    We are upgrading our website
HP Designjet Z5400 PostScript ePrinter Series - Print with no margins
Printing with no margins (to the edges of the paper) is known as borderless printing. This can be done only on rolls of glossy paper.
In order to be sure of leaving no margins, the printer prints slightly past the edges of the paper. Any ink deposited outside the paper is absorbed by the sponge situated in the platen.
You can request printing with no margins in the following ways:
  • In the Windows driver dialog: select the Paper/Quality tab and press the Margins/Layout button. Then select Borderless.
  • In the Mac OS X Page Setup dialog: select a paper size name that includes the words “no margins”. Then, in the Print dialog, select Margins/Layout > Borderless.
    If your application offers no Page Setup dialog, please use the Print dialog.
  • On the Embedded Web Server's Submit Job page: select Advanced settings > Paper > Layout/Margins > Borderless.
When you select Borderless, you must also select one of the following Image Enlargement options:
  • Automatically by printer means that the printer automatically enlarges your image slightly (normally by a few millimeters in each direction) in order to print over the edges of the paper.
  • Manually in application means that you must enlarge the image yourself in your application, and select a custom paper size that is slightly larger than the actual paper size.
If the first print job after loading paper is a borderless job, the printer may trim the leading edge of the paper before printing.
At the end of a borderless print, the printer normally cuts the print slightly inside the image area to ensure that the print is borderless. It then cuts the paper again so that no residual part of the image is included in the next print. However, if the job is cancelled, or if there is white space at the bottom of the image, only a single cut is made.
