    Fix HP Printer issue on macOS
HP OfficeJet Enterprise Color X555, MFP X585 - 15.A0 jam error in optional tray 3
Use the information in this document to clear a paper jam in tray 3. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 15.A0.03
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in tray 3:
  1. Open Tray 3 and pull it straight out to remove it from the printer.
    Figure : Open the tray
  2. Reach inside the opening of Tray 3 and remove the sheet by pulling it to the right and then out of the printer.
    Figure : Remove jammed paper from the opening of Tray 3
  3. If the jam cannot be cleared at the tray, try clearing the jam from the lower left door.
    Figure : Remove jammed paper from the lower left door
  4. Reinsert Tray 3 into the printer and then push it in to close the tray.
    When closing the tray, push in the middle, or with even pressure on both sides. Avoid pushing on one side only.
    Figure : Reinsert and close Tray 3
