HP Z440 Workstation - Overview
Product description
HP Z440 Workstation
Product features
Feature
Intel® C612 Chipset
Graphics
  • NVIDIA NVS 310 512MB Graphics
  • NVIDIA NVS 315 1GB Graphics
  • NVIDIA NVS 510 2GB Graphics
Graphics Cable Adapters
  • HP DisplayPort to Dual Link DVI Adapter
  • HP DisplayPort To DVI-D Adapter
  • HP DisplayPort To DVI-D Adapter (2-Pack)
  • HP DisplayPort To DVI-D Adapter (4-Pack)
  • HP DisplayPort To DVI-D Adapter (6-Pack)
  • HP DisplayPort To VGA Adapter
  • HP DisplayPort To VGA Adapter 2nd
Storage/Hard drives
SAS Hard Drives for HP Workstations:
  • 600GB SAS 15K rpm 6Gb/s 3.5" HDD
  • 300GB SAS 15K rpm 6Gb/s 3.5" HDD
  • HP 1.2TB SAS 10K SFF HDD
  • HP 600GB SAS 10K SFF HDD
  • HP 300GB SAS 10K SFF HDD
*For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30GB of system disk is reserved for system recovery software.
Up to (4) 3.5-inch 15K rpm SAS drives: 300, 600 GB; 2.4 TB max
Up to (4) 2.5-inch 10K rpm SAS drives: 300, 600 GB, 1.2 TB; 4.8 TB max
SAS controller add-in card required
3rd and 4th SFF SAS HDDs will be automatically installed into a single 2:1 5.25" external bay adapter
Removable Boot Drive option
SATA Hard Drives:
  • 500GB SATA 7200 rpm 6Gb/s 3.5" HDD
  • 1TB SATA 7200 rpm 6Gb/s 3.5" HDD
  • 2.0TB SATA 7200 rpm 6Gb/s 3.5" HDD
  • 3.0TB SATA 7200 rpm 6Gb/s 3.5" HDD
  • 500GB SATA 7.2K SED SFF HDD
Up to (4) 3.5-inch 7200 rpm SATA drives: 500 GB, 1.0, 2.0, 3.0, 4.0* TB; 16.0 TB max
Up to (1) 2.5-inch SATA Self-Encrypting Drive (SED): 500 GB Opal 1
*4TB drive planned to be available late 2014
SATA Solid State Drives:
  • HP 128GB SATA 6Gb/s SSD
  • HP 256GB SATA 6Gb/s SSD
  • HP 512GB SATA 6Gb/s SSD
  • HP 1TB SATA 6Gb/s SSD
  • HP 256GB SATA 6Gb/s SED SSD
  • Intel Pro 1500 180GB SATA SSD
  • Samsung Enterprise 240GB SATA SSD
  • Samsung Enterprise 480GB SATA SSD
Up to (4) 2.5-inch 6Gb/s SATA Solid State Drives: 128, 256, 512 GB, 1 TB; 4.0 TB max
Up to (1) 2.5-inch 6Gb/s SATA Self-Encrypting Solid State Drive (SED SSD): 256 GB Opal 2
Up to (4) 2.5-inch Intel Pro 1500 6Gb/s SATA Solid State Drive: 180 GB; 720 GB max
Up to (4) 2.5-inch Samsung Enterprise 6Gb/s SATA Solid State Drives: 240, 480 GB; 1.9 TB max
3rd and 4th SSDs will be automatically installed into a single 2:1 5.25" external bay adapter
PCIe Solid State Drives:
  • HP Z Turbo Drive 512GB SSD
  • HP Z Turbo Drive 256GB SSD
Up to (2) PCI Express Solid State Drives: 256, 512 GB; 1.0 TB max
PCIe SSDs are not available with SAS controller and/or HDDs
Hard Drive Controllers
  • Integrated SATA 6.0 Gb/s Controller
  • RAID 0 Configuration – Striped Array
  • RAID 0 Data Configuration -- Boot/OS Drive + 2 Drive Striped Array
  • RAID 1 Configuration – Mirrored Array
  • RAID 10 Configuration - Striped/Mirrored Array
  • LSI 9217-4i4e 8-port SAS 6Gb/s RAID Card
SATA hardware RAID is supported on Linux systems that have support for the Intel RSTe technology.
The Linux kernel, with built-in software RAID, provides excellent functionality and performance. It is a good alternative to hardware-based RAID. Please visit http://www.hp.com/support/linux_hardware_matrix for RAID capabilities with Linux.
All drives must be identical in type and capacity.
RAID arrays greater than 2 TB are fully supported.
1 Requires hard drives with identical speed, capacity, and interface. Specific user-configured hardware SAS RAID configurations are supported on this Linux system. For details, please visit http://www.hp.com/support/linux_hardware_matrix
2 Specific user-configured hardware SAS RAID configurations are supported on this Linux system.
IS: Striping of 2 or more HDDs into a single logical volume
IM: Mirroring of 2 HDDs into a single logical volume
IME: Mirroring of 3 or more HDDs into a single logical volume.
Memory
4GB DDR4-2133 ECC Registered RAM
8GB DDR4-2133 ECC Registered RAM
16GB DDR4-2133 ECC Registered RAM
For details on the supported memory configurations on the HP Z440 Workstation, please refer to the System Technical Specifications - System Board section of this document.
Each processor supports up to 4 channels of DDR4 memory. To realize full performance at least 1 DIMM must be inserted into each channel.
The CPUs determine the speed at which the memory is clocked. If an 1866MHz capable CPU is used in the system, the maximum speed the memory will run at is 1866MHz, regardless of the specified speed of the memory.
1 ONLY registered DDR4 DIMMs are supported. DDR3 DIMMs ARE NOT SUPPORTED.
2 Configurations of greater than 4x memory DIMMs require the HP Z440 Memory Cooling Solution, which is available both CTO (J2R51AV) and AMO (J2R52AA).
Networking/Communications
Integrated Intel I218LM PCIe GbE Controller
Intel Ethernet I210-T1 PCIe NIC
HP X520 10GbE Dual Port Adapter
HP 10GbE SFP+ SR Transceiver
HP 361T PCIe Dual Port Gigabit NIC
Intel 7260 802.11 a/b/g/n PCIe WLAN NIC
"Gigabit" Ethernet indicates compliance with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/sec. For high speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
*Wireless access point and internet service required. Availability of public wireless access points limited.
Audio/Multimedia
Integrated Realtek HD ALC221 Audio
Input Devices
Keyboard:
  • HP PS/2 Keyboard
  • HP USB Keyboard
  • HP USB Smart Card Keyboard
  • HP Wireless Keyboard and Mouse
Mice:
  • HP PS/2 Mouse
  • HP USB Optical Mouse
  • HP USB 1000dpi Laser Mouse
  • HP USB Optical 3-Button 2.9M OEM Mouse
  • HP SpaceMouse Pro USB 3D Input Device
  • HP SpacePilot Pro 3D USB Intelligent Controller
Software overview
Feature
Operating systems (Preinstalled)
  • Windows 8.1 Pro 64-bit*
  • Windows 7 Professional 64-bit (available through downgrade rights from Windows 8.1 64-bit)**
  • Windows 7 Professional (MSNA) 64-Bit*
  • HP Linux Installer Kit
  • Red Hat Enterprise Linux (RHEL) Workstation - Paper License (1yr)
* Not all features are available in all editions or versions of Windows. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows functionality. See http://www.microsoft.com.
** This system is preinstalled with Windows® 7 Pro software and also comes with a license and media for Windows 8.1 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
1 This second OS must be ordered with the HP Linux Installer Kit as the first OS.
  • HP Performance Advisor
  • HP Remote Graphics Software (RGS) 6.0
  • MS Office Home & Business 2013
  • Cyberlink PowerDVD and Power2Go
  • Foxit PhantomPDF Express
Available as a free download here: http://www.hp.com/go/performanceadvisor.
NOTE 2: Supported operating systems:
  • Windows 7 Professional 32/64
  • Windows 8 Professional 32/64
  • RHEL v6.5
  • SLED 11 SP3
For more information, go to: http://www.hp.com/go/rgs.
Must select as a Configure to Order option.
