Document ID: c04210573
Version: 1
HP ZBook 15inch Mobile Workstation Notebook PCs - Computer Displays 1.3GB of Physical Memory When 4GB RAM Installed on Microsoft Windows 32-Bit Computer
Release date : 20-Mar-2014
Last updated : 24-Mar-2014
DESCRIPTION
The computer displays only 1.3Gb of available memory despite having 4Gb of RAM installed. This only occurs on a computer with a Microsoft Windows 32bit operating system. The computer will display 3.65Gb of available memory on a 64-bit Microsoft Windows operating system.
SCOPE
Computer:
  • HP ZBook 15-inch Mobile Workstation
Operating Systems:
  • Microsoft Windows 7 Enterprise (32-bit)
  • Microsoft Windows 7 Ultimate (32-bit)
  • Microsoft Windows 7 Professional (32-bit)
RESOLUTION
The computer is configured with a switchable graphics card and also supports Thunderbolt. The memory difference occurs because memory is allocated for these two system configurations as well reserved for Microsoft LOGO certificate.
While Thunderbolt can be disabled, HP does not recommend this as it could impact system performance. To disable Thunderbolt, complete the following procedure:
  1. Power off the computer.
  2. Power on the computer and immediately press F10 to enter BIOS.
  3. Select Advanced.
  4. Select Port Options.
  5. Under Thunderbolt port, select Display Port Only.
  6. Press Esc, then Save and Exit.
Hardware platforms affected : HP ZBook 15 Mobile Workstation
Operating systems affected : Microsoft Windows 7 Enterprise (32-bit) (deleted) Microsoft Windows 7 Professional (32-bit) (deleted) Microsoft Windows 7 Ultimate (32-bit) (deleted)
Support Communication Cross Reference ID : IA04210573
