    Apache Log4j Update
HP Officejet Enterprise Color MFP X585/X585 Flow - Product specifications
Product dimensions
Physical specifications, with ink cartridges
Height
Depth
Width
X585dn
594 mm
545 mm
515 mm
34.8 kg
X585f
34.9 kg
X585z
35.3 kg
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1, 2, 3
Product Series4
Printing
Ready
Sleep
Auto On/ Auto Off
Off
67 W
34 W
9.0 W
1.7 W
0.35 W
1Values subject to change.
2Power reported is highest value measured for all product models using standard voltages.
3Default time from Ready mode to Sleep = 60 minutes
4Speed is 42 ppm A4 size and 42 ppm Letter-size.
Electrical specifications
110-volt input voltage: 100 to 127 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz), 3 A
220-volt input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz), 3 A
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Acoustic emissions
HP Officejet Enterprise Color MFP X5851
Sound power level
Printing (43 ppm)
Copying (43 ppm)
Declared per ISO 9296
LWAd = 6.7 Bels (A) [67 dB(A)]
LWAd = 7.1 Bels (A) [71 dB(A)]
Sound pressure level - Operator position
Printing
LpAm = 53 dB(A)
1Acoustic values are subject to change.
Operating environment specifications
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
15° to 30°C
15° to 30°C
Relative humidity
20% to 60% relative humidity (RH)
20% to 80% RH
Altitude
Not applicable
0 to 2,400 m
