HP DL380z Gen8 Virtual Workstation - Specifications
Physical specifications
Dimensions (H x W x D)
SFF Drives: 8.73 x 44.55 x 69.85 cm (3.44 x 17.54 x 27.50 in)
Weight (approximate)
  • Maximum
    27.66 kg (61.00 lb)
  • Minimum (one SFF hard drive, power supply, and processor installed, ODD not installed)
    18.59 kg (41.0 lb)
Electrical specifications
Input requirements (per power supply)
  • Rated line voltage
    100 to 120 V ac
    200 to 240 V ac
  • Rated input current
    For 1200 W power supply:
    10 A (at 100 V ac)
    4.9 A (at 200 V ac)
  • Rated input frequency
    50 to 60 Hz
  • Rated input power
    930 W (at 100 V ac)
    1348 W (at 200 V ac)
BTU rating
Maximum (For 1200 W power supply)
3530 BTU/hr (at 100 V ac)
4600 BTU/hr (at 200 V ac)
Power supply output (per power supply)
Rated steady-state power / Maximum peak power (For 1200 W power supply)
800 W (at 100 V ac)
900 W (at 120 V ac)
1200 W (at 200 to 240 V ac)
Environmental specifications
System inlet temperature
  • Operating
    10° to 35°C (50° to 95°F) at sea level with an altitude derating of 1.0°C per every 304.8 m (1.8°F per every 1000 ft) above sea level to a maximum of 3048 m (10,000 ft), no direct sustained sunlight. Maximum rate of change is 10°C/hr (18°F/hr). The upper limit may be limited by the type and number of options installed.
    System performance may be reduced if operating with a fan fault or above 30°C (86°F).
  • Non-operating
    -30° to 60°C (-22° to 140°F). Maximum rate of change is 20°C/hr (36°F/hr).
Relative humidity (non-condensing)
  • Operating
    10% to 90% relative humidity (Rh), 28°C (82.4°F) maximum wet bulb temperature, non-condensing.
  • Non-operating
    5% to 95% relative humidity (Rh), 38.7°C (101.7°F) maximum wet bulb temperature, non-condensing.
Altitude
  • Operating
    3048 m (10,000 ft). This value may be limited by the type and number of options installed. Maximum allowable altitude change rate is 457 m/min (1500 ft/min).
  • Non-operating
    9144 m (30,000 ft). Maximum allowable altitude change rate is 457 m/min (1500 ft/min).
Acoustic noise
Listed are the declared A-Weighted sound power levels (LWAd) and declared average bystander position A-Weighted sound pressure levels (LpAm) when the product is operating in a 23°C ambient environment. Noise emissions were measured in accordance with ISO 7779 (ECMA 74) and declared in accordance with ISO 9296 (ECMA 109). The listed sound levels apply to standard shipping configurations. Additional options may result in increased sound levels.
Performance
Idle
Operating
LWAd
4.1 B
5.0 B
LpAm
25 dBA
35 dBA
Emissions classification (EMC)
Certifications
FCC rating
Class A
Normative standards
CISPR 22; EN55022; EN55024; FCC CFR 47, Pt 15; ICES-003; CNS13438; GB9254; K22;K24; EN 61000-3-2; EN 61000-3-3; EN 60950-1; IEC 60950-1
Product conformance to cited product specifications is based on sample (type) testing, evaluation, or assessment. This product or family of products is eligible to bear the appropriate compliance logos and statements.
HP Smart Array P420i controller specifications
Dimensions
Embedded
Disk Drive and Enclosure Interface - Transfer Rate
6Gb/s SAS (Serial Attached SCSI)
6Gb/s SATA (Serial ATA)
SAS connectors
2 internal 4X connectors
Cache memory speed
1GB or 2GB FBWC DDR3-1333MHz with 72-bit wide bus
System interface
x8 PCIe 3.0 provides 8GB/s maximum bandwidth
SAS speed
(8) 6Gb/s SAS links provide 4.8GB/s maximum bandwidth
Cache memory
Zero Memory RAID has no cache memory
72-bit 1GB ECC protected flash back write cache (FBWC) or 72-bit 2GB FBWC
Logical drives supported
Zero Memory, Up to 2 logical volumes (8SFF physical drives)
Up to 64 logical drives with cache
Host memory addressing
64-bit, supporting greater than 4GB system memory space
RAID support
  • RAID 6, 60 (Advanced Data Guarding)
  • RAID 5, 50 (Distributed Data Guarding)1
  • RAID 10 (Striping & Mirroring)
  • RAID 0 (Striping), RAID 1 (Mirroring)
1. A minimum of 512 MB cache is required to enable RAID 5, 50, 6, 60.
HP Smart Array Advanced Pack (SAAP 2.0) is no longer required to enable RAID 6 & 60 (Advanced Data Guarding). However, controller must be in firmware version 4.68 (or later).
HP Ethernet 1Gb 4-port 366FLR adapter specifications
HP flexible network technology
HP flexible network technology consists of replaceable network solutions to meet customer requirements now and in the future.
10Base-T/100Base-TX/1000Base-TX
Compatibility
  • IEEE 802.3
  • IEEE 802.3ab
  • IEEE 802.3u
  • IEEE 802.3x
  • IEEE 802.3ad
  • IEEE 802.1q
  • IEEE 802.3az
  • IEEE 802.1as
  • IEEE 1588
Data transfer method
PCI Express, four lanes (x4)
Intel Ethernet Controller I350
Network transfer rate
  • 10Base-T (Half-Duplex) - 10 Mb/s
  • 10Base-T (Full-Duplex) - 20 Mb/s
  • 100Base-TX (Half-Duplex) - 100 Mb/s
  • 100Base-TX (Full-Duplex) - 200 Mb/s
  • 1000Base-TX (Full-Duplex) - 2000 Mb/s
Connector
Four RJ-45
Cable support
  • 10Base-T
    Category 5e (CAT-5e) or better twisted-pair cabling; up to 328 ft (100 m)
  • 100Base-TX
  • Category 5e (CAT-5e) or better twisted-pair cabling; up to 328 ft (100 m)
  • 1000BaseTX
HP Ethernet 10Gb 2-port 560FLR-SFP+ adapter specifications
SFP+ for Direct Attach Cable copper or fiber
Compatibility
  • IEEE 802.3
  • IEEE 802.1ab
  • IEEE 802.3x
  • IEEE 802.3ad
  • IEEE 802.1p/802.1q
  • IEEE 802.3ae
  • IEEE 802.1Qau
PCI Express 2.0, eight lanes (x8)
Intel 82599 Controller (generation 10)
  • Full duplex - 20 Gb/s per port
  • Total aggregate - 40 Gb/s Full Duplex theoretical bandwidth
Connector
Two SFP+ cages allowing use of Direct Attach copper and SR fiber optic modules
Country: Flag Thailand
