Document ID: c04423228
Version: 1
HP Elite X2 1011 G1 and EliteBook Folio 1020 G1 PCs - When Connected Standby Is Disabled in BIOS, Device Manager Displays Realtek HD Audio Driver as an Unknown Device
Release date : 26-Aug-2014
Last updated : 26-Aug-2014
DESCRIPTION
Disabling the Connected Standby option in BIOS causes the Realtek HD audio driver to be displayed as an Unknown Device in Device Manager.
SCOPE
Affected Platforms:
HP Elite x2 1011 G1
HP EliteBook Folio 1020 Notebook PC
Software:
Realtek HD Audio Driver version 6.0.1.7293
Operating Systems:
  • Microsoft Windows 8.1 (Standard)
  • Microsoft Windows 8.1 (Pro)
  • Microsoft Windows 8.1 (Enterprise)
RESOLUTION
To resolve this issue perform one (1) of the following procedures:
Procedure 1: Enable Connected Standby in BIOS setting.
  1. Power on Computer.
  2. Immediately press Esc button during startup (Esc button displays the startup menu).
  3. Press F10, select Advance and choose Device Configurations.
  4. Scroll down to Connected Standby.
  5. Check the box to enable Connected Standby.
  6. Press the F10 key to accept the change.
  7. Click Yes on the Save Changes screen to exit the BIOS.
  8. Sign into Windows and open Device Manager.
  9. Tap or click arrow to expand Sound, video and game controllers.
  10. Verify Realtek High Definition Audio is displayed correctly.
  11. Close Device Manager.
Procedure 2: If Connected Standby is disabled in BIOS, run HP Software Setup to reinstall the audio driver.
  1. On the Start screen, tap or click the Search button to open Search.
  2. Enter HP Software Setup in the Search field.
  3. Select HP Software Setup from the results list.
  4. Tap or click Yes when the User Account Control (UAC) appears.
  5. The HP Software Setup utility will open.
  6. Tap or click Hardware Enabling Drivers.
  7. Locate and select the Realtek HD Audio Driver.
  8. Tap or click Install.
  9. Allow the installation process to complete the driver install.
  10. Tap or click Continue.
  11. The computer will restart.
  12. Sign into Windows and open Device Manager.
  13. Tap or click Sound, video and game controllers.
  14. Verify Realtek High Definition Audio is displayed correctly.
Hardware platforms affected : HP Elite x2 1011 G1, HP EliteBook Folio 1020 G1 Notebook PC
Support Communication Cross Reference ID : IA04423228
