Document ID: c04230512
Version: 1
HP ZBook 15-Inch Mobile Workstation Notebook PCs - Computer Does Not Install Intel PROSet Bluetooth Driver
Release date : 07-Apr-2014
Last updated : 07-Apr-2014
DESCRIPTION
The computer may display the following symptoms after attempting to install the Intel PROSet Bluetooth driver (SoftPaq 61660):
  • The Intel PROSet Bluetooth driver (SP61660) does not install.
  • Device Manager may display a "Generic Bluetooth Adapter" instead of the appropriate Bluetooth driver.
  • The Intel Bluetooth Driver (International) (SP63222) does not install after installing SP61660.
  • The driver cannot be manually loaded from Device Manager.
SCOPE
Computers:
  • HP ZBook 15-inch Mobile Workstation
Operating Systems:
  • Microsoft Windows 7 Enterprise (64-bit)
Bluetooth Modules:
  • 7260
  • 6235
RESOLUTION
The incorrect SoftPaq was installed. SoftPaq 61660 is not compatible with the 7260 Bluetooth adapter and SoftPaq 63222 is not compatible with the 6235 Bluetooth adapter.
To resolve this issue, uninstall the current Intel(R) PROset/Wireless Software for Bluetooth(R) Technology through Programs and Features, then download and install the appropriate SoftPaq to resolve this issue:
Affected Bluetooth Adapter
Affected Bluetooth Module
SoftPaq Description
Release Notes
Download SoftPaq
7260 Adapter
Intel Centrino Wireless Bluetooth 3.0 + High Speed Adapter
Version: 3.1
Revision: D
6235 Adapter
Intel Centrino Wireless Bluetooth 3.0 + High Speed Adaptor
Intel Centrino Wireless Bluetooth 4.0 + High Speed Adaptor
Version: 2.6
Revision: D
A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
Hardware platforms affected : HP ZBook 15 Mobile Workstation
Operating systems affected : Microsoft Windows 7 Enterprise (64-bit) (deleted)
Support Communication Cross Reference ID : IA04230512
