    Fix HP Printer issue on macOS
HP LaserJet P3015 - Product specifications
Product dimensions
Product dimensions, with toner cartridge
Height
Depth
Width
P3015
316 mm
412 mm
448 mm
17.6 kg
P3015d
316 mm
412 mm
448 mm
17.6 kg
P3015n
316 mm
412 mm
448 mm
17.6 kg
P3015dn
316 mm
412 mm
448 mm
17.6 kg
P3015x
456 mm
412 mm
448 mm
22.8 kg
Product dimensions with all doors, trays, and document feeder fully opened
Height
Depth
Width
P3015
347 mm
1040 mm
448 mm
P3015d
347 mm
1040 mm
448 mm
P3015n
347 mm
1040 mm
448 mm
P3015dn
347 mm
1040 mm
448 mm
P3015x
487 mm
1040 mm
448 mm
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1, 2, 3
Product Series4
Printing
Ready
Sleep
Off
HP LaserJet P3015
780 W
14.5 W
8.5 W
0.6 W
1Values subject to change.
2Power reported is highest value measured for all product models using standard voltages.
3Default time from Ready mode to Sleep = 30 minutes
4Speed is 40 ppm A4 size and 42 ppm Letter-size.
Electrical specifications
110-volt input voltage: 100 to 127 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz), 8.6 A
220-volt input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz), 4.2 A
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Acoustic emissions
HP LaserJet P30151
Sound power level
Printing (42 ppm)
Ready
Declared per ISO 9296
LWAd = 6.8 Bels (A) [68 dB(A)]
Inaudible
Sound pressure level - Bystander position
Printing (42 ppm)
Ready
LpAm = 54 dB(A)
Inaudible
1Acoustic values are subject to change. Configuration tested: HP LaserJet P3015dn, printing on A4-size paper at 40 ppm in simplex mode.
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
17.5° to 25°C
-20° to 60°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 90% RH
