HP Z1 G2 Workstation - Specifications
Physical specifications
Specification
Chassis dimensions (H x W x D)
  • Vertical display orientation with stand: 530.0 x 660.4 x 419.1 (20.8 x 26 x 16.5 in)
  • Standard display orientation without stand: 457.2 x 660.4 x 81.28 mm (18 x 26 x 3.2 in)
  • Service/Shipping orientation: 116 x 660 x 510 mm
Exact weights depend upon configuration; Max system weight with stand: 21.32 kg (47 lbs); Stand weight 5.9 kg (13 lbs)
Processors specifications
Specification
Processors
  • Intel xeon processor E3-1280v3, Quad-Core, 8MB cache, 3.6 GHz, up to 4.0 GHz with Intel Turbo Boost Technology
  • Intel xeon processor E3-1245v3, Quad-Core, 8MB cache, 3.4 GHz, up to 3.8 GHz with Intel Turbo Boost Technology
  • Intel xeon processor E3-1225v3, Quad-Core, 8MB cache, 3.2 GHz, up to 3.6 GHz with Intel Turbo Boost Technology
  • Intel Core i5-4570 processor, Quad-Core, 6MB cache, 3.2 GHz, up to 3.6 GHz with Intel Turbo Boost Technology
  • Intel Core i3-4130 processor, Dual-Core, 4MB cache, 3.4 GHz
Hard drives specifications
SATA hard drives for HP workstations
Specification
500GB SATA 10K rpm SFF HDD
Capacity
500GB
Height
0.6 in; 1.53 cm
Width
Media diameter
2.5 in; 6.36 cm
Physical size
2.75 in; 6.99 cm
Interface
Serial ATA (6Gb/s)
Synchronous transfer
Up to 600MB/s
Rate
(Maximum)
Buffer
64MB
Cache
Adaptive
Seek time (typical reads, includes controller overhead, including settling)
Single track
1.2 ms (typical)
Average
3.6 ms
Full stroke
9.0 ms (typical)
Rotational speed
10K rpm
Operating temperature
5° to 55° C (41° to 131° F)
Specification
1TB SATA 10K rpm SFF HDD
Capacity
1TB
Height
0.6 in; 1.53 cm
Width
Media diameter
2.5 in; 6.36 cm
Physical size
2.75 in; 6.99 cm
Interface
Serial ATA (6Gb/s)
Up to 600MB/s
Rate
(Maximum)
Buffer
64MB
Cache
Adaptive
Single track
1.2 ms (typical)
Average
3.6 ms
Full stroke
9.0 ms (typical)
Rotational speed
10K rpm
Specification
500GB SATA 7200 rpm 6Gb/s 3.5 inch HDD
Capacity
500GB
Height
1 in; 2.54 cm
Width
Media diameter
3.5 in; 8.9 cm
Physical size
4 in; 10.17 cm
Interface
Serial ATA (6.0Gb/s), NCQ enabled
Up to 600MB/s
Rate
(Maximum)
Buffer
16MB
Cache
Adaptive
Single track
2 ms
Average
11 ms
Full stroke
21 ms
Rotational speed
7,200 rpm
Logical blocks
976,773,168
Specification
1TB SATA 7200 rpm 6Gb/s 3.5 inch HDD
Capacity
1 Terabyte (1000GB)
Height
1 in; 2.54 cm
Width
Media diameter
3.5 in; 8.9 cm
Physical size
4 in; 10.17 cm
Interface
Up to 600MB/s
Rate
(Maximum)
Buffer
64MB
Single track
2 ms
Average
11 ms
Full stroke
21 ms
Rotational speed
7,200 rpm
Logical blocks
1,953,525,168
Specification
2.0TB SATA 7200 rpm 6Gb/s 3.5 inch HDD
Capacity
2TB
Height
1 in; 2.54 cm
Width
Media diameter
3.5 in; 8.9 cm
Physical size
4 in; 10.17 cm
Interface
Up to 600MB/s
Rate
(Maximum)
Buffer
64MB
Single track
1.0 ms
Average
11 ms
Full stroke
18 ms
Rotational speed
7,200 rpm
Logical blocks
3,907,029,168
Specification
3.0TB SATA 7200 rpm 6Gb/s 3.5 inch HDD
Capacity
3.0TB
Height
1 in; 2.54 cm
Width
Media diameter
3.5 in; 8.9 cm
Physical size
4 in; 10.17 cm
Interface
Up to 600MB/s
Rate
(Maximum)
Buffer
64MB
Single track
0.6 ms
Average
11 ms
Rotational speed
7,200 rpm
SATA SSDs for HP workstations
Specification
HP 256GB SATA 6GB/s SSD
Capacity
256GB
Height
0.28 in; 0.7 cm
Interface
SATA 6GB/s
Synchronous transfer Rate (Maximum)
Up to 500MB/s (Sequential read)
0° to 70° C (32° to 158° F)
HP 256GB mSATA 6Gb/s SSD
Capacity
256GB
Interface
6Gb/s SATA
HP 512GB SATA 6GB/s SSD
Capacity
512GB
Height
0.28 in; 0.7 cm
Width
Physical size
2.5 in; 6.36 cm
Interface
SATA 6GB/s
Seagate 600 Pro 120GB SATA SSD
Capacity
120GB
Height
0.276 in; 0.7 cm
Width
Physical size
2.76 in; 7.01 cm
Interface
SATA 6GB/s
Up to 600MB/s
Seagate 600 Pro 480GB SATA SSD
Capacity
480GB
Height
0.28 in; 0.7 cm
Width
Physical size
2.76 in; 7.01 cm
Interface
SATA 6GB/s
Up to 600MB/s
Graphics specifications
Integrated Intel HD Graphics (Z230/Z1G2)
Specification
Form factor
Integrated in select Intel Xeon E3, Intel Core i7, and Intel Core i5 processors. Check specific platform specifications for selections.
Graphics controller
Intel HD graphics
Memory
Unified Memory Architecture (UMA) frame buffer. Graphics memory is shared with system memory. Size selectable between 64MB to 512MB via BIOS setting. Default size is 64MB. Additional memory is allocated for graphics as needed using Intel's Dynamic Video Memory Technology (Intel DVMT 5.0), to provide an optimal balance between graphics and system memory use.
Connectors
Check system platform specifications where Intel HD graphics are available.
Maximum resolution
  • Display port: 2560 x 1600
  • DVI: 1920 x 1200
  • VGA: 2048 x 1536
Shading architecture
Shader model 5.0
Supported graphics
OpenGL 4.0
APIs
DirectX 11.1
Available graphics
Windows 7
Drivers
Windows 8.1
1. For DVI and VGA outputs, separate adapters may be required.
NVIDIA quadro K610M 1GB graphics
Form factor
MXM v3.1 type A (82 mm x 70 mm)
Graphics controller
  • N15M-Q3, 954MHz core clock
  • PCI express Gen 3 x16 (part of MXM v3.1 connector)
Memory
  • 1GB GDDR5
  • 64 bit wide interface
  • 2600 MHz
  • 20.8 GB/s
Connectors
One M X M v3.1 connector (285-pin)
Maximum resolution
  • 2 x 3840 x 2160 @ 60Hz digital displays
  • In Z1 G2 application:
    • Internal display: 2560 x 1440
    • External display via DP connector: 2560 x 1600
    • External display via optional thunderbolt module: Two 3840 x 2160
Image quality features
  • Each color component can be processed at up to 32-bit floating point.precision and displayed at up to 12-bit precision.
  • Advanced FXAA and TXAA antialiasing.
  • 16 K Texture and render processing.
  • MPEG-2 HD and WMV HD video playback (1920 x 1080p).
  • H.264 hardware decode acceleration.
  • Nvidia scalable geometry engine.
Shader model 5.0 support
Supported graphics APIs
  • Full IEEE 764-2008 32-bit
  • DirectX 11.1 shader model 5.0
  • OpenGL 4.3
  • Compute API support for NVIDIA CUDA C, CUDA C++, DirectCompute 5.0, OpenCL, Java, Python and Fortran
Available graphics drivers
  • Windows 7 64-bit
  • Windows 8.1 64-bit
  • SUSE linux enterprise desktop 11 64-bit
  • Red Hat enterprise linux 6 workstation 64-bit
NVIDIA quadro K2100M 2GB graphics
Form factor
MXM v3.1 ypte A (82 mm x 70 mm)
Graphics controller
  • N15P-Q3, 665MHz core clock
  • 576 CUDA cores
Bus type
Memory
  • 2GB GDDR5
  • 128 bit wide interface
  • 3000 MHz
  • 48GB/s
Connectors
Maximum resolution
  • precision and displayed at up to 12-bit precision.
  • AES-128 CTR/CBC/ECB decryption modes supported.
  • Nvidia 3D Vision Pro
Supported graphics
APIs
  • DirectX 11.1 Shader Model 5.0
  • OpenGL 4.3
  • 5.0, OpenCL, Java, Python and Fortran
Available graphics
Windows 7 64-bit
Drivers
NVIDIA Quadro K3100M 4GB graphics
Form factor
M X M v3.1 type A (82 mm x 105 mm)
Graphics controller
  • N15E-Q1, 705MHz core clock
  • 768 CUDA cores
Bus type
PCI express Gen 3 x 16 (part of MXM v3.1 connector)
Memory
  • 4GB GDDR5
  • 256 bit wide interface
  • 3200 MHz
  • 102.4 GB/s
Connectors
Maximum resolution
Supported graphics
APIs
  • DirectX 11.1 Shader model 5.0
  • OpenGL 4.3
Available graphics
Windows 7 64-bit
Drivers
NVIDIA Quadro K4100M 4GB graphics
Form factor
M X M v3.1 type B (82 mm x 105 mm)
Graphics controller
  • N15E-Q3, 705MHz core clock
  • 1152 CUDA cores
Bus type
PCI Express Gen 3 x16 (part of M X M v3.1 connector)
Memory
  • 4GB GDDR5
  • 3200MHz
  • 102.4 GB/s
Connectors
Maximum resolution
  • Maximum number of active displays: 4
    • External display via optional Thunderbolt module: Two 3840 x 2160
  • 16K Texture and render Processing.
Supported graphics
APIs
  • OpenGL 4.3
Available graphics
Windows 7 64-bit
Drivers
Optical and removable storage
HP Slim DVD-ROM drive
12.7 mm high, tray-load
Mounting orientation
Either horizontal or vertical
Interface Type
SATA / ATAPI
Dimensions (W x H x D)
128 x 14 x 128 mm
Disc capacity
DVD-ROM
  • Single layer: Up to 4.7GB
  • Double layer: Up to 8.5GB
Access times
DVD-ROM single layer
< 110 ms (typical)
CD-ROM mode 1
< 110 ms (typical)
Full stroke DVD
< 230 ms (seek)
Full stroke CD
< 220 ms (seek)
Power
Source
SATA DC power receptacle
DC Power requirements
5 VDC ± 5%-100 mV ripple p-p
DC current
5 VDC -< 800mA typical, < 1600 mA maximum
Operating environmental (all conditions noncondensing)
Temperature
5° to 50° C (41° to 122° F)
Relative humidity
10% to 80%
Maximum wet bulb temperature
29° C (84° F)
HP Slim SuperMulti DVDRW SATA Drive
Interface type
SATA / ATAPI
128 x 14 x 128 mm
Supported media types
  • DVD-RAM
  • DVD+R
  • DVD+RW
  • DVD+R DL
  • DVD-R DL
  • DVD-R
  • DVD-RW
  • CD-R
  • CD-RW
Disc capacity
DVD-ROM
8.5GB DL or 4.7GB standard
Access times
Full stroke DVD
< 230 ms (seek)
Full stroke CD
< 220 ms (seek)
Maximum data
CD ROM read
CD-ROM, CD-R Up to 24X
Transfer rates
DVD ROM read
  • CD-RW Up to 24X
  • DVD-RAM Up to 8X
  • DVD+RW Up to 8X
  • DVD-RW Up to 8X
  • DVD+R DL Up to 8X
  • DVD-R DL Up to 8X
  • DVD-ROM Up to 8X
  • DVD-ROM DL Up to 8X
  • DVD+R Up to 8X
  • DVD-R Up to 8X
Power
Source
DC power requirements
DC current
5 VDC -< 800 mA typical < 1600 mA maximum
Temperature
Relative humidity
10% to 80%
29° C (84° F)
HP Slim Blu-ray Writer
Horizontal
Interface type
SATA
128 x 14 x 128 mm
  • BD-ROM
  • BD-R
  • BD-RE
  • DVD-RAM
  • DVD+R
  • DVD+RW
  • DVD+R DL
  • DVD-R DL
  • DVD-R
  • DVD-RW
  • CD-R
  • CD-RW
Disc capacity
DVD-ROM
8.5GB DL or 4.7 GB standard
CD-ROM
  • 650MB CD-ROM (Read only)
  • 800/700/650MB CD-Recordable (Read & write)
  • 700/650MB CD-Rewritable (Read & write)
  • 700/650MB High Speed CD-Rewritable (Read & write)
  • 700/650MB Ultra & Ultra+ Speed CDRewritable (Read & write)
Blu-ray
50 GB DL or 25GB standard
Access times
Full stroke DVD
< 200 ms (seek)
Full stroke CD
< 200ms (seek)
Blu-ray
< 230ms (seek)
Startup time
  • (Time to drive ready from tray loading)
  • BD-ROM (SL/DL) 25S / 28S
  • BD-R (SL/DL) 25S / 28S
  • BD-RE (SL/DL) 25S / 28S
  • DVD-ROM (SL/DL) 18S / 18S
  • DVD-R (SL/DL) 25S / 25S
  • DVD-RW 25S
  • DVD+R (SL/DL) 25S / 25S
  • DVD+RW 25S
  • DVD-RAM 45S
  • CD-ROM 15S
Maximum data transfer rates
CD ROM read
  • CD-ROM, CD-R Up to 24X
  • CD-RW Up to 24X
DVD ROM read
  • DVD-RAM Up to 8X
  • DVD+RW Up to 8X
  • DVD-RW Up to 8X
  • DVD+R DL Up to 8X
  • DVD-R DL Up to 8X
  • DVD-ROM Up to 8X
  • DVD+R Up to 8X
  • DVD-R Up to 8X
Blu-ray
  • BD-ROM Up to 6X
  • BD-ROM DL Up to 6X
  • BD-R Up to 6X
  • BD-R DL Up to 6X
  • BD-R Up to 6X
  • BD-RE SL/DL Up to 6X
  • BD-RE TL 4.8x
Power
Source
DC current
5 VDC -< 900 mA typical, 2000 mA maximum
Temperature
Relative humidity
15% to 80%
29° C (84° F)
Controller cards specifications
HP Thunderbolt 2-port AiO module
  • Data transfer rate: Supports up to 20 Gb/s (20,000 Mb/s)
  • Devices supported: Thunderbolt certified devices
  • Ports: Two (2) Thunderbolt 2 external 20-Pin output connectors (Side)
  • System requirements: Genuine Windows 7 Professional 64-bit, Genuine Windows 8.1 64-bit, Intel i5 series or higher processor, 128-MB RAM, 1-GB Hard Drive, available PCIe slot.
  • Temperature - Operating: 10° to 55° C ( 50° to 131° F)
  • Temperature - Storage: -30° to 60° C (-22° to 140° F)
  • Relative humidity - Operating: 20% to 80%
  • Compliances: FCC Part 15B, cULus 60950, CE Mark EN55022B(1995)/EN55024- 1998 STD, Taiwan BSMI CNS13438, Korea MIC
  • Operating systems supported: Genuine Windows 7 Professional 64-bit, Genuine Windows 8.1 64-bit.
  • Kit contents: HP Thunderbolt 2 Module, user documentation and warranty card.
  • Warranty: The HP Thunderbolt 2 Module has a one-year limited warranty or the remainder of the warranty of the HP supported product in which it is installed. Technical support is available seven days a week, 24 hours a day, by phone, as well as online support forums. Certain restrictions and exclusions apply.
Networking and communications specifications
Integrated intel I217LM PCIe GbE controller
  • Connector: RJ-45
  • Controller: Intel I217LM GbE platform LAN connect networking controller
  • Memory: 3KB Tx and 3KB Rx FIFO packet buffer memory
  • Data rates supported: 10/100/1000 Mb/s
  • Compliance: 802.1as/1588, 802.1p, 802.1Q, 802.3, 802.3ab, 802.3az, 802.3i, 802.3u, 802.3z
  • Bus architecture: PCI express and SMBus
  • Data transfer mode: PCIe-based interface for active state operation (S0 state) and SMBus for host and management traffic (Sx low power state)
  • Power requirement: Requires 3.3 V (integrated regulators for core Vdc)
  • Boot ROM support: Yes
  • Network transfer mode: Full-duplex; Half-duplex (not supported for the 1000BASE-T transceiver)
  • Network transfer rate:
    • 10 BASE-T (half-duplex) 10 Mb/s
    • 10 BASE-T (full-duplex) 20 Mb/s
    • 100 BASE-TX (half-duplex) 100 Mb/s
    • 100 BASE-TX (full-duplex) 200 Mb/s
    • 1000 BASE-T (full-duplex) 2000 Mb/s
  • Management capabilities: vPro, WOL, auto MDI crossover, PXE, iSCSI Boot, Muti-port teaming, RSS, ACPI, Advanced cable diagnostic, loopback modes, AMT 9.0 support, Circuit breaker, VLAN, Multicast Listener Discovery (MLD)
Environmental specifications
Operating:
Temperature
5° to 35°C (40° to 95°F)
Humidity
8% to 85%
Maximum altitude (unpressurized)
3,000 m (10,000 ft)
Non-operating:
Temperature
-40° to 60°C (-40° to 140°F)
Humidity
8% to 90%
9,100 m (30,000 ft)
Safety certifications
Eco-Label certifications & declarations
  • ENERGY STAR (energy-saving features available on selected configurations-Windows only)
  • US Federal Energy Management Program (FEMP)
  • IT ECO declaration
Link to product overview information
