    We are upgrading our website
HP LaserJet Pro 400 M401 - Product specifications
Product dimensions
Product dimensions, with toner cartridge
Height
Depth
Width
M401n
267 mm
368 mm
364 mm
10 kg
M401dn
271 mm
368 mm
364 mm
11 kg
M401dw
271 mm
368 mm
364 mm
11 kg
Product dimensions with all doors, trays, and document feeder fully opened
Height
Depth
Width
M401n
308 mm
633 mm
364 mm
M401dn
383 mm
633 mm
364 mm
M401dw
383 mm
633 mm
364 mm
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Power consumption (average, in watts)1, 2, 3
Product Series4
Printing
Ready
Sleep
Off
570 W
7.3 W
6.2 W
0.1 W
1Values subject to change.
2Power reported is highest value measured for all product models using standard voltages.
3Default time from Ready mode to Sleep = 15 minutes
4Speed is 33 ppm A4 size and 35 ppm Letter-size.
Electrical specifications
110-volt input voltage: 100 to 127 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz)
220-volt input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz (+/- 2 Hz)
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Acoustic emissions
HP LaserJet Pro 400 M4011
Sound power level
Printing (33 ppm)
Ready
Declared per ISO 9296
LWAd = 6.4 Bels (A) [64 dB(A)]
Inaudible
Sound pressure level - Bystander position
Printing (33 ppm)
Ready
LpAm = 51 dB(A)
Inaudible
1Acoustic values are subject to change. Configuration tested: HP LaserJet Pro 400 M401dn, printing on A4-size paper at 33 ppm in simplex mode.
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
17° to 25°C
15° to 32.5°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
Altitude
Not applicable
0 to 3048 m
Country: Flag Thailand
