    Apache Log4j Update
HP Latex 3000 Printer Series - The printer seems slow
You may experience a temporary delay while the printer's drying and curing modules are warming up.
In some circumstances, the printer will deliberately print more slowly than usual to prevent the printheads from overheating. There are several possible reasons why a printhead may start to overheat:
  • The room temperature is too high.
  • The printhead is suffering from blocked nozzles (see Check and clean the printheadsCheck and clean the printheads).
  • The printhead is faulty and should be replaced.
