    Looking for Site Help?
HP LaserJet Enterprise MFP M630 - Clear jams under the top cover and in the registration area
The following information describes how to clear a paper jam under the top cover. When a jam occurs, the control panel displays an animation that assists in clearing the jam.
  1. Open Tray 1 and remove the the envelope-feeder cover (or remove the optional envelope feeder, if it is installed).
    Figure : Remove the envelope-feeder cover
  2. Lift the top-cover-release latch and open the top cover.
    Figure : Open the top cover
  3. Remove the toner cartridge.
    Figure : Remove the toner cartridge
  4. At the front of the registration roller, lift the small green tab to raise the plastic roller shield, and then pull any jammed paper straight out.
    Figure : Remove the jammed paper
  5. At the back of the roller, use the longer green tab to raise the metal shield, and then pull any jammed paper straight out.
  6. Install the toner cartridge.
    Figure : Install the toner cartridge
  7. Close the top cover.
    Figure : Close the top cover
  8. Insert the envelope-feeder cover.
    Figure : Insert the envelope-feeder cover (or the optional envelope feeder).
Country: Flag Thailand
