    Apache Log4j Update
HP Designjet T2500 eMultifunctional Printer Series - Line lengths are inaccurate
If you have measured your printed lines and find that the lengths are not sufficiently accurate for your purposes, you can try to improve line length accuracy in the following ways.
  1. Print on HP Matte Film, for which your printer's line length accuracy is specified. See Functional specificationsFunctional specifications.
    Polyester film is about ten times more dimensionally stable than paper. However, using film that is thinner or thicker than HP Matte Film will reduce line length accuracy.
  2. Set the Print Quality slider to Quality.
  3. Maintain the room at a steady temperature between 10 and 30°C (50 and 86°F).
  4. Load the roll of film and let it rest for five minutes before printing.
  5. If you are still not satisfied, try recalibrating the paper advance. See Recalibrate the paper advanceRecalibrate the paper advance.
