HP B421 42-inch LED Digital Signage Display - Specifications
Physical specifications
Dimensions (W x D X H)
  • Unpacked (head only): 98.04 x 3.85 x 57.29 cm (39.2 x 1.55 x 22.9 in)
  • Packaged: 107 x 14.8 x 72.7 cm (42.8 x 5.9 x 29.1 in)
Bezel Width
All four sides:19.7 mm (0.775 in)
  • Unpacked: 11.9 kg (26.23 lb)
  • Packaged: 15.3 kg (33.73 lb)
Tilt range
None
Swivel range
None
Height adjustable
None
Pivot rotation
None
Base
There is no stand.
Environmental specifications
Temperature
Operating
0° to 40°C (32° to 104°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%, 38.7°C max wet-bulb
Altitude
Operating
+0 to 2,000 m (0 to 6,561 ft)
Non-operating
0 to 5000 m (0 to 16,404 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-Free display glass
Yes
Low Halogen
Yes (everything except external cables)
Mercury free display backlighting
Yes
Applicable product safety standards specify thermal limits for plastic surfaces. The device operates well within this range of temperatures.
On Screen Display (OSD) controls
Buttons or Switches
Power/Input/Menu/Up, Down/+Plus, - Minus
Languages
English, German, French, Italian, Spanish, Russian, Polish, Turkish, Simplified Chinese
User controls
Brightness, Contrast, Color, Image Control, OSD Control, Language, Information, Factory Reset, Input Control, Audio Control
Signal interface/performance
Horizontal frequency
31.5 to 91.1 kHz
Vertical frequency
50 to 85 Hz
Recommended resolution
1920 x 1080 @ 60 Hz
Max resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 640 x 480 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 800 x 600 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1280 x1024 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1600 x 900 @ 60 Hz
  • 1680 x 1050 @ 60Hz
  • 1920 x 1080 @ 60 Hz
Maximum pixel clock speed
165 MHz
User programmable modes
N/A
Anti-Glare
Yes
Default Color Temperature Standard
10000K
Video/Other inputs
Plug and play
Yes
Input signal
VGA (RGB), DVI-D. HDMI (HDCP support on DVI and HDMI), YPbPr component video
Output
N/A
USB
(1) USB 2.0 input for playing multimedia files
LAN (RJ45)
(1) RJ45 Input for command and control and video over Ethernet
RS232
(1) input and (1) output
Audio
(1) 3.5-mm audio input; (2) RCA inputs L/R; (2) RCA outputs L/R; (1) S/PDIF output Speaker
Speaker
(2) 7-W integrated speakers
IR
(1) input and (1) output for receiving and sending the IR control signals
Video cables included
(1)VGA, (1) HDMI
Video cable lengths
1.8 m (5.9 ft )
Power specifications
Power supply
Internal
Input power
90 ~ 264 V ac
Frequency
47~63Hz
Typical power consumption
88 W
Maximum
104 W
Power saving
Sleep: 0.5 W
Power cable length
1.8 m (5.9 ft)
