    Apache Log4j Update
HP Officejet Enterprise Color X555, MFP X585 - Replace the output flap
This document provides the procedure to replace the output flap for the HP Officejet Enterprise Color X555 and HP Officejet Enterprise Color MFP X585/X585 Flow.
Figure : Output bin flap
  1. Turn off the product, and then disconnect the power cable.
    Figure : Turn off product, disconnect power cable
  2. Remove the output bin by pulling up on the edge of the bin closest to the output flap, tilting it away from the product, and then pulling the assembly up.
    Figure : Remove the output bin
  3. Remove the output bin flap by flexing the middle of the output bin flap, pulling the rear side pin out, and then sliding the flap toward the rear to disconnect the front side pin.
    Figure : Remove the flap
  4. Remove the new flap from its packaging, and then reuse the packaging to send the old flap to a recycling center.
    Figure : Unpackage the new flap and recycle the old one
  5. Install the new output bin flap by inserting the front side pin into its slot, and then flexing the middle of the flap in order to insert the rear side pin into its slot.
    Figure : Install the flap
  6. Reinstall the output bin.
    Figure : Install the output bin
  7. Reconnect the power cable, and then press the power button to turn on the product.
    Figure : Reconnect the power cable, turn on the product
