    We are upgrading our website
Document ID: c04202061
Version: 1
HP ZBook 15-inch and 17 G2 Mobile Workstations - Computer Does Not Display on Three External Monitors With HP 230W Advanced Docking Station
Release date : 17-Mar-2014
Last updated : 08-Sep-2015
DESCRIPTION
The computer only displays on two monitors when three monitors are connected to the docking station listed in the SCOPE.
SCOPE
Computers:
  • HP ZBook 15-inch Mobile Workstation
  • HP ZBook 17-inch G2 Mobile Workstation
Docking Stations:
  • HP 230W Advanced Docking Station
RESOLUTION
To display on three monitors, connect two of the monitors to DP ports on the docking station and one monitor to the mini DP port with a mini DP to DP adapter. No other configurations are compatible with the docking station.
Hardware platforms affected : HP 230W Advanced Docking Station, HP ZBook 15 Mobile Workstation, HP ZBook 17 Mobile Workstation
Support Communication Cross Reference ID : IA04202061
