    Fix Windows 10 Update Issues
HP ZBook 17 G2 Mobile Workstation Specifications
Product image
Product features
Feature
Accelerated processing unit
  • 4th Generation Intel® Core™ i7-4940MX (3.10 GHz, 1600 MHz, 8 MB L3 Cache, 4 cores, 57W)
    Up to 4.00 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel® Core™ i7-4910MQ (2.9 GHz, 1600MHz, 8 MB L3 cache, 4 cores, 47W)*
    Up to 3.90 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel® Core™ i7-4810MQ (2.8 GHz, 1600MHz, 6 MB L3 cache, 4 cores, 47W)*
    Up to 3.80 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel® Core™ i7-4710MQ (2.5 GHz, 1600MHz, 6 MB L3 cache, 4 cores, 47W) (no vPro support)*
    Up to 3.50 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel® Core™ i7-4610M (3.00 GHz, 1600 MHz, 4 MB L3 Cache, 2 cores, 37W)
    Up to 3.70 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel® Core™ i5-4340M (2.90 GHz, 1600 MHz, 3 MB L3 Cache, 2 cores, 37W)
    Up to 3.60 GHz with Intel Turbo Boost Technology
  • Intel Dual-Core i5-4210M (3.20 GHz, 1600 MHz, 3 MB L3 Cache, 4 threads, 37W)
    Up to 3.20 GHz with Intel Turbo Boost Technology
*Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing system required. Performance will vary depending on your hardware and software configurations. Intel’s numbering is not a measurement of higher performance.
Mobile Intel® QM87
Inel Core i5 with VPRO and Core i7 with VPRO Technology Capable
Intel Core i5 with vPro and Core i7 with vPro technology is a selectable feature that is available on units configured with select processors, a qualified Intel Centrino® WLAN module and a preinstalled Windows operating system. It provides advances in remote manageability, security, energy efficient performance, and wireless connectivity. Intel Active Management Technology 9.0 (iAMT) offers built-in manageability and proactive security for networked mobile workstations, even when they are powered off* or when the operating system is inoperable. It can help identify threats before they reach the network, isolate infected systems, and update regardless of their power state.
*Requires a Windows operating system, network hardware and software, connection with a power source, and a direct (non-VPN) corporate network connection which is either cable or wireless LAN.
Some functionality of Intel Core i5 with vPro/Core i7 with vPro technology, such as Intel Active Management technology and Intel Virtualization technology, requires additional third- party software in order to run. Availability of future "virtual appliances" applications for Intel Core i5 with vPro/Core i7 with vPro technology is dependent on third- party software providers. Compatibility with future "virtual appliances" is yet to be determined.
Graphics
  • AMD FirePro™ M6100 with 2 GB dedicated GDDR5 video memory
    Microsoft DirectX 11.1 (Shader Model 5.0) and OpenGL 4.2 capable
  • NVIDIA Quadro K1100M with 2 GB dedicated GDDR5 video memory
  • NVIDIA Quadro K3100M with 4 GB dedicated GDDR5 video memory
  • NVIDIA Quadro K4100M with 4 GB dedicated GDDR5 video memory
  • NVIDIA Quadro K5100M with 8 GB dedicated GDDR5 video memory
  • NVIDIA Optimus Technology and AMD EnduroTM Technology supported
NVIDIA Quadro mobile professional graphics support up to five independent displays when using an HP Advanced Docking station (sold separately). AMD FirePro™ professional graphics support up to five independent displays when using an HP Advanced Docking station (sold separately).
Multi-Display Support
  • Without Docking Station:
    HP ZBook 17 without the use of a Docking Station supports up to a maximum of four independent displays. These four displays are the internal panel plus three external displays connected to the VGA, the DisplayPort (DP), and the Thunderbolt™ Port connectors.
  • With Docking Station*:
    The Advanced Docking Station has VGA and four digital display output connectors (two DVI and two DP). Of those four digital display connectors, only two may be used at a time (two DVI, two DP or one DP and one DVI). When used together with the HP ZBook 17, a maximum of five independent displays are supported. These five displays are the internal panel plus four external displays connected to three display outputs connectors from the standard or Advanced Docking Station*, and the ThunderboltTM connector from the ZBook.
  • DP 1.2 “daisy-chain” feature:
    On HP ZBook 17, the maximum number of independent displays is increased to six with the use of DP1.2 “daisy-chain” feature. This requires Hybrid Graphics to be enabled, one monitor connected to the dock VGA, and at least one daisy chain connection on (A) System DP, (B) Docking Station DP 1, (C) Docking Station DP 2.
Internal
  • 17.3" diagonal LED-backlit HD+SVA anti-glare (1600 x 900)
  • 17.3" diagonal LED-backlit FHD WVA anti-glare (1920 x 1080)
  • 17.3" diagonal LED-backlit FHD DreamColor UWVA IPS anti-glare (1920 x 1080)
External
  • Up to 30-bit (2^30) per pixel "Deep Color"
    (total of 1,073,741,824 color variations)
Thunderbolt™ 2*
Supported as part of the daisy chain connected with Intel approved thunderbolt cables.
Thunderbolt Features
  • Legacy : DP 1.1a, DVI-A/D, HDMI and VGA displays attached to the end of the thunderbolt daisy chain via Intel certified dongles
  • DP 1.2 redrive: DisplayPort monitors capable of supporting DP 1.2 may be directly attached to the Thunderbolt port to achieve HBR2 and MST functionality.
  • DP display with miniDP connector may be attached directly to TB (Thunderbolt) port.
  • DP display with standard DP connector and other legacy displays (HDMI, DVI, VGA) may be attached to TB with the use of a dongle.
  • DP1.2 MST feature ("daisy-chain" feature) is supported through TB port.
* Thunderbolt™ 2 is new technology. Install all the latest drivers for your Thunderbolt device before connecting the device to the Thunderbolt port. Thunderbolt cable and Thunderbolt device (sold separately) must be compatible with Windows.
DisplayPort w/MST (Multi-stream Transport)
Supports resolutions up to Supports resolutions up to QFHD 3840 x 2160, 24/30-bit color depth at 60 Hz, and WUXGA (1920 x 1200) monitors, 24/30-bit color depth at 120 Hz.
DisplayPort Feature
  • Multi-stream Transport (MST): Multi-stream Transport is a DP 1.2 feature that allows daisy chaining of DP 1.2 monitors (requires built in support of DP 1.2 MST in monitor), or the use of DP 1.2 hubs with MST to achieve 4 active displays without a docking station.
  • Optimal configurations for enabling the maximum number of displays (up to five independent displays when using an HP Advanced Docking station (sold separately) with hybrid graphics enabled):
    • With Port Replicator:
      • Dock DP + Dock DVI + Internal Display + Thunderbolt DP port (enabling VGA will drop one digital display)
    • With Advanced Port Replicator:
      • Dock DP1 + Dock DP2 + Internal Display + Thunderbolt DP port (enabling VGA will drop one digital display)
VGA
Port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz.
DVI-D (single link)
Video signal available through DVI port in optional HP Docking Station (sold separately) as well as through DP to DVI adapters to use without the optional HP Docking Station supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage and drives
Primary storage bay: Hard Drives
  • 320/500 GB*5400 rpm SMART SATA II HDD
*For hard drives GB = 1 billion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
Memory
Z Turbo Drive Storage Bay
256 GB Z Turbo Drive (PCIe Solid State Drive)
Primary Storage Bay
Hard Drives*
  • 500/750 GB, 1 TB 7200 rpm SMART SATA II
  • 500 GB 7200 rpm SMART SATA II Self Encrypting Drive
  • 500 GB 5400 rpm SMART SATA II Self Encrypting Drive FIPS 140-2 compliant
HP 3D DriveGuard (Windows only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Solid State Drive*
  • 128/180/240/256/512 GB SATA 6 Gb/sec
  • 256 GB SATA 6 Gb/sec Self Encrypting Drive
*For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) of system and up to 30 GB (for Windows 8) disk is reserved for system recovery software.
Networking/Communications
Wireless
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Optional Broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth® is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Mobile Broadband options
  • HP hs3110 HSPA+ Mobile Module
  • HP lt4112 LTE/HSPA+ Qualcomm® Gobi™ 4G Module
  • HP lt4211 LTE/EV-DO/HSPA+ Gobi 4G Module
All 802.11 integrated wireless LAN options
  • Intel Dual Band Wireless-NB 7260 802.11 a/b/g/n (2x2) WiFi
  • Intel Dual Band Wireless-AC 7260 802.11 a/b/g/n/ac (2x2) WiFi and Bluetooth 4.0 combo
  • Intel Dual Band Wireless-AN 7260 802.11 a/b/g/n (2x2) WiFi and Bluetooth 4.0 combo
Communications
Integrated Intel I217-LM Gigabit** Network Connection (vPro configurations)
*Broadband wireless is an optional feature and requires separately purchased service contract. Check with your local vendor for coverage area and availability in your area. Connection and speeds will vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all regions.
**The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
***Integrated Intel Wi-Di feature is available on select configurations only and requires separately purchased projector, tv or computer monitor with an integrated or external Wi-Di receiver. External Wi-Di receivers connect to the projector, tv or computer monitor via a standard HDMI cable, also sold separately.
****802.11 requires access point and internet service. Availability of public wireless access points limited.
WWAN not available with DreamColor displays.
Audio/Multimedia
Audio
  • DTS Studio Sound HD audio (Windows OS only)
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Combo mic-in / stereo headphone-out jack
Optional 720p HD webcam
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280x720 resolution (720p) and up to 30fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Keyboard/Pointing devices/Buttons and function keys
Keyboard
Optional backlit keyboard with Function key control to toggle backlit brightness setting - off/full/half brightness The HP spill-resistant keyboard is designed using a thin layer of Mylar film under the keyboard and a drain system that funnels fluid through a hole in the bottom of the notebook. This minimizes the risk of damage to sensitive components underneath. The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, function keys, and 19.05 x 19.05 mm key pitch (center-to-center spacing). U.S. and International key layouts are available. Other features include hot keys for instant access to power conservation and brightness.
Pointing devices
  • Touchpad with On/Off button, two-way scroll, gestures, three pick buttons
  • Pointstick with three additional pointstick buttons
  • Image sensor touchpad for enhanced performance and improved precision on scroll and gesture
Buttons and Function Keys
Separate launch buttons provide easy access to the following features: wireless on/off, volume mute. Function keys provide control of the following features: standby mode, external display, volume down, volume up, HP Power Assistant (Windows 7 only), and display brightness.
Power specifications
Specification
Stand-alone power requirements (AC power)
  • Nominal operating voltage:
    • 19.5 V
  • Average Operating Power:
    • DreamColor: 35 W
    • Without DreamColor: 25 W
  • Max operating power:
    • Discrete: < 200 W or < 230 W
Display specifications
17.3-inch HD+ SVA LED anti-glare
Specification
Dimensions (H x W)
38.2 x 21.5 cm (15.0 x 8.5 in)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typ)
Pixel resolution
  • Pitch: 0.3287 x 0.3287 mm
  • Format: 1600 x 900
  • Configuration: RGB stripe
Backlight
LED
PPI
106
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/10/20 (Left/Right/Down/Up) (minimum)
17.3-inch FHD WVA LED anti-glare
Specification
Dimensions (H x W)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
500:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typ)
Pixel resolution
  • Pitch: 0.1989 x 0.1989 mm
  • Format: 1920 x 1080
Backlight
LED
PPI
127
Viewing angle
  • ±60° Horizontal, ±50° Vertical (minimum)
  • 60/60/50/50 (Left/Right/Down/Up) (minimum)
17.3-inch FHD UWVA LED anti-glare Dreamcolor
Specification
Dimensions (H x W)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typ)
Pixel resolution
Backlight
LED
PPI
127
Viewing angle
  • 80° Horizontal, ±80° Vertical (minimum)
  • 80/80/80/80 (Left/Right/Down/Up) (min)
Technology Type
30-bit In-Plane Switching (IPS)
Color Depth
10-bits/color
Display Colors
Over 1 billion colors (native mode)
Color Gamut Coverage
CIE1931 (x,y)
CIE 1976 (u',v')
NTSC
109%
129%
AdobeRGB
114%
127%
sRGB
154%
148%
Storage and drives
750 GB 7200 rpm SATA Hard Drive
Specification
Drive weight
115 g (0.25 lb)
Capacity
750 GB
Height
9.5 mm (0.37 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0 Gb/s
Transfer rate (synchronous maximum):
600 MB/s (Drive Capability)
Seek time (typical reads, including settling)
  • Single Track: 1.5 ms ~ 2 ms
  • Average: 11 ms ~ 13 ms
  • Maximum: 15 ms ~ 21 ms
Cache
Up To 32 MB
Rotational speeds
7200 rpm
Logical Blocks
1,465,149,168
Operating Temperature
0° to 60° C (32° to 140° F) [top cover temp]
Features
ATA Security, S.M.A.R.T., NCQ, Ultra DMA
500 GB 7200 rpm SATA Hard Drive
Specification
Drive weight
92 - 115 g (0.20 - 0.25 lbs)
Capacity
500 GB
Height
7/9.7 mm (0.28/0.38 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Rotational speed
7200 rpm
Logical blocks
976,773,168
Operating temperature [case temp]
Features
  • Single Track:: 1.5 ms ~ 2 ms
  • Maximum: 18 ms ~ 22 ms
Cache
Up To 32 MB
*For hard drives and solid state drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 8.1) of system disk is reserved for the system recovery software.
500 GB 5400 rpm SATA FIPS* Hard Drive
Specification
Drive weight
95 g (0.21 lbs)
Capacity
500 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA Security; TCG Opal 2.x, FIPS, S.M.A.R.T., NCQ, Ultra DMA
  • Average: 12 ms
  • Maximum: 22 ms
Cache
16 MB
*FIPS-certified, hardware-based AES-256 encryption image.
Specification
Drive weight
95 g (0.21 lbs)
Capacity
500 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 2.6
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA Security, TCG OPAL v1.00, S.M.A.R.T., NCQ, Ultra DMA
300 MB/s (Drive Capability)
  • Single Track:: 2 ms
  • Average: 13 ms
  • Maximum: 18 ms
Cache
32 MB
SATA 6 Gb/s 512 GB, 2.5-inch Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
512 GB
NAND Type
MLC
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
  • Maximum Sequential Read: 505 MB/s
  • Maximum Sequential Write: 470 MB/s
Logical blocks
1,000,215,216
0° to 70° C (32° to 158° F) [ambient temp]
Features
ATA Security; DIPM; TRIM; DEVSLP
SATA 6 Gb/s 256 GB, 2.5-inch SATA SED Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
556 GB
NAND Type
MLC
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
  • Maximum Sequential Read: Up to 515 MB/s
  • Maximum Sequential Write: Up to 465 MB/s
Logical blocks
500,118,192
Features
SATA 6 Gb/s 240 GB, 2.5-inch Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
240 GB
NAND Type
MLC
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
  • Maximum Sequential Read: Up to 540 MB/s
  • Maximum Sequential Write: Up to 490 MB/s
Logical blocks
468,862,128
Features
SATA 6 Gb/s 180 GB, 2.5-inch Solid State Drive
Specification
Drive weight
78 g (0.17 lbs)
Capacity
180 GB
NAND Type
MLC
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
Logical blocks
351,651,888
Features
Specification
Drive weight
78 g (0.17 lbs)
Capacity
128 GB
Height
7 mm (0.28 in)
Width
69.85 mm (2.75 in)
Interface
ATA-8, SATA 3.0
Performance
  • Maximum Sequential Read: Up to 550 MB/s
  • Maximum Sequential Write: Up to 350 MB/s
Logical blocks
250,069,680
Features
Z Turbo Drive 256 GB, PCIe Solid State Drive
Specification
Drive weight
10 g (0.02 lbs)
Capacity
256 GB
Height
60 mm (0.24 in)
Width
22 mm (0.87 in)
Interface
ATA-8, PCIe 2.0
Performance
  • Maximum Sequential Read: 730 MB/s
  • Maximum Sequential Write: 620 MB/s
Logical blocks
500,118,192
0° to 70° C (32° to 158° F) [case temp]
Features
*For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) of system and up to 30 GB (for Windows 8) disk is reserved for system recovery software.
Software and Security
Security
Windows 8
  • HP Device Access Manager with Just In Time Authentication
  • DigitalPersona Fingerprint Driver
  • HP Drive Encryption1
  • HP File Sanitizer2
  • HP Client Security Manager
  • HP SpareKey
  • Microsoft Defender
  • Validity Fingerprint Driver
Windows 7
  • HP File Sanitizer
  • HP SpareKey
  • Microsoft Security Essentials
BIOS Features
Windows 8
  • Absolute Persistence Module3
  • HP Sure Start
  • HP Automatic Drive Lock4
  • HP BIOS Protection
  • HP Disk Sanitizer (Not for SSD)5
  • HP DriveLock6
  • HP SpareKey
  • Hybrid Boot
  • Master Boot Record Security
  • Measured Boot
  • Power On Authentication
  • Pre-Boot Security
  • Secure Boot
  • Secure Erase (SSD & HDD)7
  • BIOS Update via Network
Windows 7
  • HP Sure Start
  • HP DriveLock
  • HP SpareKey
  • Hybrid Boot
  • Measured Boot
  • Pre-Boot Security
  • Secure Boot
MultiMedia
Windows 8
  • Cyberlink Power2Go
  • Cyberlink PowerDVD
Windows 7
  • Cyberlink YouCam BE
HP Value Add
Windows 8
  • Getting Started with Windows 8
  • HP 3D DriveGuard8
  • HP ePrint Driver9
  • HP Hotkey Support
  • HP Manageability
  • HP PageLift App10
  • HP Support Assistant
  • Box 50GB Offer11
  • Foxit PhantomPDF Express for HP
  • Skype
Windows 7
  • HP 3D DriveGuard
  • HP ePrint Driver
  • HP Hotkey Support
  • HP Manageability
  • HP PageLift
  • HP Recovery Manager
  • HP Recovery Disc Creator (HPRDC)
  • Box 50GB
  • Skype
Microsoft Products
Windows 8
  • Buy Office
Windows 7
  • Buy Office
Additional Software Available from the Web
HP SoftPaq Download Manager
HP Software System Manager
Workstation ISV Certifications
See the latest list of certifications at HP Workstation ISV Certification page.
HP Remote Graphics Software
The remote desktop solution for serious workstation users and their most demanding applications.
Download at: www.hp.com/go/RGS
HP Remote Graphics Software will note be available for Windows 8.1 at launch.
HP Performance Advisor
HP Performance Advisor enables optimal configuration of HP Mobile Workstations delivering stability and best performance.
HP Performance Advisor will guide your system setup allowing a "custom" configuration that best matches the workstation to user requirements.
HP Recovery Manager
Models shipped with Windows 7 include HP Recovery Manager. HP Recovery Manager enables fast recovery of the factory preinstalled image if the system becomes corrupted or if important system files are accidentally deleted. Up to 36 GB (for Windows 7) of system and up to 36 GB (for Windows 8) disk is reserved for system recovery software.
Security
See Software section above.
Other Standard Security Features
Integrated Smart Card Reader
HP Spare Key (requires initial user setup)
One-Step Logon
Common Criteria EAL4+ Augmented Certified Discrete TPM 1.2 Embedded Security Chip
Security lock slot
Support for Intel® AT12
Optional Security Features
HP Fingerprint Sensor (optional)
Computrace* with GPS Tracking - Subscription based security solution providing the ability to track, initiate physical recovery, conduct asset management, and perform remote data delete by utilizing GPS technology. GPS functionality requires HP Mobile Broadband Module.
* The Computrace agent is shipped turned off, and must be activated by customers when they purchase a subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S.
Audio/multimedia - DTS Sound+
Specification
Implementation
IDT 92HD91
Function Key Volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone in
Stereo
Headphone/Line out
Stereo
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Specification
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling rate(s)
8 kHz - 48kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Integrated stereo
Specification
Power rating
2 W
Impedance
4 ohms
HP 230W Slim Smart AC Adapter
Dimensions
7.87 x 3.94 x 1.0 in (200 x 100mm x 25.4mm)
840 g (1.85 lb)
Input
100 to 240 VAC
  • Output power: 40W
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 3.5 A at 90 VAC, 1.75 A at 180 VAC
Output power
  • Output power: 230W
  • DC output: 19.5V
  • Hold-up time: 5 msec at 115 VAC input
  • Output current limit: <18A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental Design
  • Temperature
    • Operating: 5° to 40° C (32° to 104° F)
    • Non-operating (storage): -20° to 65° C (-4° to 149° F)
  • Altitude: 0 to 3,048 m (0 to 10,000 ft)
  • Humidity: 20% to 80%
  • Storage Humidity: 10% to 90%
EMI and safety certifications
CE Mark- full compliance with LVD and EMC directives; Worldwide safety standards- IEC950, EN60950, UL1950, Class 1, SELV; Agency approvals- C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCIB, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
HP 200W Slim Smart AC Adapter
Dimensions (H x W x L)
172 x 96 x 25.4 mm (6.77 x 3.80 x 1.0 in)
748 g) (1.65 lb)
Input
100 to 240 VAC
  • Input Efficiency: 87% min at 115 VAC
  • Input AC current: 2.9 A at 90 VAC, 1.45 A at 180 VAC
Output
  • Output power: 200W
  • DC output: 19.5V
  • Output current limit: <16A, Over voltage protection- 29V max automatic shutdown
Connector
  • Temperature
HP 8-cell Lithium-Ion Battery (83 WHr)
2 x 5.3 x 27cm (0.8 x 2.1 x 10.6 in)
0.442 kg (0.99 lb)
Cells/Type
Lithium-Ion
Energy
  • Temperature
    • Operating (Charging): 0° to 45° C (32° to 113° F)
    • Operating (Discharging): -10° to 50° C (14° to 122° F)
    • Non-operating: -20° to 50° C (-4° to 122° F)
Battery Re-Charge Time
  • System in OFF or Standby Mode: 2.5 hours
  • System ON: 3 to 5 hours
Fuel Gauge LED
No
1 year
Compatible with optional Travel Battery
Yes
HP Long Life 8-cell Lithium-Ion Battery (75 WHr)
2 x 5.3 x 27 cm (0.8 x 2.1 x 10.6 in)
0.442 kg (0.99 lb)
Cells/Type
8-cell; Lithium-Ion
Energy
  • Voltage: 14.4V
  • Amp-hour capacity: 5.1Ah
  • Watt-hour capacity: 75Wh
Temperature
  • Operating (Discharging): (-10° to 60° C (14° to 140° F)
  • Non-operating: -20° to 60° C (-4° to 140° F)
Fuel Gauge LED
No
Warranty*
3 year
Yes
* 3-year platform warranty is required for a 3-year Long Life Battery warranty.
Optional HP BB09 Ultra Extended Life Notebook Battery (secondary battery)
3 x 15 x 29 cm (1.2 x 5.9 x 11.4 in)
0.682 kg (1.5 lb)
Cells/Type
Lithium-Ion
Energy
  • Voltage: 11.25V
  • Amp-hour capacity: 8.85Ah
  • Watt-hour capacity: 100Wh
Temperature
  • Operating (Discharging): (-10° to 50° C (14° to 122° F)
  • System in OFF or Standby Mode: 3.5 to 5 hours
  • System ON: 4 to 7 hours
Fuel Gauge LED
Yes
1 year
No
Optional HP ST09 Extended Life Notebook Battery ("Travel Battery") (secondary battery)
3 x 15 x 30.5 cm (1.2 x 6.1 x 12 in)
0.550 kg (1.2 lb)
Cells/Type
Lithium-Ion Polymer
Energy
  • Voltage: 11.1V
  • Amp-hour capacity: 6.6Ah
  • Watt-hour capacity: 73Wh
Temperature
Fuel Gauge LED
Yes
1 year
Yes
Wireless
Communications
* Broadband wireless is an optional feature and requires separately purchased service contract. Check with your local vendor for coverage area and availability in your area. Connection and speeds will vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all regions.
** The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
*** Integrated Intel Wi-Di feature is available on select configurations only and requires separately purchased projector, tv or computer monitor with an integrated or external Wi-Di receiver. External Wi-Di receivers connect to the projector, tv or computer monitor via a standard HDMI cable, also sold separately.
**** 802.11 requires access point and internet service. Availability of public wireless access points limited.
Physical specifications
Specification
Dimensions (H x W x D)
1.33 in (at front) x 16.37 in x 10.7 in
34 mm (at front) x 416 mm x 272 mm
Height with DreamColor display: 1.34 in / 34.0 mm at front; 1.57in / 40.0 mm at rear
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes Dual Core CPU, HD+, NVIDIA Kepler, DVD R/W, 2GBx1 SODIMM, , wLAN, FPR, 8-cell battery, no wWAN, no BlueTooth.
Starting at 7.42 lb (3.36 kg) with Z Turbo Drive and weight saver (no optical drive)
Starting at 7.67 lb (3.46 kg) with hard drive and DVD-R/W drive
Software overview
Preinstalled Software with Windows Operating System
Feature
Security
Windows 8
  • HP SpareKey
Windows 7
  • HP File Sanitizer
  • HP SpareKey
BIOS Features
Windows 8
  • HP Sure Start
  • HP DriveLock6
  • HP SpareKey
  • Hybrid Boot
  • Measured Boot
  • Pre-Boot Security
  • Secure Boot
  • Secure Erase (SSD & HDD)6
Windows 7
  • HP Sure Start
  • HP DriveLock
  • HP SpareKey
  • Hybrid Boot
  • Measured Boot
  • Pre-Boot Security
  • Secure Boot
MultiMedia
Windows 8
Windows 7
HP Value Add
Windows 8
  • HP 3D DriveGuard8
  • HP ePrint Driver9
  • HP Hotkey Support
  • HP Manageability
  • HP PageLift App10
  • Box 50GB Offer11
  • Skype
Windows 7
  • HP 3D DriveGuard
  • HP ePrint Driver
  • HP Hotkey Support
  • HP Manageability
  • HP PageLift
  • Box 50GB Offer
  • Skype
Microsoft Products
Windows 8
  • Buy Office
Windows 7
  • Buy Office
  • HP SoftPaq Download Manager
  • HP Software System Manager
  • The remote desktop solution for serious workstation users and their most demanding applications.
  • Download at: www.hp.com/go/RGS
  • HP Performance Advisor enables optimal configuration of HP Mobile Workstations delivering stability and best performance. HP Performance Advisor will guide your system setup allowing a "custom" configuration that best matches the workstation to user requirements.
HP Recovery Manager
Security
  • Integrated Smart Card Reader
  • HP Spare Key (requires initial user setup)
  • One-Step Logon
  • Common Criteria EAL4+ Augmented Certified Discrete TPM 1.2 Embedded Security Chip
  • Security lock slot
  • Support for Intel® AT12
  • HP Fingerprint Sensor (optional)
  • Computrace* with GPS Tracking - Subscription based security solution providing the ability to track, initiate physical recovery, conduct asset management, and perform remote data delete by utilizing GPS technology. GPS functionality requires HP Mobile Broadband Module.
Environmental specifications
Specification
Temperature
  • Operating: 0° to 35° C (32° to 95° F) (not writing optical)
  • Operating: 5° to 35° C (41° to 95° F) (writing optical)
  • Non-operating: (-20° to 60° C (-4° to 140° F)
Relative humidity
  • Operating: 10% to 90%, non-condensing
  • Non-operating: 5% to 95%, 101.6° F (38.7° C) maximum wet bulb temperature
Shock
  • Operating: 40 G, 2 ms, half-sine
  • Non-operating: 200 G, 2 ms, half-sine
Random vibration
  • Operating: 0.75 grms
  • Non-operating: 1.50 grms
Altitude (unpressurized)
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Planned Industry Standard Certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR®: Select models*
  • EPEAT: Gold **
  • ICES: Yes
  • Australia / NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
*Configurations of the HP Classmate that are ENERGY STAR qualified are identified as HP Classmate ENERGY STAR on HP websites and on www.energystar.gov.
**EPEAT® registered where applicable. EPEAT registration varies by country.
For accessibility information on HP products, please visit: http://www.hp.com/accessibility.
