    Apache Log4j Update
HP Officejet Enterprise Color X555, MFP X585 - Install the ink-collection unit
This document provides the procedure to install the ink-collection unit and duplex module for the HP Officejet Enterprise Color X555 and HP Officejet Enterprise Color MFP X585/X585 Flow.
Figure : Ink collection unit (ICU)
  1. Open the product left door.
    Figure : Open the left door
  2. Pull the ink collection unit (ICU) straight out to remove it from the product.
    Figure : Remove the ICU
  3. Remove the new ICU from its packaging.
    Figure : Remove the replacement ICU from packaging
    Retain the packaging to use it to ship the old ICU to a recycling center.
  4. Install the new ICU by pushing it straight into the product.
    Figure : Install the new ICU
  5. Close the left door.
    Figure : Close the left door
  6. Use the packaging from the installed ICU to ship the old unit to a recycling center.
    Figure : Pack the old ICU for shipping
  7. For recycling information and to print a mailing label, go to www.hp.com/recycle, select the country/region from which the old ICU will be shipped and then click the Go button, and then click the HP ink and LaserJet toner cartridges link.
  8. Update the product to indicate that a new ICU has been installed.
    • If the New Ink Collection Unit screen displays on the product control panel, touch Yes to indicate that a new unit has been installed.
    • If the New Ink Collection Unit screen does not display on the product control panel, complete the following steps.
      1. Open the Administration menu, and then open the Manage Supplies menu.
      2. Touch the Reset Supplies menu, and then touch the New Ink Collection Unit item.
      3. Touch the Yes item to indicate that a new ICU has been installed.
