 meter).
Battery
740
Primary battery:
  • 3-cell (50 WHr) battery with hard drive
  • 3-cell (24 WHr) battery with 2.5 in solid state drive
  • 3-cell (50 WHr) battery with 2.5 in solid state drive
  • 3-cell (50 WHr) battery + Slice (60 WHr) with 2.5 in solid state drive
Secondary battery:
  • 6-cell HP Long Life Slice 60 WHr (optional)
750
Primary battery:
  • 3-cell (24 WHr) battery with 2.5” solid state drive
Software overview
Feature
Operating System
  • Windows 8.1 Pro 64*
  • Windows 8.1 64*
  • Windows 7 Professional**
  • Windows 7 Professional 32*
  • Windows 7 Professional 64*
  • FreeDOS
Preinstalled software with Windows operating system
BIOS
  • HP BIOSphere
  • HP Sure Start
  • HP DriveLock / HP Automatic Drive Lock
  • HP BIOS Protection
  • HP SpareKey
  • Update via Network
  • Master Record Security
  • Power On Authentication
  • Pre-Boot Security
  • Secure Erase
  • Hybrid Boot
  • Measured Boot
  • Secure Boot
MultiMedia
  • CyberLink Power DVD
  • CyberLink Power2Go
  • CyberLink YouCam BE (Windows 7 only)
Communication
  • HP Connection Manager (Windows 7 only)
  • HP GPS and Location
  • HP Mobile Connect (Windows 8 only)
  • HP Wireless Hotspot (Windows 8 only)
  • Intel WiDi Software
  • HP Roaming Alert
  • Intel My WiFi and Wireless Drivers
