Document ID: c04422548
Version: 1
HP EliteBook G2 and ProBook G2 Notebook PCs - Microphone Recording Level Set to 50 Percent Records Playback at a Low Level.
Release date : 25-Aug-2014
Last updated : 25-Aug-2014
DESCRIPTION
Recorded playback volume is too low. This only occurs when the recording level is set to 50% or below.
SCOPE
Computers:
  • HP EliteBook 725 G2 Notebook PC
  • HP EliteBook 745 G2 Notebook PC
  • HP EliteBook 755 G2 Notebook PC
  • HP EliteBook Folio 9480m Notebook PC
  • HP ProBook 430 G2 Notebook PC
  • HP ProBook 440 G2 Notebook PC
  • HP ProBook 445 G2 Notebook PC
  • HP ProBook 450 G2 Notebook PC
  • HP ProBook 455 G2 Notebook PC
  • HP ProBook 470 G2 Notebook PC
Operating Systems:
  • Microsoft Windows 8.1 (standard)
  • Microsoft Windows 8.1 Pro
  • Microsoft Windows 8.1 (Enterprise)
RESOLUTION
To resolve this issue, manually adjust recording level to increase the recording level to 100 percent.
  1. From the Windows Start screen, select the Search Bar.
  2. Enter Sound in the Search Bar.
    Note: If you use a touch screen, simply bring up the on-screen keyboard first.
  3. Select Sound from the search results.
    Figure 1: Search results screen
  4. In the Sound window, select the Recording tab.
  5. Tap or click the recording device that you want to use as your recording device.
    Figure 2: Sound Tab
  6. Choose the desired microphone and tap or click Properties.
  7. In the Properties window, make sure that the Use this device (enable) option is selected in the Device usage drop-down list.
    Figure 3: Microphone Properties
  8. Select the Levels tab.
  9. Make sure that the Microphone sensitivity is set to the maximum level (100%)
  10. Be sure the microphone is not muted. Also, check that the Microphone Boost is set to minimum, then tap or click Apply, then OK.
    Figure 4: Microphone Levels tab
  11. From the Windows Start screen, select the Search Bar and enter Sound Recorder.
  12. Select Sound Recorder from the search results.
    Figure 5: Search result for Sound Recorder
  13. Tap or click Start Recording and speak into the microphone. Try recording your voice, then play it back.
    Figure 6: Sound Recorder
Hardware platforms affected : HP EliteBook 725 G2 Notebook PC, HP EliteBook 745 G2 Notebook PC, HP EliteBook 755 G2 Notebook PC, HP EliteBook Folio 9480m Notebook PC, HP ProBook 430 G2 Notebook PC, HP ProBook 440 G2 Notebook PC, HP ProBook 445 G2 Notebook PC, HP ProBook 450 G2 Notebook PC, HP ProBook 455 G2 Notebook PC, HP ProBook 470 G2 Notebook PC
Support Communication Cross Reference ID : IA04422548
