    Fix HP Printer issue on macOS
HP LaserJet Enterprise MFP M630 - Replace the staple cartridge
If the stapler runs out of staples, jobs continue to print to the stapler/stacker, but they are not stapled.
To purchase staple cartridges, go to the HP Parts Store at www.hp.com/buy/parts.
Staple cartridge information
Item
Part number
HP Staple Cartridge Refill
Replacement staple cartridge
C8091A
Remove and replace the staple cartridge
  1. Press the release latch, and then slide the stapling mailbox away from the product.
    Figure : Release the stapling mailbox
  2. Press the latch to release the stapler door.
    Figure : Press the latch
  3. Open the stapler door.
    Figure : Open the stapler door
  4. Lift the green tab on the staple cartridge up, and then pull the staple cartridge straight out.
    Figure : Remove the staple cartridge
  5. Insert the new staple cartridge into the stapler and push down on the green handle until it snaps into place.
    Figure : Insert the staple cartridge
  6. Close the stapler door.
    Figure : Close the stapler door
  7. Slide the stapling mailbox toward the product until it latches in place.
    Figure : Attach the stapling mailbox
