Document ID: c04391090
Version: 1
Advisory: HP T510 Flexible Thin Client - Internet Explorer Displays Error: "Internet Explorer Has Stopped Working" When Attempting to Play a Flash Video
Release date : 31-Jul-2014
Last updated : 05-Apr-2018
DESCRIPTION
Internet Explorer 10 displays the following message when attempting to play a flash video:
Internet Explorer has stopped working
The issue occurs if the Adobe Flash player plug-in is not present and the IE attempts to play the video using the HTML 5 media element.
SCOPE
Systems:
  • HP t510 Flexible Thin Client
  • HP t510 Flexible Thin Client (ENERGY STAR)
Operating Systems:
  • Microsoft Windows Embedded Standard 7 (WES 7)
RESOLUTION
Internet Explorer 10 does not support flash media playback using the HTML 5 media element. Workaround the issue using one of the following options:
Option 1: re-enable the Adobe Flash Player plug-in (shockwave flash object)
  1. Open Intenet Explorer
  2. Click Tools (gear icon)
  3. Select Manage add-ons
  4. Click Toolbars and Extensions
  5. Select Shockwave Flash Object under Adobe Systems Incorporated
  6. Click Enable
  7. Click Close
Option 2: Use software rendering instead of GPU rendering:
  1. Open Internet Explorer
  3. Select Internet Options
  4. Click Advanced
  5. Select Use software rendering instead of GPU rendering*
  6. Click OK
  7. Restart the computer
NOTE: this option can have a performance impact as it shifts video rendering to the CPU
Option 3: downgrade the Thin Client image to an earlier version that has Internet Explorer 9
Use both of the following SoftPaqs to downgrade to the latest image version that includes Internet Explorer 9:
SoftPaq Description
Release Notes
Download SoftPaq
Microsoft Windows Embedded Standard 7E 8G-Flash Image (Part 1 of 2)
Version: 6.1.7601.290
Revision: A
SoftPaq Description
Release Notes
Download SoftPaq
Microsoft Windows Embedded Standard 7E 8G-Flash Image (Part 2 of 2)
Revision: A
Hardware platforms affected : HP t510 Flexible Thin Client, HP t510 Flexible Thin Client (ENERGY STAR) (deleted)
Support Communication Cross Reference ID : IA04391090
