    Fix HP Printer issue on macOS
HP OfficeJet Enterprise Color X555, MFP X585 - 15.A0 jam error in tray 2
Use the information in this document to clear a paper jam in tray 2. When a jam occurs, the control panel displays a message and an animation that assists in clearing the jam.
  • 15.A0.02
In addition to the instructions provided in this document, you can view the following video of how to clear a paper jam in tray 2:
  1. Open Tray 2 by pulling it out and releasing the latch at the rear left of the tray.
    Figure : Open the tray
  2. Remove the jammed sheet by pulling it to the right and then out of the printer.
    Figure : Remove the jammed paper
  3. Close Tray 2.
    To close the tray, push in the middle or with even pressure on both sides. Avoid pushing on one side only.
    Figure : Close the tray
