    Windows 11 Upgrade Guide
Document ID: c04310193
Version: 1
HP ElitePad 900 G1 Tablet Notebook PCs - BIOS Error 259 Displayed During BIOS Update
Release date : 21-May-2014
Last updated : 21-May-2014
DESCRIPTION
The BIOS update stops and does not finish when using SP65916. The computer displays the following error:
BIOS error code=259
SCOPE
Computer:
  • HP ElitePad 900 G1 Tablet
RESOLUTION
The Driver Access Service Layer (DASL) needs to be installed manually before installing SoftPaq SP65916. Complete the following procedure to resolve this issue:
  1. Download the DASL below:
    SoftPaq Description
    Release Notes
    Download SoftPaq
    HP Driver Access Service Layer (DASL) Application
    Version: 6.2.10.1
    Revision: A
    A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
  2. Download the following SoftPaq:
    SoftPaq Description
    Release Notes
    Download SoftPaq
    HP Elitepad 900 System BIOS/Firmware and Driver Update
    Version: 1.0.1.7
    Revision: A
  3. Navigate to the SoftPaq SP65916 folder location, then extract the contents into a new folder.
  4. Open the SoftPaq SP65916 folder, then double-click C:\SWSETUP\SP65916\DASL\setup.exe.
  5. Restart the computer, then open the new folder with SoftPaq SP65916's contents, then double-click C:\SWSETUP\SP65916\FDSetup.exe to complete the update.
Hardware platforms affected : HP ElitePad 900 G1 Tablet, HP MX10 Retail Solution with Retail Jacket
Support Communication Cross Reference ID : IA04310193
