Select HP LaserJet Enterprise printer models may encounter decreased hard drive reliability when the device has FutureSmart Firmware Bundle Version 3.2.0 installed.
- ${title}
- ${title}
- ${title}
- ${title}
HP LaserJet Enterprise - Firmware update required to ensure hard drive reliability
Issue
Solution
Check the firmware version that is currently installed and update the firmware if necessary.
To obtain the IP address and determine the version of firmware currently installed on the printer, print a configuration page.
From the Home screen on the printer control panel, scroll to and open the following menus:
Administration
Reports
Configuration/Status Pages
Select Configuration page and then select Print.
On the printed Configuration Page, look in the "Device Information" section for the Firmware Bundle Version similar to the following example:Figure : Configuration page, Device Information sectionIf the Firmware Bundle Version is 3.2 or 3.2.0, update the firmware to FutureSmart Bundle Version 3.2.3 or 3.2.5 or later (depending on the product).
To obtain the latest firmware, use the following chart to open the printer firmware page, find the file for Multiple Operating Systems, and then click Download.
HP recommends updating the firmware to FutureSmart Bundle Version 3.2.3 or 3.2.5 or later as soon as possible. If a firmware update cannot be performed immediately, HP recommends using the Workaround listed below as a temporary solution until the firmware can be updated.Affected HP LaserJet Enterprise seriesUpgrade Firmware to versionHP LaserJet Enterprise 500 M525HP LaserJet Enterprise 500 Flow M525cHP LaserJet Enterprise Color 500 M551HP LaserJet Enterprise 500 color M575 MFPHP LaserJet Enterprise 500 color Flow M575c MFPHP LaserJet Enterprise 600 M601HP LaserJet Enterprise 600 M602HP LaserJet Enterprise 600 M603HP LaserJet Enterprise 700 M712HP LaserJet Enterprise 700 MFP M725HP Color LaserJet Enterprise M750HP LaserJet Enterprise 700 color MFP M775HP LaserJet Enterprise 800 M806HP LaserJet Enterprise 800 Flow MFP M830HP Color LaserJet Enterprise M855HP Color LaserJet Enterprise Flow MFP M880
For detailed instructions on how to update the firmware, go to Update firmware using a USB flash drive or the Embedded Web Server (EWS) (c03847902) (in English).
Workaround
If a firmware update cannot be performed immediately, use the following workaround as a temporary solution until the firmware can be updated.
Open the Embedded Web Server (EWS).
Open a Web browser.
In the address field, type the printer IP address exactly as it appears on the Configuration Page, and then press Enter.Figure : Example of an IP address in a browser window
If you receive a warning about the website's security certificate, click Continue to this website (not recommended) (this will not impact the browser or PC).
Click the General tab.
In the left pane, click Energy settings.
Under Sleep Timer Settings, make sure the Wake/Auto On Events: option is set to All Events.If not, select All Events and then click Apply.Figure : Embedded Web Server, Energy Settings tab
Affected printers
The following HP LaserJet Enterprise models are affected:
HP LaserJet Enterprise 500 color M525
HP LaserJet Enterprise 500 color Flow M525c
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
