HP EliteBook Folio 9480m Notebook PC - Specifications
Physical specifications
Feature
Weights and dimensions
  • 4-cell (52Whr): 1.61 kg (3.56 lb)
  • 6-cell (60Whr): 2.06kg (4.54lb)
Dimensions (w x d x h)
  • 33.8 x 23.1 x 1.895 cm (13.3 x 9.09 x 0.75 in)
Weight varies by configuration and components. Weight includes No FPR, 1 SODIMM, M.2 120GB SSD, no camera, no WWAN, Intel WLAN. Weight varies by configuration and components.
Ports/Slots
Ports
  • VGA – One
  • DisplayPort 1.2a with Multi-Stream Transport (MST) support – One (v1.2a)
  • Headphone/Microphone combo port – One
  • Power Connector – One
  • Secondary Battery Connector – One
  • Docking Connector – One
  • RJ-45 (Ethernet) – One
  • USB 3.0 – Two
  • USB 3.0 charging port – One
Digital media slots
  • 1 SD slot (supported media include: SD, SDHC, SDXC)
System specifications
Specification
Stand-Alone powerRequirements (AC Power)
  • Nominal Operating Voltage: 19.5 V
  • Average Operating Power: 5.23 W
  • Max Operating Power: <45 W
Temperature
  • Operating: 0° to 35° C (32° to 95° F) (not writing optical)
  • Non-operating: -20° to 60° C (-4° to 140° F)
Relative humidity
  • Operating: 10% to 90%, non-condensing
  • Non-operating: 5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
  • Operating: 40 G, 2 ms, half-sine
  • Non-operating: 200 G, 2 ms, half-sine
Random Vibration
  • Operating: 0.75 grms
  • Non-operating: 1.50 grms
Altitude (unpressurized)
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: Select models (Microsoft OS)*
  • EPEAT: Registered Gold in United States**
  • ICES: Yes
  • Australia/NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
* Configurations of the HP EliteBook Folio 9480m that are ENERGY STAR qualified are identified as HP EliteBook Folio ENERGY STAR on HP websites and on www.energystar.gov.
** EPEAT registration varies by country. See www.epeat.net for registration status by country.
EPEAT status listed above applies to U.S.
For accessibility information on HP products, please visit: http://www.hp.com/accessibility.
Display specifications
14.0-inch LED HD (1366 x 768)
Specification
Dimensions (W x H)
32.4 x 19.2 cm (12.74 x 7.56 in)
Diagonal size
35.6cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
400:1 (typical)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.227 mm
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
PPI
112 ppi
Viewing angle
  • ±30° Horizontal, ±10° vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum)
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
14.0-inch LED HD+ (1600 x 900) anti-glare
Specification
Dimensions (W x H)
32.1 x 20.6 cm (12.64 x 8.11 in)
Diagonal size
35.6cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1
Refresh rate
60 Hz
Brightness
250 nit (typical)
Pixel resolution
  • Pitch: 0.1935 mm
  • Format: 1600 x 900
Backlight
LED
PPI
131 ppi
Viewing angle
STORAGE AND DRIVES
The EliteBook Folio is available in standard thin and light configurations for customers who value the ultra-thin design but prefer options such as a standalone HDD or require a self-encrypting hard drive. These configurations will not meet Intel’s definition of an Ultrabook.
500 GB 7200 rpm SATA Hard Drive
Specification
Drive Weight
95g (0.21 lbs)
Capacity
500 GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer Rate
Synchronous (maximum): 300 MB/s (Drive Capability)
S.M.A.R.T
IV
Seek Time (typical reads, including settling)
  • Single Track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Rotational Speed
7200 rpm
Logical Blocks
976,773,168
Operating Temperature
0° to 60° C (32° to 140° F) [case temp]
Features
ATA Security
500 GB 7200 rpm SMART SATA II Self Encrypting Hard Drive
Specification
Drive Weight
95g (0.21 lbs)
Capacity
500 GB
Height
7 mm (0.276 in)
Width
63.5 mm (2.5 in)
Interface
Transfer Rate
S.M.A.R.T
IV
  • Single Track: 1 ms
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16 MB
Rotational Speed
7200 rpm
Logical Blocks
976,773,168
Features
ATA Security
SATA 6 Gb/s 256 GB, 2.5- inch SATA SED Solid State Drive
Specification
Drive Weight
73 Grams
Capacity
256 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: Up to 460 MB/s
  • Maximum Sequential Write: Up to 260 MB/s
Logical Blocks
500,118,192
0° to 70°C (32° to 158°F) [case temp]
Features
ATA Security; ATA-8 compliant; SATA 3.0; DIPM; TRIM
SATA 6 Gb/s 240 GB, 2.5- inch Solid State Drive
Specification
Drive Weight
78 Grams
Capacity
240 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: 550 MB/s
  • Maximum Sequential Write: 520 MB/s
Logical Blocks
468,862,128
Features
ATA Security; ATA-8, SATA 3.0; DIPM; TRIM
SATA 6 Gb/s 180 GB, 2.5- inch Solid State Drive
Specification
Drive Weight
78 Grams
Capacity
180 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
Logical Blocks
351,651,888
SATA 6 Gb/s 128 GB, 2.5- inch Solid State Drive
Specification
Drive Weight
73 Grams
Capacity
128 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: 415 MB/s
  • Maximum Sequential Write: 175 MB/s
Logical Blocks
250,069,680
Features
ATA Security; ATA-8; SATA 3.0 DIPM; TRIM
Features
Specification
Drive Weight
73 Grams
Capacity
128 GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
Logical Blocks
250,069,680
Features
120 GB* M.2 Solid State Drive
Specification
Drive Weight
< 10 Grams
Capacity
128 GB
Height
22 mm (0.276 in)
Width
42 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum Sequential Read: 540 MB/s
  • Maximum Sequential Write: 480 MB/s
Logical Blocks
234,441,648
Features
ATA Security; ATA-8; SATA 3.0; TRIM
* For storage drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30GB (for Windows 8) of system disk is reserved for system recovery software.
Security
HP Fingerprint Sensor (optional)
Specification
Mobile voltage operation
3.0V-3.6V Single Supply
Operating temperature
0° – 70°C (32° – 158°F)
Current consumption at 3.3 V
>70 mA peak imaging and scrolling
>25 mA hardware finger detection
Advanced Power Management
High-rate image capture
Up to 240 image frames /sec
ESD resistance
IEC 61000-4-2 Level 4 (±15KV)
Detection matrix
192 x 16 Pixels
9.7 mm x 0.81 mm
500 ppi High-Resolution Images
Networking/Communications
Intel I218LM Gigabit Network Connection
Specification
Connector
RJ-45
System Interface
Integrated on PCA
Controller
Intel I218LM GbE platform LAN connect networking controller
Memory
24 KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mbps
IEEE Compliance
  • 802.1P
  • 802.1Q
  • 802.2
  • 802.3
  • 802.3ab
  • 802.3az
  • 802.3u
Bus architecture:
PCI Express and SMBus
Data transfer mode
PCIe-based interface for active state operation (S0 state) and SMBus for host and management traffic (Sx low power state)
Power requirement
  • Requires 3.3V and 0.9V or just 3.3V with integrated regulators
  • Power consumption 0.733 Watts
Boot ROM support
Yes
Network transfer mode
  • Full-duplex
  • Half-duplex (not supported for the 1000BASE-T transceiver)
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mbps
  • 10BASE-T (full-duplex) 20 Mbps
  • 100BASE-TX (half-duplex) 100 Mbps
  • 100BASE-TX (full-duplex) 200 Mbps
  • 1000BASE-T (full-duplex) 2000 Mbps
Environmental
  • Operating Temperature: 0° to 85° C
  • Operating Humidity: 60% RH
Management
WOL, auto MDI crossover, PXE, Muti-port teaming, RSS, Advanced cable diagnostic.
Alerting
ASF 2.0 support; iAMT 9.0 support
HP hs3110HSPA+ Mobile Broadband* Module
Specification
Technology/Operating bands
  • Modes: WCDMA/HSDPA/HSUPA/HSPA+/AWS/GSM/EDGE/GPRS
  • Penta-band WCDMA/HSDPA/HSUPA/HSPA+/AWS:
    • 850/900/1900/2100/AWS MHz
  • GSM/GPRS/EDGE: 850/900/1800/1900 MHz
Wireless protocol standards
  • GSM/GPRS/EDGE: Class B, Multi-slot class 33, coding schemes CS1 - CS4 and MSC1 - MSC9.
  • UMTS/WCDMA: Release 99 and Release 7
  • Advanced Receiver Type 3i
GPS
GPS Standalone, A-GPS: L1 (Internet- and Network assisted)
Wireless parametric standards
Complies with 3GPP specifications
Maximum data rates
  • GPRS/EDGE: Multi-slot Class 33, Class B
  • WCDMA PS: UL (384 kbps) / DL (384 kbps)
  • UL/DL HSPA: UL (5.76 Mbps)/ DL (7.2 Mbps)
  • UL/DL HSPA+: UL (5.76 Mbps)/ DL (21Mbps)
Maximum output power
WCDMA/HSPA/HSPA+ 2100/1900/900/850/AWS MHz:
  • +24dBm (Power Class 3)
  • GPRS 1900/1800 MHz: +30dBm (Power Class 1)
  • GPRS 900/850 MHz: +33dBm (Power Class 4)
  • EDGE 1900/1800 MHz: +26dBm (Power Class E2)
  • EDGE 900/850 MHz: +27dBm (Power Class E2)
Maximum power consumption:
2500mA (peak); 600mA (average)
Power consumption, sleep mode
3.6 mA
Power management
  • USB selective suspend, Connected Standby
  • Integrated notebook wireless button
Antenna type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the display enclosure
Form Factor
M.2 Socket 2, USB 2.0 interface high speed
<6 g
Dimensions (Length x Width x Thickness)
42 x 30 x 2.3 mm (2.01 x 1.18 x 0.18 in)
SIM card supply voltage
1.8 V/3.0 V UICC (SIM/UICC/USIM)
Voltage, Operating
3.135V~4.4V (3.3 V recommended)
Temperature, operating
  • -10° to 55° C (14° to 131° F) (Normal operation)
  • -20° to 70° C (-4° to 158° F) (Extended operation)
Temperature, storage
-40° to 85° C (-40° to 185° F)
Humidity
5% to 95%
Configuration utilities
HP Connection Manager
LED activity
  • LED Off - Radio Off
  • Solid LED On - Radio On
*Mobile Broadband is an optional feature and requires factory configuration. Use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds will vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, and in all regions.
HP lt4112 LTE/HSPA+ Gobi™ 4G Module*
Specification
  • LTE FDD all bands with diversity: 2100 MHz (Band I), 1900 MHz (Band II), 1800 MHz (Band III), 850 MHz (Band V), 2600 MHz (Band VII), 900 MHz (Band VIII), 800 MHz (Band XX, DD800)
  • WCDMA/HSDPA/HSUPA/HSPA+ all bands with diversity: 2100 MHz (Band I), 1900 MHz (Band II), 800 MHz (Band V), 900 MHz (Band VIII)
  • GSM/GPRS/EDGE: 1900 MHz (Band II), 1800 MHz (Band III), 850 MHz (Band V), 900 MHz (Band VIII)
  • 3GPP Release 8 LTE Specification
  • WCDMA R99, 3GPP Release 5, 6 and 7 UMTS Specification
Complies with 3GPP specifications Release 8 for LTE
Maximum data rates
  • LTE (Category 3): 100 Mbps (Download), 50Mbps (Upload)
  • DC-HSPA+: 42 Mbps (Download), 5.76 Mbps (Upload)
  • HSPA+: 21.6 Mbps (Download), 5.76 Mbps (Upload)
  • EDGE: 236.8 kbps (Download), 236.8 kbps (Upload)
  • GPRS: 85.6 kbps(Download), 85.6 kbps (Upload)
GPS
Standalone
GPS bands
1575.42 MHz (± 1.023 MHz), GLONASS 1596-1607MHz
  • LTE: +23 dBm (+/- 2 dBm)
  • WCDMA: +23.5 dBm (+/- 1 dBm)
  • GPRS Band II, III: +29.5 dBm (+/- 1 dBm)
  • GPRS Band V, VIII: +32.5 dBm (+/- 1 dBm)
  • EGPRS Band II, III: +26.5 dBM (+/-1.5 dBm)
  • EGPRS Band V, VIII: +27.5 dBM (+/-1.5 dBm)
  • LTE: 1,200 mA (peak); <900 mA (average)
  • WCDMA: 1,100 mA (peak); <800 mA (average)
  • EGPRS: 2,800 mA (peak); <7900 mA (average)
3 mA
Power management
USB selective suspend, Integrated notebook wireless button
Form Factor
Dual high efficiency multi-band antennae with spatial diversity
6 g
42 mm × 30 mm × 2.3 mm
Voltage, Operating
3.135 V to 4.4 V (3.3 V +1.1V/-0.165V)
Temperature, operating (from TIA/EIA/IS-98-D)
–10° to 55° C (14° to 131° F)
Temperature, non-operating, 96 hours (from MIL-STD 202 Method 108)
–40° to 85° C (–40° to 185° F)
Humidity, non-operating
95% relative humidity for 48 hours @ 185° F (85° C) (non-condensing)
LED activity
* Mobile Broadband is an optional feature and requires factory configuration. Use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds will vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, and in all regions.
HP lt4211 LTE/EV-DO/HSPA+ 4G WWAN*
Specification
  • LTE: 1900 (Band 2)/1700 (Band 4)/850 (Band 5)/700 (Band 13), 700 (Band 17), 1900 (Band 25) MHz
  • HSPA+: 2100 (Band 1)/1900 (Band 2)/1700 (Band 4)/850 (Band 5), 800 (Band 8) MHz
  • E-GPRS: 1900 (Band 2)/1800 (Band 3)/850 (Band 5)/900 (Band 8) MHz
  • EV-DO: 800 (BC0)/1900 (BC1) MHz
  • 3GPP Release 9 LTE Specification
  • E-GPRS: Class B, Multi-slot class 33, coding schemes CS1 - CS4 and MSC1 - MSC9
  • EVDO Release 0 and Release A
GPS
Standalone
GPS bands
1575.42 MHz, GLONASS 1602 MHz
Maximum data rates
  • WCDMA PS: 384 kbs (Download), 384 kbs (Upload)
  • WCDMA CS: 64 kbs (Download), 64 kbs (Upload)
  • E-GPRS: 236.8 kbps (Download), 236.8 kbps (Upload)
  • EV-DO Rev.B: 14.7 Mbps (Download), 5.4 Mbps (Upload)
  • EV-DO Rev.A: 3.1 Mbps (Download), 1.8 Mbps (Upload)
  • LTE: +23 dBm (+1/- 2 dBm)
  • HSPA+: +24 dBm (+1/- 2 dBm)
  • E-GPRS Band 1800/1900: +25 dBM (+/-1 dBm)
  • E-GPRS Band 850/900: +26 dBM (+/-1 dBm)
  • GPRS 1800/1900 : +30 dBm (+1/-2 dBm)
  • GPRS 850/900: +32 dBm (+/- 1 dBm)
  • EV-DO: +24 dBM (+/-1 dBm)
  • HSPA+: 1,100 mA (peak); <800 mA (average)
  • E-GPRS: 2,800 mA (peak); <500 mA (average)
  • EV-DO: 1000 mA (peak); <700 mA (average)
Form Factor
M.2, 3042-S3 Key B
6 g
42 x 30 x 2.3 mm (1.65 x 1.18 x 0.09 in)
*Mobile Broadband is an optional feature and requires factory configuration. Connection requires wireless data service contract, network support, and is not available in all areas. Contact service provider to determine the coverage area and availability. Connection speeds will vary due to location, environment, network conditions, and other factors.
Intel Dual Band Wireless- N 7260 802.11 a/b/g/n (2x2) WiFi + Bluetooth 4.0 Combo Adaptor*, **
Specification
Wireless LAN Standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Frequency Band
802.11b/g/n
  • 2.402 - 2.482 GHz
802.11a/n
  • 4.9 - 4.95 GHz (Japan)
  • 5.15 - 5.25 GHz
  • 5.25 - 5.35 GHz
  • 5.47 - 5.725 GHz
  • 5.825 - 5.850 GHz
Antenna Structure
2 transmit; 2 receive (2x2)
Maximum data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11b: 1, 2, 5.5, 11 Mbps
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
  • 802.11n: card will support rates for NSS=1 and NSS=2 for RX and TX for 20 and 40 MHz channels. Short and long guard interval shall be supported.
Modulation
  • Direct Sequence Spread Spectrum
  • CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security1:
  • IEEE and WiFi compliant 64 / 128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES.
  • WPA2 certification
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5
  • WAPI
  • FIPS 140-2
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Network Architecture
Ad-hoc (Peer to Peer)
Models
Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between band Access Points
Output Power2
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
Power Consumption
  • Transmit: 2.0 Watts
  • Receive: 1.6 Watts
  • Idle mode3: 250 mW (WLAN Associated)
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio off: 75 mW
Power Management
  • ACPI and PCI Express compliant power management
  • 802.11 compliant power saving mode
Receiver Sensitivity4
802.11g:
  • -90 dBm (6 Mbps)
  • -89 dBm (9 Mbps)
  • -87 dBm (12 Mbps)
  • -85 dBm (18 Mbps)
  • -82 dBm (24 Mbps)
  • -79 dBm (36 Mbps)
  • -76 dBm (48 Mbps)
  • -74 dBm (54 Mbps)
802.11b:
  • -95 dBm (1 Mbps)
  • -93 dBm (2 Mbps)
  • -91 dBm (5.5 Mbps)
  • -88 dBm (11 Mbps)
802.11g:
  • -90 dBm (6 Mbps)
  • -89 dBm (9 Mbps)
  • -87 dBm (12 Mbps)
  • -85 dBm (18 Mbps)
  • -82 dBm (24 Mbps)
  • -79 dBm (36 Mbps)
  • -76 dBm (48 Mbps)
  • -74 dBm (54 Mbps)
802.11n:
  • -69 dBm (150 Mbps
  • -66 dBm (300 Mbps)
Antenna Connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form Factor
PCI-Express Half-MiniCard
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
TBD
Operating Voltage
3.3v +/- 9%
Temperature
  • Operating: -10° to 70° C (14° to 158° F)
  • Non-operating: -40° to 80° C (-40° to 176° F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED Activity
  • LED Off - Radio OFF
  • Solid LED On - Radio ON
1 Check latest software/driver release for updates on supported security features.
2 Maximum output power may vary by country according to local regulations.
3 In Power Save Polling mode and on battery power.
4 Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
5 WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista.
HP Integrated Module with Bluetooth 4.0+EDR Wireless Technology
Specification
Bluetooth Specification
4.0+EDR Compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency Band
2402 to 2480 MHz
Number of Available Channels
79 (1 MHz) available channels
Data Rates and Throughput
  • 3 Mbps data rate; throughput up to 2.17 Mbps
  • Synchronous Connection Oriented links up to 3, 64 kbps, voice channels
  • Asynchronous Connection Less links 2178.1 kbps/177.1 kbps asymmetric or 1306.9 kbps symmetric
Transmit Power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Receiver Sensitivity:
Better than -20 dBM at 0.1 % raw bit error rate
Power Consumption
  • Peak (Tx) 264 mW
  • Peak (Rx) 231 mW
  • Sleep <1 mW
Antenna
Internally integrated within module
Range
Up to 10 m (33 ft)
Electrical Interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth Software Supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link Topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power Management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth Profiles Supported
  • Serial Port Profile (SPP)1
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)12
  • Generic Object Exchange Profile (GOEP)12
  • Object Push Profile (OPP)12
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)12
  • Personal Area Networking Profile (PAN)12
  • Human Interface Device Profile (HID)12
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)2
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
1 Indicates the profile is supported by Microsoft Windows XP SP2
2 Indicates the profile is part of Windows Vista
* Wireless access point and internet service required. Availability of public wireless access points limited.
** Wifi + Bluetooth combo is an optional feature.
Intel Dual Band Wireless- AC 7260 802.11 ac (2x2) WiFi + BT 4.0 combo Adapter*, **
Specification
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11ac
Interoperability
Wi-Fi certified
Frequency Band
  • 802.11b/g/n
    • 2.402 - 2.482 GHz
  • 802.11a/n
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
    • 2.402 - 2.482 GHz
Data Rates
  • 802.11n: MCS 0 ~ MCS 15, (20MHz, and 40MHz)
  • 802.11ac : MCS0 ~ MCS9, (1SS, and 2SS) (20MHz, 40MHz, and 80MHz)
Modulation
  • BPSK, QPSK, CCK, 16-QAM, 64-QAM, 256-QAM
Security1
  • IEEE 802.11i
  • Cisco Certified Extensions, all versions through CCX4 and CCX Lite
  • WAPI
  • FIPS 140-2
Network Architecture Models:
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output Power2
Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas >20cm from the user and peak gain of +3dBi at 2.4GHz and +4dBi at 5GHz
Power Consumption
  • Transmit: 2.0 W (max)
  • Receive: 1.6 W (max)
  • Idle mode (PSP): 250 mW (WLAN Associated)
  • Radio disabled: 75 mW
Power Management
Receiver Sensitivity3
802.11b:
  • -95 dBm (1 Mbps)
  • -93 dBm (2 Mbps)
  • -88 dBm (11 Mbps)
802.11a/g:
  • -90 dBm (6 Mbps)
  • -89 dBm (9 Mbps)
  • -87 dBm (12 Mbps)
  • -85 dBm (18 Mbps)
  • -82 dBm (24 Mbps)
  • -79 dBm (36 Mbps)
  • -76 dBm (48 Mbps)
  • -74 dBm (54 Mbps)
802.11n:
  • -69 dBm (72.2 Mbps)
Antenna type
High efficiency antenna with spatial diversity, mounted in the display enclosure.
Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications and Bluetooth communications.
Form Factor
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
3.1g
Operating Voltage
Humidity
Altitude
LED Activity
3 Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CKK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
V4.0 High Speed, V2.1+EDR, backwards compatible with V1.1, 1.2 and 2.0
Specification
Transmit Power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power Consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep < 17 mW
Antenna
Range:
Up to 10 m (33 ft)
  • USB 2.0 compliant
Link Topology
Security
Power Management
Self-configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
  • Generic Access Profile (GAP)
  • Dial_Up Networking Profile (DUN)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Printing Profile (BPP)
  • VDP (Video Distribution Profile)
  • AVRCP (Audio Video Remote Control Profile)
*Wireless access point and internet service required. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it may affect the ability of the notebook to communicate with other 802.11ac WLAN devices
**Bluetooth sold separately or as an optional feature.
Audio/Multimedia - DTS sound
Implementation: Realtek ALC3227-CG
Function key volume controls: Volume up, volume down, and mute
Full duplex: Yes
Microphone in: Stereo
Headphone/line out: Stereo
Integrated microphone: Yes, dual digital microphone array
Audio output quality
Frequency response: 10 Hz – .454*Fs
Signal to noise ratio: 95 dB (DAC), 88dB (ADC)
Total harmonic distortion: 0.01%
Play/Record sampling rate(s): 44.1k/48k/96k/192kHz
DAC: 16, 20 or 24-bit
ADC: 16, 20 or 24-bit
Internal stereo speakers
Power rating: 2 W
Impedance: 4 ohms
Power
HP 45W Smart AC Adapter
Dimensions
9.6 x 4.95 x 2.24 cm (3.78 x 1.95 x 0.88 in)
Input
90 to 265 VAC
Input Efficiency: 87% min at 115 VAC
Input frequency range: 47 to 63 Hz
Input AC current: 1.4 A at 90 VAC and maximum load
Output
Output power: 45W
DC output: 19.5V
Hold-up time: 5 msec at 115 VAC input
Output current limit: <8A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
Operating temperature :0° to 35° C (32° to 95° F)
Non-operating (storage) temperature: -20° to 85° C (-4° to 121° F)
Altitude: 0 to 5,000 m (0 to 16,405 ft)
Humidity: 0% to 95%
Storage Humidity: 0% to 95%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within the first three years of operation.
HP 65W EM Smart AC Adapter
Dimensions
126.0 x 50.0 x 30.0 mm
300 g
Input
90 to 265 VAC
Input AC current: 1.7 A at 90 VAC
Output
Output power: 65W
DC output: 19.5V
Output current limit: <11A, Over voltage protection- 29V max automatic shutdown
Connector
Altitude: 0 to 3,048 m (0 to 10,000 ft)
Humidity: 0% to 95%
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
HP 4-cell Lithium-Ion Long Life Battery (52 WHr)
Dimensions
0.8 x 13.3 x 20.7cm (0.31 x 5.25 x 8.15 in)
Weight (max)
0.335kg (0.74 lb)
Cells/Type
4-cell Lithium-Ion
Energy
  • Voltage: 14.8V
  • Amp-hour capacity: 3.515Ah
  • Watt-hour capacity: 52Wh
Temperature
  • Operating (Charging): 0° to 45° C (32° to 113° F)
  • Operating (Discharging): -10° to 50° C (14° to 122° F)
  • Non-operating: -20° to 50° C (-4° to 122° F)
Battery Re-Charge Time
  • System in OFF or Standby Mode: 2.5 hours
  • System ON: 3 to 5 hours
Fuel Gauge LED
No
Optional Travel Battery Available
No
HP 6-cell Lithium-Ion Long Life Slice Battery (60 WHr)
Dimensions
0.7 x 32 x 21.3 cm (0.28 x 12.6 x 8.39 in)
Weight (max)
0.78 kg (1.72 lb)
Cells/Type
6-cell Lithium-Ion
Energy
  • Voltage: 11.4V
  • Amp-hour capacity: 5.4Ah
  • Watt-hour capacity: 60Wh
Temperature
  • System in OFF or Standby Mode: 3.5 to 5 hours
  • System ON: 4 to 7 hours
Fuel Gauge LED
No
No
Material usage
This product does not contain any of the following substances in excess of regulatory limits (for reference of these limits please refer to the HP General Specification of the Environment (http://www.hp.com/hpinfo/globalcitizenship/environment/supplychain/gen_specifications.html):
  • Asbestos
  • Certain Azo Colorants
  • Certain Brominated Flame Retardants - may not be used as flame retardants in plastics
  • Cadmium
  • Chlorinated Hydrocarbons
  • Chlorinated Paraffins
  • Formaldehyde
  • Halogenated Diphenyl Methanes
  • Lead carbonates and sulfates
  • Lead and Lead compounds
  • Mercuric Oxide Batteries
  • Ozone Depleting Substances
  • Polybrominated Biphenyls (PBBs)
  • Polybrominated Biphenyl Ethers (PBBEs)
  • Polybrominated Biphenyl Oxides (PBBOs)
  • Polychlorinated Biphenyl (PCB)
  • Polychlorinated Terphenyls (PCT)
  • Polyvinyl Chloride (PVC) - except for wires and cables, and certain retail packaging has been voluntarily removed from most applications.
  • Radioactive Substances
  • Tributyl Tin (TBT), Triphenyl Tin (TPT), Tributyl Tin Oxide (TBTO)
  • Nickel finishes that release greater than 0.5 μgrams/cm2/week, measured according to EN 1811:1998, are not used on any product surface designed to be frequently handled or touched by users.
Country: Flag Thailand
