Specification
Chassis (W x D x
H)
337 x 100 x 380.5 mm
(13.26 x 3.93 x 14.98 in)
System volume
12.82 L
System weight
5.905 kg (13.01 lb)
Max supported weight
(desktop orientation)
35 kg
Tower stand
(H x W x D)
27.5 x 178.2 x 199 mm
(1.08 x 7.01 x 7.83 in)
Packaged (H x W x D)
528 x 229 x 499 mm
(20.78 x 9.01 x 19.64 in)
Shipping weight
Estimated = 9.691 kg
21.365lb
Palletization profile
SEA
AIR
- ${title}
- ${title}
- ${title}
- ${title}
HP ProDesk 480 G1 Microtower PC - Specifications
Physical specifications
Power specifications
Specification
High efficiency
240 W active PFC
High efficiency
80 PLUS bronze
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50/60 Hz
Operating line frequency range
47 - 63 Hz
Rated input current
4A
Rated input current with energy efficient
power supply
4A
Current leakage
(NFPA 99)
< 275 μA @ 120 V
Power supply fan
70 mm Fan
Power cord length
6.0 ft (1.83 m)
Graphics specifications
Specification
Form factor
Full height
Graphics controller
AMD radeon HD 8470
Core clock
775 MHz
Memory clock
900 MHz
Memory
2GB, DDR3, 64-bit wide
Bus type
PCIe Gen2
Maximum power
< 30 W
Power source support
12 V and 3.3 V
3D API support
DX11
HDCP support
yes
Display maximum resolution
Supported graphics APIs
DX11, OpenGL, full 1080p BD (H264) playback in hardware, HDMI 1.4 support
note: |
Specification
Form factor
Low Profile: 2.713 × 6.15 in
Graphics controller
NVIDIA NVS 310
Memory clock
875 MHz
Memory size
512MB DDR3
Memory bandwidth
14GB/s
Maximum power
19.5 W
Up to 2560 x 1600 (digital display) per display
Display output
Up to 2 displays in the following configurations
note: |
Specification
Form factor
Graphics controller
NVIDIA NVS 315
Memory clock
875 MHz
Memory size
512MB DDR3
Memory bandwidth
14GB/s
Connectors
DMS-59 , with support for dual VGA, dual DVI or dual Display Port with the appropriate
adapter cable
Up to 2048 x 1536 VGA; 1920 x 1200 DVI; 2560 x 1600 DisplayPort
Display output
note: |
Specification
Form factor
PCIe x16 Card
Graphics controller
NVIDIA Kepler architecture GPU
Core clock
875 MHz
Memory clock
891 MHz
Memory size
2GB DDR3 128 bit
Memory bandwidth
28.5GB/s
2560 x 1600 digital, 2048 x 1536 analog
Display support
Integrated 400 MHz RAMDAC
note: |
Specification
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8350
Core clock
GPU engine operates at 523 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
875 MHz
HDCP support
Yes
note: |
Specification
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8490
Core clock
GPU engine operates at 875 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
900 MHz
HDCP support
Yes
note: |
Memory specifications
Specification
System memory support
Platform memory support
The Small Form Factor (SFF) and Microtower (MT) platforms support up to four (4) industry-standard DDR3-SDRAM
DIMMs.
High definition audio specifications
Specification
Type
Integrated
HD stereo codec
Realtek 2-channel ALC221 codec
Audio I/O ports
Internal speaker amplifier
1.5 W amplifier for the internal speaker only. External speakers must be powered externally.
Rear Line-in audio port is re-taskable as either Line-in or Microphone-In.
Multi-streaming capable
Multi-streaming can be enabled in the Realtek control panel to allow independent audio
streams to be sent to/from the front and rear jacks.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes – Uses OS soft wavetable
Analog audio
Yes
Number of channels on line-Out
Stereo (Left & Right channels)
Internal speaker
Yes
External speaker jack
Yes
Full duplex
Yes
Hard disk and solid state storage specifications
Specification
Capacity
500,107,862,016 bytes
Rotational speed
7,200 rpm
Interface
Serial ATA 2.0 (6.0 Gb/s)
Buffer size
16MB
Logical blocks
976,773,168
Seek time (typical reads)
Single track:
2.0 ms
Average:
12 ms
Full-Stroke
25 ms
Height (nominal)
0.374 in/9.5 mm
Media diameter: 2.5 in/63.5
Width (nominal)
mm
Physical size: 2.75 in/70 mm
Operating temperature
5° to 55°C (41° to 131° F)
Specification
Formatted capacity
1TB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Solid State Hybrid Drive (SSHD) technology with NAND flash
Interface
Serial ATA (SATA)
Cache buffer
64MB
NAND flash
Commercial Multilevel Cell (cMLC)
8GB
Number of sectors
976,773,168
Single track:
2.0 ms
Average:
12 ms
Height
0.374 +/-.008 in (9.5 +/- 0.2 mm)
Width
2.750 +/- 0.010 in (69.85 +/- 0.25 mm)
Length
3.951 +0.008 / -0.010 in (100.35 +0.20 / -0.25 mm)
0.254 lb/115 g (max))
0° to 60°C (32° to 140°F)
Specification
Capacity
Rotational speed
7,200 rpm
Interface
Serial ATA 3.0 (6.0 Gb/s)
Buffer size
16MB
Logical blocks
976,773,168
Seek time (typical reads,
includes controller overhead,
including settling)
Single track:
2.0 ms
Average:
11 ms
Full-Stroke:
21 ms
Height (nominal)
1 in/2.54 cm
Width (nominal)
Media diameter:
3.5 in/8.89
cm
Physical size:
4 in/10.2 cm
5° to 55° C (41° to 131° F)
Specification
Unformatted capacity
128GB
Architecture
Multi Level Cell (MLC) NAND
Interface
SATA 6 GB/sec
Dimensions (W x H x D)
6.985 x 0.7 x 10.05 cm ( 2.75 x 0.276 x 3.96 in)
0.16 lb (73 g)
Bandwidth performance
Sustained sequential read:
Up to 450 MB/ss
Sustained sequential write:
Up to 260 MB/s
Random read (4KB):
up to 46K IOPs
Random write (4KB):
up to 56K IOPs
Latency
Read:
55ms (TYP)
Write:
55ms (TYP)
Power
DC power requirement:
Min 4.5 V; Max 5.5 V
Total power consumption:
160 mW (Active) ;< 85 mW; (Idle)
Useful drive life
1.2 million device hrs
Environmental
(all conditions, non-condensing)
Operating temperature:
0° to 70°C (32° to 158°F)
Relative humidity:
5% to 95%
Shock:
1,500 G/1.0 msec
Specification
256,186,209,271 bytes
Architecture
Self-Encrypting (SED) Solid State Drive with 25nm MLC NAND Flash and SATA interface
Interface
Serial ATA 2.0 (3.0 Gb/s)
NAND flash
25nm MLC NAND flash
Height
.275 in/7 mm
Width
2.75 in/69.85 mm
Length
3.95 in/100.5 mm
0.161 lb (73 g)
Sustained sequential 128k
read:
Up to 450 MB/ss
write:
Up to 260 MB/s
Random 4k read:
up to 46K IOPs
Random 4k write:
up to 56K IOPs
Latency
Read:
55 μs
Write:
55 μs
Power
SATA power consumption:
160 mW (active average); < 85 mW (idle average)
Useful drive life
72TB written, up to 40GB/day for 5 years
Environmental
(all conditions, noncondensing)
0° to 70° C (32° to 158° F)
Relative humidity:
5% to 95%
Shock:
1,500 G/1 ms
Specification
Formatted capacity
500GB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Solid State Hybrid Drive (SSHD) technology with NAND Flash
Interface
Serial ATA (SATA)
Cache buffer
64MB
NAND Flash Commercial
8GB
Number of sectors
976,773,168
Single track:
2.0 ms
Average:
12 ms
Height
0.268 +/-.008 in (6.8 +/- 0.2 mm)
Width
Length
0.209 lb/95 g (max)
0° to 60° C ( 32° to 140° F )
Specification
Capacity
1,000,204,886,016 bytes
Rotational speed
7,200 rpm
Interface
Buffer size
32MB
Logical blocks
1,953,525,168
Seek Time (typical reads,
including settling)
Single track:
2.0 ms
Average:
11 ms
Full-Stroke:
21 ms
Height (nominal)
1 in/2.54 cm
Width (nominal)
Media diameter:
3.5 in/8.89
cm
Physical size:
4 in/10.2 cm
Specification
2TB
Rotational speed
7,200 rpm
Interface
SATA 6Gb/s NCQ
Cache, Multisegmented (MB)
64MB
Seek time (average)
Read
< 8.5 ms
Write
< 9.5 ms
Height
1.028 in/26.11 mm
Width
4.0 in/101.6 mm
Depth
5.787 in/146.99 mm
1.38 lb/626 g
0° to 60° C (32° to 140° F)
Removable storage specifications
Specification
Height
12.7 mm height
Orientation
Either horizontal or vertical
Interface type
SATA/ATAPI
Disc recording capacity
Up to 8.5 GB DL or 4.7 GB standard
5.04 x 0.5 x 5.0 in (128 x 12.7 x 127 mm) without bezel
Weight (maximum)
0.42 lb (190 g)
Specification
Height
12.7 mm Slim tray-load
Orientation
Interface type
SATA/ATAPI
Disc capacity
Up to 128GB QL, 100 GB TL, 50 GB DL or 25 GB standard SL
Dimensions
W x H x D (maximum)
Weight (maximum)
Up to 0.37 lb (170 g) without bezel
Specification
Height
12.7mm
Orientation
Interface type
SATA/ATAPI
Weight (maximum)
Specification
Height
5.25-inch, half-height, tray-load
Orientation
Interface type
SATA
Disc capacity
Blu-ray: 128GB QL, 100GB TL, 50 GB DL or 25 GB standard
DVD: 8.5GB DL or 4.7GB standard
Dimensions
W x H x D (maximum)
5.8 x 1.7 x 7.1 in (14.8 x 4.2 x 18.0 cm) maximum
Weight (maximum)
2.1 lb (950 g)
Specification
Height
Orientation
Interface type
SATA
Dimensions
W x H x D (maximum)
5.8 x 1.7 x 6.9 in (14.8 x 4.2 x 17.5 cm) maximum
Weight (maximum)
2.1 lb (950 g)
Specification
Height
Orientation
Interface type
SATA
Dimensions
W x H x D (maximum)
Weight (maximum)
2.1 lb (950g)
Networking and communications specifications
Specification
Connector
RJ-45
System interface
Integrated on PCA
Controller
Realtek RTL8151GH-CG Gigabit Ethernet Controller
Memory
16 KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mb/s
IEEE compliance
Bus architecture
PCI express
Data transfer mode
PCIe-based interface for active state operation (S0 state)
Power requirement
Requires 3.3 V and 1 V or just 3.3 V with integrated regulators
power consumption 0.425 W
Network transfer mode
Network transfer rate
Environmental
Management
WOL, auto MDI crossover, PXE, Muti-port teaming, Advanced cable diagnostic
Specification
Connector
RJ-45
System interface
PCI express x1
Controller
Intel I210 Gigabit ethernet controller
Memory
Integrated dual 48K configurable transmit receive FIFO Buffers
10/100/1000 Mb/s
IEEE compliance
Bus architecture
PCI-E 2.1
Data path width
X1, 250 MB/s, Bi-directional interface
Data transfer mode
Bus-master DMA
Hardware certifications
Full-duplex
FCC, B, CE, TUV-c, TUVus Mark Canada and United States, TUV-GS Mark for European
Union
Power requirement
Aux 3.3 V, 3.0 W in 1000 base-T and 1.0 W in 100 base-T
Boot ROM support
Environmental
Management
WOL, PXE, DMI, WFM 2.0
Specification
Wireless LAN standards
IEEE 802.11a/b/g/n
Interoperability
Frequency band
802.11b/g/n:
802.11a/n:
Antenna structure
2 transmit; 2 receive (2x2)
Data rates
Modulation
Security
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Network architecture models
Roaming
Output power
Power consumption
Power management
Power management
Receiver sensitivity
Antenna connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form factors
PCI-Express Half-MiniCard
0.0068 lb (3.1 g)
Dimensions
0.12 x 1.06 x 1.18 in (3.1 x 26.8 x 30.0 mm)
Operating voltage
3.3V +/- 9%
Operating:
Temperature
-10° to 70°C (14° to 158°F)
Humidity
10% to 90% (non-condensing)
Non-operating:
Temperature
-40° to 80°C (-40° to 176°F)
Humidity
5% to 90% (non-condensing)
LED Activity
LED Amber - Radio Off; LED White - Radio On
Environmental specifications
Operating:
Temperature range
10° to 35°C (50° to 95°F)
Relative humidity
10-90% (non-condensing at ambient)
Maximum altitude (unpressurized)
3048 m (10,000 ft)
Non-operating:
Temperature range
-30° to 60°C (-22° to 140°F)
Relative humidity
5% to 95% (non-condensing at ambient)
9144 m (30,000 ft)
Link to product overview information
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
