Remove and replace the battery for HP Pavilion 10-k000 and 10-j000 x2 Detachable PCs
This document applies to HP Pavilion 10-k000 and 10-j000 x2 detachable computers.
HP Pavilion 10-k000 or 10-j000 x2 detachable computer
Before you begin
  • Have a Phillips head screwdriver, tweezers or needle-nose pliers, and a non-marring flat-bladed tool, or similar prying tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
  warning:
To avoid personal injury or damage to the computer use extreme care not to twist, crack, or puncture the battery.
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion 10-k000 and 10-j000 x2 detachable computers.
Removing the battery
Follow the steps in this section to remove the battery.
  warning:
Step 1
To begin, remove the display enclosure.
For instructions to remove the display enclosure, see the HP support document, Remove and Replace the Display Enclosure for HP Pavilion 10-k000 and 10-j000 x2 Detachable PCs.
Removing the display enclosure
Step 2
Carefully lift the locking bar up on the webcam connector and disconnect the webcam ribbon cable from the system board.
Lifting the locking bar on the webcam ribbon cable connector
Step 3
Carefully remove the webcam ribbon cable from the adhesive that secures it to the battery.
Lifting the webcam ribbon cable from the adhesive that secures it to the battery
Step 4
Using a non-marring, flat bladed tool carefully loosen the battery from the adhesive that secures the battery to the display panel assembly.
Lifting the battery from the adhesive with the flat-bladed tool
Step 5
Lift and remove the battery.
Replacing the battery
Use the steps in this section to replace the battery.
Step 1
Place the battery into position on the display panel assembly and lower it into place.
Make sure the webcam ribbon cable is not pinched between the battery and the display panel assembly.
Placing the battery on the display panel assembly
Step 2
Gently apply pressure to the battery to adhere it to the display panel assembly.
Pressing down on the battery to adhere it to the display panel assembly
Step 3
Insert the webcam ribbon cable into its connector on the system board...
Inserting the webcam ribbon cable into the connector
...and press the locking bar down to lock the cable into place.
Pressing the locking bar down to hold the cable in the connector
Step 4
Apply pressure to the webcam ribbon cable to adhere it to the battery.
Pressing to adhere the webcam ribbon cable to the battery
Step 5
Replace the display enclosure.
For instructions to replace the display enclosure, see the HP support document, Remove and Replace the Display Enclosure for HP Pavilion 10-k000 and 10-j000 x2 Detachable PCs.
Replacing the display enclosure
