HP LaserJet M5025/M5035 MFP - Product specifications
Product dimensions
Product dimensions, with toner cartridge
Height
Depth
Width
M5025
775 mm
584 mm
597 mm
55 kg
M5035
775 mm
584 mm
597 mm
55 kg
M5035x
1035 mm
762 mm
737 mm
93 kg
M5035xs
1194 mm
762 mm
737 mm
97 kg
Product dimensions with all doors, trays, and document feeder fully opened
Height
Depth
Width
M5025
1080 mm
991 mm
1016 mm
M5035
1080 mm
991 mm
1016 mm
M5035x
1340 mm
1067 mm
1016 mm
M5035xs
1499 mm
1067 mm
1016 mm
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1, 2, 3
Product Series4
Printing
Ready
Sleep
Off
600 W
80 W
21 W
0.2 W
1Values subject to change.
2Power reported is highest value measured for all product models using standard voltages.
3Default time from Ready mode to Sleep = 30 minutes
4HP LaserJet M5025 MFP: Speed is 25 ppm A4 size and 25 ppm Letter-size. HP LaserJet M5035 MFP: Speed is 35 ppm A4 size and 35 ppm Letter-size.
Electrical specifications
110-volt input voltage: 100 to 127 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz), 8 A
220-volt input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz), 4.5 A
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Acoustic emissions
HP LaserJet M5025/M5035 MFP1
Sound power level
Printing
Copying
Ready
Declared per ISO 9296
LWAd = 6.6 Bels (A) [66 dB(A)]
LWAd = 7.1 Bels (A) [71 dB(A)]
Inaudible
Sound pressure level - Bystander position
Printing
Copying
Ready
LpAm = 54 dB(A)
LpAm = 56 dB(A)
Inaudible
1Acoustic values are subject to change. Configuration tested:HP LaserJet M5035 MFP printing on A4-size paper at 35 ppm in simplex mode.
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
17° to 25°C
15° to 32.5°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
Altitude
Not applicable
0 to 3048 m
