HP Tablets - HP Connected Music Powered by Meridian (Android Jelly Bean, 8" screen size or larger)
This document applies to HP tablets 8" and larger with Android (Jelly Bean).
With the HP Connected Music software application, you can listen to Internet radio, preview and buy tracks in the 7digital music store, listen to subscription music services, and play music files stored on your device. Use this document to learn more about installing and using the HP Connected Music app.
Installing HP Connected Music
Use the following steps to download the HP Connected Music app from the Google Play Store and create a new account:
  1. Be sure you are connected to the Internet, and then touch the Google Play Store icon .
    The Google Play Store opens on your device.
  2. Touch the search icon , and then search for HP Connected Music.
  3. Touch the HP Connected Music app, and then touch the Install button.
    Figure : Install HP Connected Music app screen
  4. Touch Accept to allow the app to access your information. HP Connected Music is installed on your Home screen.
    Figure : Accept App permissions request
  5. Open HP Connected Music from the Google Play Store by touching the Open button or by touching the HP Connected Music icon on your device.
    Figure : HP Connected Music icon
  6. The HP Connected Music home screen opens. Touch the Setup button located in the lower left corner of the screen.
    Figure : Setup button on the HP Connected Music home screen
  7. On the Setup Account window, sign in with another account or enter your email address and touch Setup Account to create a new account.
    Figure : Setup Account information
    Setup Account information window
    You can choose to sign in with these services at any time after logging in to HP Connected Music by touching the Account icon located in the lower left corner of the screen.
  8. Fill out the Setup Account form, and then touch OK.
    Figure : Setup Account form
    Setup Account form window
  9. At the Account Successfully Created window, you are given another opportunity to sign in to any additional accounts. Close the window to start using HP Connected Music
You are now ready to configure and use HP Connected Music.
Configuring HP Connected Music
After you have set up an account, you return to the HP Connected Music Home screen.
Figure : HP Connected Music Home screen
On the HP Connected Music home screen, in the lower left corner, click the options icon and then select Preferences from the menu.
Figure : Preferences in the options menu
The following tabs allow you to configure HP Connected Music to your preferences:
  • General: Use the General tab to configure General preferences, such as language and display options.
    Figure : General Tab under the Preferences menu
  • Services: Use the Services tab to log in to different subscription music service accounts that you want to use in HP Connected Music.
Adding music files to your library
The HP Connected Music app automatically adds music from your music folder to your library. You can add more music to your library by buying tracks from the 7digital Music Store, or downloading music to your music folder from other devices. To open the HP Connected Music app, click the app icon on the Home screen.
The app opens on the Windows desktop.
For more information about adding music to your HP Connected Music library, choose from the sections below:
Listening to music
Use HP Connected Music to listen to music from your library, create and listen to a playlist, or listen to music on Internet radio. Touch the HP Connected Music app icon to open the app.
Frequently Asked Questions
Get answers to the following most frequently asked questions.
What audio file formats does HP Connected Music support?
How can I add music to my collection?
Where do files go when I add them to my collection?
What happens if I buy music from the iTunes music store?
Can I buy music from other online stores?
How much music can I have in my collection?
Can HP Connected Music sync music to my phone or iPod?
I am trying to listen to music using the File Manager app and it is not working; what can I do?
I uninstalled HP Connected Music; can you send me a download link?
What is Meridian?
Where can I get more help?
