Printhead
One printhead, with doubled nozzles for matte black
Ink cartridges
Cartridges containing 40 ml of ink: gray, photo black, matte black, yellow, magenta, and cyan
Cartridges containing 130 ml of ink: gray, photo black, matte black, yellow, magenta, and cyan
Minimum
Maximum
Roll width
279 mm
914 mm
Roll length
91 m
Roll diameter
140 mm
Roll weight
11.9 kg
Sheet width
210 mm
914 mm
Sheet length
279 mm
1676 mm
Sheet width (scanner)
914 mm (36 in)
Sheet length (scanner)
15 m (49.21 ft) at 200dpi, TIFF file format and 24 in width
Roll paper thickness
0.5 mm
Sheet paper thickness
0.5 mm
Paper weight
60 g/m²
328 g/m²
* up to 0.6 mm printed to the output stacking tray with manual mode
Print quality
Maximum detail
Graphic language
Rendering resolution (ppi)
Printing resolution (dpi)
Best (photo paper*)
On
HP-GL/2, HP PCL3GUI
1200 × 1200
2400 × 1200
PostScript
600 × 600
2400 × 1200
Off
any
600 × 600
1200 × 1200
Best (other papers)
Off
any
600 × 600
1200 × 1200
Normal
Off
HP-GL/2
600 × 600
1200 × 1200
HP PCL3GUI, PostScript
300 × 300
1200 × 1200
Fast (heavyweight coated, photo)
Off
HP-GL/2
600 × 600
1200 × 1200
300 × 300
1200 × 1200
Fast (plain, coated, natural tracing paper)
Off
HP-GL/2
600 × 600
600 × 1200
300 × 300
600 × 1200
Economode
Off
any
300 × 300
600 × 1200
* For a list of supported papers, see Order paperOrder paper.
Scanner resolutions: 200, 300, 600 ppi.
Top, right and left margins
5 mm
Bottom margin (trailing edge)
5 mm (roll)
22 mm (sheet)
±0.1% of the specified vector length or ±0.2 mm (whichever is greater) at 23°C, 50-60% relative humidity, on E/A0 printing material in Best or Normal mode with HP Matte Film roll feed.
HP Designjet
Languages
T2500
HP PCL3GUI, HP-GL/2 and HP RTL, CALS G4, TIFF, JPEG, URF
T2500 PS
HP PCL3GUI, HP-GL/2 and HP RTL, CALS G4, TIFF, JPEG, URF, Adobe PDF 1.7, Adobe PostScript 3
Scanner
TIFF, JPEG, PDF
