HP 250 G2 Notebook PC - Overview
Product description
Product features
Feature
Processor1
  • 4th Generation Intel Core i3-4000M (2.4 GHz, 3MB L3 cache, 2 cores)
  • 3rd Generation Intel Core i3-3110M (2.4 GHz, 3 MB L3 cache, 2 cores)
  • Intel Pentium N3510 (2.0 GHz, 2MB L3 cache, 4 cores)
  • Intel Pentium 2020M (2.4 GHz, 2MB L3 cache, 2 cores)
  • Intel Celeron N2810 (2.0 GHz, 1MB L3 cache, 2 cores)
  • Intel Celeron 1000M (1.8 GHz, 2MB L3 cache, 2 cores)
  • Intel HM86 Express Chipset (4th generation Intel Core processors)
  • Intel HM76 Express Chipset (3rd generation Intel Core, Pentium and Celeron processors)
  • Intel Bay Trial - M SoC (Intel Pentium and Celeron processors)
Graphics
  • Integrated
    • Intel HD Graphics (Intel Pentium or Intel Celeron processor)
    • Intel HD Graphics 4000 (3rd Generation Intel Core i3, i5 processor)
    • Intel HD Graphics 4400 (4th Generation Intel Core i3 processor)
  • Discrete
    • Nvidia 820M Graphics with 1024MB of dedicated video memory (Switchable Graphics)
  • Internal
    • 15.6-inch diagonal LED-backlit HD 16:9 widescreen anti-glare (1366 x 768)
    • 15.6-inch diagonal LED-backlit HD 16:9 widescreen anti-glare (1366 x 768) (touch-enabled)
  • External
    • Up to 32-bit per pixel color depth
  • VGA
    • Port supports resolutions up to 2048 x 1536 external resolution @75 Hz (Intel HM76 Express Chipset)
    • Port supports resolutions up to 2560 x 1600 external resolution @ 60Hz (Intel Bay Trial - M SoC)
  • HDMI
    • 1.4 port supports up to 1080p, 1920 x 1080 at 60 Hz
Storage and drives (Primary storage bay hard drives)
  • 320GB 5400 rpm SMART SATA II
  • 500GB 5400 rpm SMART SATA II
  • 750GB 5400 rpm SMART SATA II
  • 1TB 5400 rpm SMART SATA II
Optical drives
  • Fixed 12.7 mm SATA Optical drive
  • DVD+/-RW SuperMulti DL Drive
Memory
  • Standard
    • DDR3L SDRAM (1600 MHz)
    • Two SODIMM slots supporting dual-channel memory
    • Standard memory up to 8192MB
  • Maximum
    • Upgradeable to 16384MB with optional 8192MB SODIMMs in slots 1 and 2
  • Dual-channel
    • Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots
Networking/communications
  • Wireless2,3
    • 802.11 b/g/n (1x1) wireless LAN module
    • Qualcomm 802.11 b/g/n (1x1) wireless LAN module
    • Optional Ralink 802.11 b/g/n (1x1) + Bluetooth 4.0 Combo
    • Optional Bluetooth 2.1 or Bluetooth 4.0
  • Communications
    • Realtek Ethernet (10/100 NIC) (Intel Bay Trial - M SoC)
    • Realtek Ethernet (10/100/1000 NIC) (Intel HM76 Express Chipset and Intel HM86 Express Chipset, only with Core i3 and non- Touch Display)
Audio/multimedia
  • Audio
    • High definition audio support
    • Integrated stereo speaker
    • Headphone / Microphone in combo jack
    • Integrated microphone
  • Webcam
    • Integrated HD webcam
Keyboards/pointing devices/buttons & function keys
  • Keyboard
    • The 101/102-key compatible keyboard features a full-pitch key layout with desktop keyboard features, such as editing keys, both left and right control and alt keys, and function keys. US and International key layouts are available.
    • Includes a separate numeric keypad.
  • Pointing devices
    • Touchpad with 2-piece pick button with left and right click functions
    • Multi-touch gestures supported
  • Buttons and function Keys
    • On/Off button
Security
Security Lock slot (lock must be purchased separately)
Power
  • Power supply
    • External 45 W ac adapter (UMA only)
    • External 65 W ac adapter
  • Primary battery
    • HP 4-cell (41 WHr) Li-Ion battery
    • HP 3-cell (31 WHr) Li-Ion battery (Available December 2013)
  • Battery life
    • TBD
  • Power conservation4
    • Hibernation
    • Standby
    • ACPI compliance
1: Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
2: Sold separately or as an optional feature.
3: Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited.
4: Only Linux will feature power conservation.
Software overview
Feature
Operating system preinstalled
  • Windows 8.1 641
  • Windows 8.1 Pro 641
  • Windows 7 Professional 64 (available through downgrade rights from Windows 8.1 Pro 64) (Available January 2013)2
  • Ubuntu Linux
  • FreeDOS 2.0
Preinstalled software with Windows Operating System
  • Buy Office
  • Recovery Manager Installer
  • Cyberlink Youcam DE
  • Cyberlink Power DVD (available on select models)
  • McAffee Internet Security
  • Getting Started with Windows 8.1
1: Not all features are available in all editions of Windows 8.1. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows 8.1 functionality. See http://www.microsoft.com for details.
2: This system is preinstalled with Windows® 7 Pro software and also comes with a license and media for Windows 8 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
Country: Flag Thailand
