Document ID: c04196633
Version: 1
HP EliteBook Folio 1040 G1 Notebook PCs - 90b Fan Error Upon Powering On the Computer
Release date : 12-Mar-2014
Last updated : 13-Mar-2014
DESCRIPTION
The screen displays the following 90b fan error when powering on the computer:
The system had detected that a cooling fan is not operating correctly.
Continued operation is not recommended and may cause unpredictable behavior that could result in random shutdown, data loss or possible system damage. The system will shutdown in 15 seconds. To prevent shutdown and continue operation, press the Enter key now.
System Fan (90B)
SCOPE
Computers:
  • HP EliteBook Folio 1040 G1 Notebook PC
RESOLUTION
Check the BIOS version installed on the computer before replacing any hardware. If the BIOS version is not 01.05, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
HP Notebook System BIOS Update
Version: 01.05
A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
If the issue persists with BIOS 01.05, falls within the SCOPE, and is within warranty, set up a service event.
Hardware platforms affected : HP EliteBook Folio 1040 G1 Notebook PC
Support Communication Cross Reference ID : IA04196633
