HP Z840 Workstation - Overview
Product description
HP Z840 Workstation
Product features
Feature
Intel® C612 Chipset
Graphics
Intel HD Graphics on all models (integrated on processor)
  • NVIDIA NVS 310 512MB 1st GFX
  • NVIDIA Quadro K2200 4GB 1st GFX
  • NVIDIA Quadro K4200 4GB 1st GFX
  • AMD FirePro W2100 2GB 1st GFX
  • NVIDIA NVS 310 512MB 2nd GFX
  • NVIDIA Quadro K2200 4GB 2nd GFX
  • NVIDIA Quadro K4200 4GB 2nd GFX
  • AMD FirePro W2100 2GB 2nd GFX
  • NVIDIA Quadro K2200 4GB 3rd GFX
Processors
  • Intel Xeon E5-2620v3 2.4 1866 6C 1stCPU
  • Intel Xeon E5-2630v3 2.4 1866 8C 1stCPU
  • Intel Xeon E5-2637v3 3.5 2133 4C 1stCPU
  • Intel Xeon E5-2620v3 2.4 1866 6C 2ndCPU
  • Intel Xeon E5-2630v3 2.4 1866 8C 2ndCPU
  • Intel Xeon E5-2637v3 3.5 2133 4C 2ndCPU
Storage/hard drives
SAS Hard Drives:
  • 600GB* SAS 15K rpm 6Gb/s 3.5" HDD
  • 300GB* SAS 15K rpm 6Gb/s 3.5" HDD
  • HP 300GB* SAS 10K SFF HDD
  • HP 600GB* SAS 10K SFF HDD
  • HP 1.2TB* SAS 10K SFF HDD
*For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30GB of system disk is reserved for system recovery software.
Up to 5 SATA drives, 5 SAS, drives, or 6 SATA 2.5", Small Form Factor (SFF) drives 8 port SAS Controller included on the system board
SATA Hard Drives:
  • 3.0TB* SATA 7200 rpm 6Gb/s 3.5" HDD
  • 2.0TB* SATA 7200 rpm 6Gb/s 3.5" HDD
  • 1TB* SATA 7200 rpm 6Gb/s 3.5" HDD
  • 500GB* SATA 7200 rpm 6Gb/s 3.5" HDD
  • 500GB* SATA 7.2K SED SFF HDD
SATA Solid State Drives (SSDs):
  • HP 128GB* SATA 6Gb/s SSD
  • HP 256GB* SATA 6Gb/s SSD
  • HP 512GB* SATA 6Gb/s SSD
  • HP 1TB* SATA 6Gb/s SSD
  • Samsung Enterprise 240GB* SATA SSD
  • Samsung Enterprise 480GB* SATA SSD
  • Intel Pro 1500 180GB* SATA SSD
  • HP 256GB* SATA 6Gb/s SED Opal 1 SSD
The 256GB Self-Encrypting Drive (SED) version has similar performance to the standard 256GB SSD. It is also available in Opal 1.0 and Opal 2.0 versions.
PCIe SSDs:
  • HP Z Turbo Drive 512GB* SSD
  • HP Z Turbo Drive 256GB* SSD
Memory
4GB DDR4-2133 ECC Registered RAM
8GB DDR4-2133 ECC Registered RAM
16GB DDR4-2133 ECC Registered RAM
32GB DDR4-2133 ECC Load Reduced (LR) RAM
Identical memory components are used to build the CTO configurations as are available as After Market Options (AMO). The AMO Option Kit Part # are shown alongside the memory DIMMs.
For details on the supported memory configurations on the HP Z840 Workstation, please refer to the System Technical Specifications - System Board section of this document.
DIMMs should be equally distributed across all four memory channels for optimal performance.
Each processor supports up to 4 channels of DDR4 memory. To realize full performance at least 1 DIMM must be inserted into each channel.
The CPUs determine the speed at which the memory is clocked. For example, if a 1600MHz capable CPU is used in the system, the maximum speed the memory will run at is 1600MHz regardless of the specified speed of the memory.
You cannot intermix LR DIMMs with Registered DIMMs. The system will not work.
Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB may not all be available due to system resources.
Networking/Communications
HP X520 10GbE Dual Port Adapter
HP 10GbE SFP+ SR Transceiver
Intel Ethernet I210-T1 PCIe NIC
Intel 7260 802.11 a/b/g/n PCIe WLAN NIC
Integrated Intel I210AT PCIe GbE Controller
Integrated Intel I218LM PCIe GbE Controller
HP 361T PCIe Dual Port Gigabit NIC
"Gigabit" or "GbE" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
*Wireless access point and internet service required. Availability of public wireless access points limited.
Audio/Multimedia
Integrated Realtek HD ALC221 Audio
Input Devices
Keyboard:
  • HP USB Smart Card Keyboard
  • HP 2.4GHz Wireless Keyboard & Mouse
  • HP USB Optical 3-Button 2.9M OEM Mouse
  • HP SpaceExplorer 3D USB Controller
Mice:
  • HP SpacePilot 3D USB Intelligent Controller
  • HP PS/2 Keyboard
  • HP PS/2 Mouse
  • HP USB Keyboard
  • HP USB Optical Mouse
  • HP USB 1000dpi Laser Mouse
  • HP Internal USB Port Kit
  • HP SAS Back Panel Connector Kit
  • HP eSATA PCI Cable Kit
  • HP Power Cord Kit
  • HP Workstation Mouse Pad
  • HP Optical Bay HDD Mounting Bracket
  • HP ENERGY STAR® Qualified Configuration
The HP Internal USB Port kit has a single USB 2.0 type A connector.
No hot plug / hot swap supported with eSATA
Software overview
Feature
Operating systems (Preinstalled)
  • Windows 8.1 Pro 64-bit*
  • Windows 7 Professional 64-bit (available through downgrade rights from Windows 8.1 64-bit)**
  • Windows 7 Professional (MSNA) 64-Bit*
  • HP Linux Installer Kit
  • Red Hat Enterprise Linux (RHEL) Workstation - Paper License (1yr)1
* Not all features are available in all editions or versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality.
** This system is preinstalled with Windows® 7 Pro software and also comes with a license and media for Windows 8.1 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
1 This second OS must be ordered with the HP Linux Installer Kit as the first OS.
  • HP Performance Advisor
  • HP Remote Graphics Software (RGS) 6.0
  • MS Office Home & Business 2013
  • Cyberlink PowerDVD and Power2Go
  • Foxit PhantomPDF Express
Country: Flag Thailand
