HP Designjet T2500 eMultifunctional Printer Series - Check usage statistics for a job
There are two ways to check usage statistics for a particular job.
The accuracy of the usage statistics is not guaranteed.
Accounting statistics with the HP Utility
  1. Access the HP Utility, see Access the HP UtilityAccess the HP Utility.
  2. Under Windows, select the Job center and then Accounting, which launches the Embedded Web Server.
    Under Mac OS X, select Job Accounting and click the Look Up button.
Accounting statistics with the Embedded Web Server
  1. Access the Embedded Web Server, see Access the Embedded Web ServerAccess the Embedded Web Server.
  2. Go to the Main tab.
  3. Select History > Accounting.
