HP ProBook 645 G1 Notebook PC Product Specification
Product image
Product features
Feature
Graphics (Integrated)1
  • AMD Elite Quad-Core A10-5750M Accelerated Processor with AMD Radeon HD 8650G Graphics
  • AMD Elite Quad-Core A8-550M Accelerated Processor with AMD Radeon HD 8550G Graphics
  • AMD Elite A6-5350M Accelerated Processor with AMD Radeon HD 8450G Graphics
  • AMD Elite A4-5150M Accelerated Processor with AMD Radeon HD 8350G Graphics
  • AMD Elite Quad-Core A10-4600M Accelerated Processor with AMD Radeon HD 7660G Graphics
  • AMD Elite Quad-Core A8-4500M Accelerated Processor with AMD Radeon HD 7640G Graphics
  • AMD Elite A6-4400M Accelerated Processor with AMD Radeon HD 7520G Graphics
  • AMD Elite A4-4300M Accelerated Processor with AMD Radeon HD 7420G Graphics
  • Internal:
    • 14-inch diagonal LED-backlit HD anti-glare (1366 x 768)
    • 14-inch diagonal LED-backlit HD+ anti-glare (1600 x 900)
    • 14-inch diagonal LED-backlit FHD anti-glare slim (1920 x 1080))
  • External:
    • Up to 32-bit per pixel color depth
  • VGA:
    • Port supports resolutions up to 1920 x 1200 external resolution @75 Hz
  • DisplayPort 1.2:
    • Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz
    • Full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
  • DVI-D (single link):
    • Video signal available through DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Storage and drives (Primary storage bay)
  • Hard drives2
    • 320/500/1TB 5400 rpm SMART SATA II HDD
    • 320/500/750GB 7200 rpm SMART SATA II HDD
    • 500GB 7200 rpm SED (Self Encrypting Drive)
    • 500GB 5400 rpm FIPSSED (Self Encrypting Drive)3
  • Solid state drive2
    • 128/180GB 2.5-inch Solid State Drive
    • 256GB SED Solid State Drive
  • HP 3D DriveGuard (Windows only): The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive
Optical drives
  • Fixed 9.5 mm Serial ATA upgrade bay
    • Blu-ray ROM DVD+/-RW SuperMulti DL Drive
    • DVD+/-RW SuperMulti DL Drive
    • DVD-ROM Drive
  • Weight saver
Memory
  • Standard
    • DDR 3L PC3L-12800 (1600 MHz)
    • Two SODIMM slots supporting dual-channel memory
    • 2GB, 4GB, and 8GB SODIMMs
  • Maximum: Upgradeable to 16384 MB with optional 8192 MB SODIMMs in slots 1 and 2
  • Dual-channel: Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Networking
  • Wireless
  • Broadband wireless (WWAN)
    • HP hs3110 HSPA+ Mobile broadband module
    • HP lt4111 LTE/EV-DO/HSPA+ Mobile broadband module (US)
    • HP lt4112 LTE/HSPA+ Mobile broadband module (EMEA, APJ)
  • Wireless LAN (WLAN)
    • Atheros 802.11 b/g/n (1x1)
    • Atheros 802.11 b/g/n (1x1) with bluetooth v4.0 combo
    • Broadcom 802.11 a/b/g/n (2x2) with bluetooth v4.0 combo
Communications
Realtek 10/100/1000 ethernet controller
Audio/multimedia
  • Audio
    • HD Audio with DTS Sound+
    • (2) Integrated stereo speakers
    • Integrated digital microphone (dual-microphone array when equipped with optional webcam)
    • Function keys for microphone:
      • Mute
      • Volume Up
      • Volume down
    • Stereo headphone/line out
    • Stereo microphone in
  • Webcam: Optional 720p HD webcam
    • HD format (widescreen)
    • Supports videoconferencing (non-HD) and still image capture
    • High quality fixed focus lens
    • Video capture at various resolutions up to 1280x720 resolution (720p) and up to 30fps
    • M-JPEG compression supports higher frame rates for video capture and videoconferencing
    • Improved low light sensitivity
    • Improved dynamic range
    • Skype-ready
Input devices
  • Keyboard
    • HP spill-resistant
    • Thin layer of Mylar film under the keyboard
    • US and International key layouts
  • Pointing devices
    • Touchpad with gestures support
    • On/Off button with LED indicator
    • Two-way scroll
    • Two pick buttons
    • Optional point stick
Buttons and function keys
  • Separate launch buttons provide easy access to wireless on/off and speaker mute.
  • Function keys provide control of features including:
    • Standby mode
    • Display brightness
    • External display
    • Microphone mute
    • Volume down
    • Volume up
Power
  • Power supply
    • External 65 W HP smart ac adapter
    • Power cord included is 1.8 m (+/- 0.1 m)/1.0 m (+/- 0.1 m)
    • HP Fast Charge
  • Primary battery
    • HP 9-cell Lithium-Ion battery (100 Whr)
    • HP 6-cell Lithium-Ion battery (55 Whr)
    • HP 6-cell Long Life Lithium-Ion battery (55 Whr)
    • HP 3-cell Lithium-Ion battery (33 Whr)
Ports/slots
  • Ports
    • USB 3.0 - Three
    • USB 3.0 charging port- One
    • DisplayPort 1.2 - One
    • VGA - One
    • Stereo microphone input - One
    • Headphone/line out - One
    • RJ-45 (Ethernet) - One
    • Docking connector - One
    • Power connector - One
  • Expansion slots supports
    • SD
    • SDHC
    • SDXC
1: Processor speed denotes maximum performance mode; processors will run at lower speeds in battery optimization mode.
2: For hard drives and solid state drives, GB = 1 billion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) and 36 GB (for Windows 8) of system disk is reserved for the system recovery software.
3: FIPS-certified, hardware-based AES-256 encryption image.
System specifications
Stand-alone power requirements (ac power)
  • Nominal operating voltage: TBD
  • Average operating power: TBD W
  • Max operating power: < 65 W
Temperature
  • Operating
    • 0°C to 35°C (32°F to 95°F) (not writing optical)
    • 5°C to 35°C (41°F to 95° F) (writing optical)
  • Non-operating: -20°C to 60°C (-4°F to 140°F)
Relative humidity
  • Operating: 10% to 90%, non-condensing
  • Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
  • Operating: 40 G, 2 ms, half-sine
  • Non-operating: 200 G, 2 ms, half-sine
Random vibration
  • Operating: 0.75 grms
  • Non-operating: 1.50 grms
Altitude (unpressurized)
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Display specifications
14.0-inch diagonal LEDbacklit HD anti-glare SVA eDP 1.2 flat (1366x768)
Outline dimensions (W x H x D)
32.09 x 20.56 x 0.36 cm (12.6 x 8.09 x 0.14 in)
Active area
30.94 x 17.395 cm (12.18 x 6.85 in)
Weight (Max)
320 g (0.71 lb)
Diagonal size
35.6cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Format: 1366 x 768 (HD)
  • Configuration: RGB Stripe
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
125 ppi
Viewing angle
SVA 40/40/15/30 (Left/Right/Down/Up)
14.0-inch diagonal LEDbacklit HD+ anti-glare SVA eDP 1.2 flat (1600 x 900)
Active area
30.96 x 17.415 cm (12.19 x 6.86 in)
Weight (Max)
325 g (0.72 lb)
Diagonal size
35.6cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
250 nit (typical)
Pixel resolution
  • Format: 1600 x 900 (HD+)
Interface
eDP 1.2 (1 lane)
LCD Mode
TN
PPI
131 ppi
Viewing angle
14.0-inch diagonal LEDbacklit FHD anti-glare UWA eDP 1.3 slim PSR (1920x1080)
32.09 x 20.56 x 0.3 cm (12.6 x 8.09 x 0.12 in)
Active area
30.93 x 17.4 cm (12.18 x 6.85 in)
Weight (Max)
340 g (0.75 lb)
Diagonal size
35.6cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nit (typical)
Pixel resolution
  • Format: 1920 x 1080 (FHD)
Interface
eDP 1.3+PSR (2 lane)
LCD mode
  • IPS
  • FFS
  • VA
PPI
157 ppi
Viewing angle
UWVA 85/85/85/85 (Left/Right/Down/Up)
Storage and drives specifications
320GB 5400-rpm SATA hard drive
Drive weight
115 g (0.25 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
  • ATA-8
  • SATA 2.6
  • 3.0 Gb/s
  • NCQ
Transfer rate
Synchronous (maximum): 300 MB/s (Drive capability)
Seek time (typical reads, including settling)
  • Single track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
625,142,448
Operating temperature (case temperature)
0°C to 60°C (32°F to 140°F)
Features
ATA security
500GB 5400-rpm SATA hard drive
Drive weight
101 g (0.22 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
  • ATA-8
  • SATA 2.6
  • 3.0 Gb/s
  • NCQ
Transfer rate
Synchronous (maximum) 300 MB/s (Drive capability)
  • Single track: 3 ms
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
1TB 5400-rpm SATA hard drive
Drive weight
115 g (0.254 lb)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
  • ATA-8
  • SATA 2.6
  • 3.0 Gb/s
  • NCQ
Transfer rate
  • Average: 13 ms
  • Maximum: 24 ms
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Features
ATA security
320GB 7200-rpm SATA hard drive
Drive weight
115 g (0.25 lb)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
  • ATA-8
  • SATA 2.6
  • 3.0 Gb/s
  • NCQ
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
625,142,448
Features
ATA security
500GB 7200-rpm SATA hard drive
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
  • ATA-8
  • SATA 2.6
  • 3.0 Gb/s
  • NCQ
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
750GB 7200-rpm SATA hard drive
Drive weight
115 g (0.25 lb)
Capacity
750GB
Height
9.5 mm (0.37 in)
Width
63.5mm (2.50 in)
Interface
  • ATA-8
  • SATA 2.6
  • 3.0 Gb/s
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Rotational speed
7200 rpm
Logical blocks
1,465,149,168
Features
ATA security
500GB 7200-rpm SMART SATA II Self Encrypting drive
Drive weight
115 g (0.25 lb)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.50 in)
Interface
  • ATA-8
  • SATA 2.6
  • 3.0 Gb/s
Transfer rate
  • Single track: 1 ms
  • Average: 12 ms
  • Maximum: 20 ms
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA security
500GB 5400-rpm SATA FIPS hard drive
Drive weight
95 g (0.20 lb)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
  • ATA-8
  • SATA 2.6
  • 3.0 Gb/s
  • NCQ
Transfer rate
  • Average: 11 ms
  • Maximum: 22 ms
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA security
SATA 6 Gb/s 128GB, 2.5-inch Solid State Drive
Drive weight
73 g (0.17 lb)
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum sequential read: 415 MB/s
  • Maximum wequential write: 175 MB/s
Logical blocks
250,069,680
0°C to 70°C (32°F to 158°F)
Features
  • ATA Security
  • ATA-8
  • SATA 3.0
  • DIPM
  • TRIM
SATA 6 Gb/s 180GB, 2.5- inch SATA Solid State Drive
Drive weight
78 g (0.17 lb)
Capacity
180 GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
SATA Gen 3 (6 Gb/s)
Performance
  • Maximum sequential read: Up to 550 MB/s
  • Maximum wequential write: Up to 520 MB/s
Logical blocks
351,651,888
Features
  • ATA Security
  • ATA-8
  • SATA 3.0
  • DIPM
  • TRIM
SATA 6 Gb/s 256GB, 2.5- inch SATA SED Solid State Drive
Drive weight
73 g (0.16 lb)
Capacity
256GB
Height
7 mm (0.276 in)
Width
70 mm (2.75 in)
Interface
SATA 3 (6 Gb/s)
Performance
  • Maximum sequential read: Up Up to 460 MB/s
  • Maximum wequential write: Up to 260 MB/s
Logical blocks
500,118,192
Features
  • ATA Security
  • ATA-8 compliant
  • SATA 3.0
  • DIPM
  • TRIM
1: For hard drives and solid state drives (SSD), GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 16 GB (for Windows 7) and 36 GB (for Windows 8) of system disk is reserved for the system recovery software.
2: FIPS-certified, hardware-based AES-256 encryption image.
Optical drives specifications
Access times (Random)
  • < 190 ms CD-ROM (typical)
  • < 180 ms DVD-ROM (typical)
  • < 230 ms BD-ROM (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X DVD-ROM
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 4X - DVD+R Dual Layer
  • 4X - DVD-R Dual Layer
  • 5X DVD-RAM
  • 6X BD-ROM
Transfer mode
UDMA Mode 5
Interface
Gen 1 SATA
Supported media (read)
  • CD-DA
  • CD-TEXT
  • CD-ROM
  • CD-ROM XA
  • MIXED MODE CD
  • CD-I
  • CD-I bridge
    • Photo-CD
    • Video CD
  • Multisession CD
    • Photo-CD
    • CD-EXTRA
    • Portfolio
    • CD-R
    • CD-RW
  • CD-R
  • CD-RW
  • DVD-ROM
    • DVD-5
    • DVD-9
    • DVD-10
    • DVD-18
  • DVD-R
  • DVD-RW
  • DVD+R
  • DVD+RW
  • DVD-RAM
  • BD-ROM
  • BD-R
  • BD-RE
Supported media (write)
  • CD-R
  • CD-RW
  • DVD+R
  • DVD+R DL
  • DVD+RW
  • DVD-R
  • DVD-R DL
  • DVD-RW
  • DVDRAM
Max media capacity (read)
50GB
Max media capacity (write)
8.5GB
Transport
Tray loading
DVD+/-RW SuperMulti DL drive
  • <140 ms CD (typical)
  • <160 ms DVD (typical)
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 6X - DVD+R Dual Layer
  • 6X - DVD-R Dual Layer
  • 5X DVD-RAM
Transfer mode
UDMA Mode 5
Interface
Gen 1 SATA
  • CD-DA
  • CD-TEXT
  • CD-ROM
  • CD-ROM XA
  • MIXED MODE CD
  • CD-I
  • CD-I bridge
    • Photo-CD
    • Video CD
  • Multisession CD
    • Photo-CD
    • CD-EXTRA
    • Portfolio
    • CD-R
    • CD-RW
  • CD-R
  • CD-RW
  • DVD-ROM
    • DVD-5
    • DVD-9
    • DVD-10
    • DVD-18
  • DVD-R
  • DVD-RW
  • DVD+R
  • DVD+RW
  • DVD-RAM
  • CD-R
  • CD-RW
  • DVD+R
  • DVD+RW
  • DVD-R
  • DVD-RW
  • DVD-RAM
  • DVD+R DL
  • DVD-R DL
8.5GB
8.5GB
Transport
Tray loading
DVD-ROM drive
  • < 140 ms CD (typical)
  • < 160 ms DVD (typical)
  • 24X CD-ROM
  • 8X-DVD
Transfer mode
UDMA Mode 5
Interface
Gen 1 SATA
  • CD-DA
  • CD-TEXT
  • CD-ROM
  • CD-ROM XA
  • MIXED MODE CD
  • CD-I
  • CD-I bridge
    • Photo-CD
    • Video CD
  • Multisession CD
    • Photo-CD
    • CD-EXTRA
    • Portfolio
    • CD-R
    • CD-RW
  • CD-R
  • CD-RW
  • DVD-ROM
    • DVD-5
    • DVD-9
    • DVD-10
    • DVD-18
  • DVD-R
  • DVD-RW
  • DVD+R
  • DVD+RW
  • DVD-RAM
None
8.5GB
Transport
Tray loading
Networking/communications specifications
Integrated Realtek 10/100/1000 NIC
Ethernet features
  • 10 Mbit/s operation
    • 10BASE-T
    • IEEE 802.3i
    • IEEE 802.3 clauses 13-14
  • 100 Mbit/s operation
    • 100BASE-TX
    • IEEE 802.3u
    • IEEE 802.3 clauses 21-30
  • 1000 Mbit/s operation
    • 1000BASE-T
    • IEEE 802.3ab
    • IEEE 8023 clauses 40
  • Auto-Negotiation (Automatic Speed Selection)
  • Full Duplex Operation at all speeds
  • Half Duplex operation at 10 and 100 Mbit/s
  • IEEE 802.1p QoS (Quality of Service) support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x flow control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE (Energy Efficient Ethernet)
  • Jumbo frame 9 K
  • Auto MDI/MDIX crossover cable detection
Power management
  • ACPI compliant - multiple power modes
  • Situation-sensitive features reduce power consumption
  • Advanced link down power saving for reducing link down power consumption
Performance features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Protocol Offload (ARP & NS)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame)
  • Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 Remote
  • Boot Statistics Gathering
    • SNMP MIB II
    • Ethernet-like MIB
    • Ethernet MIB (802.3x, clause 30)
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Realtek PCIe GBE Ethernet family controller
Technology/operating bands
  • CDMA/1xRTT/EvDO:
    • 800 MHz (Cell)
    • 1900 MHz (PCS)
  • GSM/GPRS/EDGE:
    • 850 MHz (Cell)
    • 900 MHz (EGSM)
    • 1800 MHz (DCS)
    • 1900 MHz (PCS)
  • UMTS/WCDMA with receive diversity:
    • 2100 MHz (UTRA FDD Band I)
    • 1900 MHz (UTRA FDD Band II)
    • 900 MHz (UTRA FDD Band VIII)
    • 850 MHz (UTRA FDD Band V)
  • LTE:
    • 700 MHz (Verizon, Band XIII)
Mobile operator
Verizon (US only)
Wireless protocol standards
  • GSM/GPRS/EDGE
    • Class B
    • Multi-slot class 10 operation
    • Coding schemes:
      • CS1 - CS4
      • MSC1 - MSC9.
  • CDMA
    • 1xEVDO Release 0 and Release A
    • IS-95A
    • IS-95B
    • IS-856
    • IS-2000
  • UMTS/WCDMA
    • Release 99
    • Release 7
  • LTE
    • Power Class III as per 3GPP TS 36.101
Wireless parametric standards
Complies with 3GPP specifications Release 8 for LTE
Maximum data rates
  • EvDO (Revision A)
    • 3.1 Mbps (Download)
    • 1.8 Mbps (Upload)
  • WCDMA (DC-HSPA+)
    • 42Mbps (Download)
  • LTE (Category 3)
    • 100 Mbps (Download )
    • 50Mbps (Upload)
GPS
  • Standalone
  • Assisted
  • XTRA
GPS bands
1575.42 MHz (± 1.023 MHz)
Maximum output power
  • GSM/GPRS/EDGE: 32dBm (+/-1)
  • WCDMA: 24dBm (+0.7/-2.3)
  • LTE: +23 dBm (+2.7 dBm/-1.7 dBm)
  • 1xRTT/EvDO: +24 dBm (+0.5 dBm/-1.5 dBm)
Maximum power consumption
2700 mA (peak)
Power consumption, Sleep mode
10 mA
Power management
  • USB selective suspend
  • Integrated notebook wireless button
Antenna type
Dual high efficiency 6 band antennae with spatial diversity, mounted in the display enclosure
Form factor
  • PCI-Express MiniCard
  • USB 2.0 interface
< 10 g (< 0.02 lb)
Dimensions (L x W x T)
51 x 30 x 5 mm (2.01 x 1.18 x 0.18 in)
Operating voltage
3.3 V +/- 9%
Temperature
  • Operating (from TIA/EIA/IS-98-D): -20°C to 65°C (-4°F to 149°F)
  • Non-operating, 96 hours (from MIL-STD 202 Method 108): -40°C to 85°C (-40°F to 185°F)
Humidity (non-condensing)
Non-operating: 85% relative humidity for 48 hours @ 85°C (185°F)
LED activity
  • LED Off - Radio Off
  • Solid LED On - Radio On
HP lt4111 LTE/EVDO/ HSPA+ 4G WWAN
  • LTE FDD all bands with diversity
    • 1900 MHz (Band II)1
    • 1700/2100 MHz (Band IV (AWS)
    • 850 MHz (Band V)
    • 700 MHz (Band XIII)
    • 700 MHZ (Band XVII)
    • 1900 MHz G Block (Band XXV)
  • WCDMA/HSDPA/HSUPA/HSPA+: all bands with diversity
    • 2100 MHz (Band I)
    • AWS 1700/2100 MHz (Band IV)
    • 850 MHz (Band V)
    • 800 MHz (Band VIII)
  • GSM/GPRS/EDGE
    • 1900 MHz
    • 1800 MHz
    • 850 MHz
    • 900 MHz
  • CDMA
    • Cellular 800 MHz (BC0)
    • PCS 1900 MHz (BC1)
  • 3GPP Release 8 LTE Specification
  • WCDMA R99, 3GPP Release 5, 6 and 7 UMTS Specification
  • EVDO Release 0 and Release A
Maximum data rates
  • LTE (Category 3)
    • 100Mbps (Download)
    • 50Mbps (Upload)
  • DC-HSPA+
    • 42Mbps (Download)
    • 5.76Mbps (Upload)
  • HSPA+
    • 21.6Mbps (Download)
    • 5.76Mbps (Upload)
  • EDGE
    • 236.8kbps (Download)
    • 236.8kbps (Upload)
  • GPRS
    • 85.6kbps(Download)
    • 85.6kbps (Upload)
GPS
  • Standalone GPS
  • A-GPS
  • GPS XTRA
GPS bands
  • 1575.42 MHz (± 1.023 MHz)
  • GLONASS 1596-1607MHz
  • LTE: +23 dBm (+/- 1 dBm)
  • WCDMA: +23 dBm (+/- 1 dBm)
  • GSM850/900, GMSK: +32dBm (+/- 1dBm)
  • GSM850/900, 8PSK: +27dBm (+/- 1dBm)
  • DCS1800 / PCS 1900, GMSK: +29dBm (+/- 1dBm)
  • DCS1800 / PCS 1900, 8PSK: +26dBm (+/- 1dBm)
  • CDMA: +24dBm (+/- 1dBm)
  • LTE: 1,200 mA (peak); < 900 mA (average)
    WCDMA: 1,100 mA (peak); < 800 mA (average)
    EGPRS: 2,500 mA (peak); < 700 mA (average)
Power consumption, sleep mode
2 mA
Power management
Antenna type
Dual high efficiency multi-band antennae with spatial diversity
Form factor
  • M.2
  • 3042-S3 Key B
6 g (0.013 lb)
42 × 30 × 2.3 mm (1.65 x 1.18 x 0.09 in)
Operating voltage
3.135 V to 4.4 V (3.3 V +1.1V/-0.165 V)
Temperature
  • Operating (from TIA/EIA/IS-98-D): -25°C to 60°C (-13°F to 140°F)
    Non-operating, 96 hours (from MIL-STD 202 Method 108): -40°C to 85°C (-40°F to 185° F)
95% relative humidity for 48 hours @ 85°C (185°F)
LED activity
HP lt4112 LTE/HSPA+ Gobi 4G module
    • 2100 MHz (Band I)
    • 1800 MHz (Band III)
    • 850 MHz (Band V)
    • 2600 MHz (Band VII)
    • 900 MHz (Band VIII)
    • 800 MHz (Band XX, DD800)
  • WCDMA/HSDPA/HSUPA/HSPA+ all bands with diversity
    • 2100 MHz (Band I)
    • 800 MHz (Band V)
  • GSM/GPRS/EDGE
    • 850 MHz (Band V)
Maximum data rates
  • LTE (Category 3): 100Mbps (Download), 50Mbps (Upload)
  • DC-HSPA+: 42Mbps (Download), 5.76Mbps (Upload)
  • HSPA+: 21.6Mbps (Download), 5.76Mbps (Upload)
  • EDGE: 236.8kbps (Download), 236.8kbps (Upload)
  • GPRS: 85.6kbps(Download), 85.6kbps (Upload)
GPS
Standalone
GPS bands
  • GLONASS 1596-1607 MHz
  • LTE: +23 dBm (+/- 2 dBm)
  • WCDMA: +23.5 dBm (+/- 1 dBm)
  • GPRS Band II, III: +29.5 dBm (+/- 1 dBm)
  • GPRS Band V, VIII: +32.5 dBm (+/- 1 dBm)
  • EGPRS Band II, III: +26.5 dBM (+/-1.5 dBm)
  • EGPRS Band V, VIII: +27.5 dBM (+/-1.5 dBm)
  • WCDMA: 1,100 mA (peak); < 800 mA (average)
  • EGPRS: 2,800 mA (peak); < 700 mA (average)
3 mA
Power management
Antenna type
Form factor
  • M.2
  • USB 2.0 interface
6 g (0.013 lb)
Operating voltage
3.135 V to 4.4 V (3.3 V +1.1 V/-0.165 V)
Temperature
  • Operating (from TIA/EIA/IS-98-D): -10°C to 55°C (14°F to 131°F)
LED activity
Wireless LAN standards
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
2.4 GHz
Data rates
  • 802.11b
    • 1Mbps
    • 2Mbps
    • 5.5Mbps
    • 11Mbps
  • 802.11g
    • 6Mbps
    • 9Mbps
    • 12Mbps
    • 18Mbps
    • 24Mbps
    • 36Mbps
    • 48Mbps
    • 54Mbps
  • 802.11n: many possible data rates, ranging from 6 Mbps to 300 Mbps, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
Modulation
  • Direct Sequence Spread Spectrum DBPSK
  • DQPSK
  • CCK
  • OFDM
  • BPSK
  • QPSK
  • 16-QAM
  • 64-QAM
Security
  • Supports 64- and 128-bit WEP
  • WPA
  • WPA2
  • Hardware-accelerated AES
  • 802.1x authentication types EAP-TLS
  • EAP-TTLS
  • PEAP-GTC
  • PEAP-MSCHAPv2
  • LEAP
  • EAP-FAST
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between access points
Output power
13.5 dBm, nominal
Power consumption
  • Transmit: 2.0 W (max)
  • Receive: 1.6 W (max)
  • Associated to Access Point, Idle: 250 mW nominal
  • Wireless Button Off: 100 mW nominal
  • Radio disabled: 75 mW nominal
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity
  • 72.2Mbps: -70 dbm
  • 54Mbps: -74 dBm
  • 11Mbps: -88 dBm
  • 1Mbps: -95 dBm
Antenna connections
High efficiency antenna with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express Half-MiniCard 1.2
6 g (0.013 lb)
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Operating voltage
3.3v +/- 9%
Temperature
  • Operating: -10°C to 70°C (14°F to 158°F)
  • Non-operating: -40°C to 80°C (-40°F to 176°F)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
  • LED Off - Radio OFF
  • Solid LED On - Radio ON
Atheros 802.11b/g/n (1x1) and Bluetooth 4.0 combo
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
2.402 GHz - 2.482 GHz
Data rates
  • 802.11b
    • 1Mbps
    • 2Mbps
    • 5.5Mbps
    • 11Mbps
  • 802.11g
    • 6Mbps
    • 9Mbps
    • 12Mbps
    • 18Mbps
    • 24Mbps
    • 36Mbps
    • 48Mbps
    • 54Mbps
  • 802.11n: card will support rates for NSS=1 for RX and TX for 20 MHz channels. Short and long guard interval shall be supported.
Modulation
  • Direct Sequence Spread Spectrum BPSK
  • QPSK
  • CCK
  • 16-QAM
  • 64-QAM
Security
  • Support for WPA and WPA2
  • Support for CCX version up to and including CCXv5
  • Support for the following EAP types
    • EAP-TLS
    • EAP-PEAPv0
    • EAP-PEAPv1
    • EAP-PEAPv2
    • EAP-FAST
    • EAP-SIM
  • Support for using both machine and user credentials in a single profile. The same profile must be able to be used both before user login and after user login
  • Support the use of Windows Domain credentials IP provider shall have support for an auto-logon to Windows using a PLC and LEAP via the IP provider UI
  • Must have Windows Single Sign On support so that customers can use the WLAN as their primary domain network. With regard to SSO, network association and authentication must occur and be successful before Windows domain authentication is attempted
  • Support for use of the UI client in a user account with limited local security privileges
  • Client service / profile manager must support the WiFi Alliance's WiFi Protected Setup specification
  • Any credentials saved in a profile must be done securely such that they cannot be re-used by any other user or machine.
Roaming
Output power
13.5 dBm , minimum
Power consumption
Power management
  • ACPI
  • PCI Express compliant power management 802.11 compliant power saving mode
  • 802.11b:
    • -95 dBm (1Mbps)
    • -93 dBm (2Mbps)
    • -91 dBm (5.5Mbps)
    • -88 dBm (11Mbps)
  • 802.11g:
    • -90 dBm (6Mbps)
    • -89 dBm (9Mbps)
    • -87 dBm (12Mbps)
    • -85 dBm (18Mbps)
    • -82 dBm (24Mbps)
    • -79 dBm (36Mbps)
    • -76 dBm (48Mbps)
    • -74 dBm (54Mbps)
  • 802.11n
    • -70dBm (72.2Mbps)
Antenna type
Form factor
Dimensions
Operating voltage
3.3v +/- 10%
Temperature
Altitude
LED activity
  • Solid LED On - RadioON
Bluetooth specification
  • V4.0 High Speed
  • V2.1+EDR
  • Backwards compatible:
    • V1.1
    • V1.2
    • V2.0
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3Mbps data rate; throughput up to 2.17Mbps
  • Synchronous connection oriented links up to 3, 64kbps, voice channels
  • Asynchronous Connection less links 2178.1kbps/177.1kbps asymmetric or 1306.9kbps symmetric
Transmit power
-6 dBm to 4 dBm (Bluetooth Class II)
Better than -80 dBM at 0.1 % raw bit error rate
Power consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep <17 mW
Antenna
Internally integrated within module
Range
Up 10 m (33 ft)
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software supported
  • Broadcom bluetooth for Windows
  • Microsoft Windows bluetooth software
Link topology
  • Point to Point
  • Multipoint Pico Nets up to 7 slaves
Security
Full support of bluetooth security provisions
Power management
  • Microsoft Windows ACPI, and USB Bus support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C
  • Section 15.247 & 15.249 ETS 300 328
  • ETS 300 826 Low Voltage Directive IEC950 UL
  • CSA
  • CE Mark
Bluetooth profiles supported
  • Generic Access Profile (GAP)
  • Service Discovery Application Profile (SDAP)
  • Serial Port Profile (SPP)
  • Dial_Up Networking Profile (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • Generic Audio/Video Distribution Profile (GAVDP)
  • Advanced Audio/Video Distribution Profile (A2DP)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Basic Printing Profile (BPP)
  • VDP (Video Distribution Profile)
  • AVRCP (Audio Video Remote Control Profile)
Broadcom 802.11 a/b/g/n (2x2) with Bluetooth v4.0 combo
  • IEEE 802.11a IEEE
  • 802.11b IEEE
  • 802.11g IEEE 802.11n
Interoperability
Wi-Fi certified
Frequency band
  • 802.11b/g/n
    • 2.402 - 2.482 GHz
  • 802.11a/n
    • 4.9 - 4.95 GHz (Japan)
    • 5.15 - 5.25 GHz
    • 5.25 - 5.35 GHz
    • 5.47 - 5.725 GHz
    • 5.825 - 5.850 GHz
    • 2.402 - 2.482 GHz
Data rates
  • 802.11a
    • 6Mbps
    • 9Mbps
    • 12Mbps
    • 18Mbps
    • 24Mbps
    • 36Mbps
    • 48Mbps
    • 54Mbps
  • 802.11b
    • 1Mbps
    • 2Mbps
    • 5.5Mbps
    • 11Mbps
  • 802.11g
    • 6Mbps
    • 9Mbps
    • 12Mbps
    • 18Mbps
    • 24Mbps
    • 36Mbps
    • 48Mbps
    • 54Mbps
  • 802.11n: card will support rates for NSS=1 and NSS=2 for RX and TX for 20 and 40 MHz channels. Short and long guard interval shall be supported
Modulation
  • QPSK
  • CCK
  • 16-QAM
  • 64-QAMc
Security
  • IEEE and WiFi compliant 64 / 128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES
  • WPA2 certification IEEE 802.11i
  • Cisco Certified Extensions, all versions through V5 WAPI
Roaming
Output power
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
  • Maximum output power must be able to achieve modular regulatory certification with notebooks that have antennas >20cm from the user and peak gain of +3 dBi at 2.4 GHz and +4 dBi at 5 GHz
Power consumption
  • Idle mode (PSP): 250 mW (WLAN Associated)
  • Idle mode: 100 mW (WLAN unassociated)
Power management
  • ACPI and PCI Express compliant power management
  • 802.11b
    • -95 dBm (1Mbps)
    • -93 dBm (2Mbps)
    • -91 dBm (5.5Mbps)
    • -88 dBm (11Mbps)
  • 802.11a/g
    • -90 dBm (6Mbps)
    • -89 dBm (9Mbps)
    • -87 dBm (12Mbps)
    • -85 dBm (18Mbps)
    • -82 dBm (24Mbps)
    • -79 dBm (36Mbps)
    • -76 dBm (48Mbps)
    • -74 dBm (54Mbps)
  • 802.11n
    • -69 dBm (72.2Mbps)
    • -66 dBm (300Mbps)
Antenna type
  • High efficiency antenna with spatial diversity, mounted in the display enclosure
  • Two embedded dual band 2.4/5 GHz antennas are provided to the card to support WLAN MIMO communications
  • Bluetooth communications
Form factor
Dimensions
3.3 g (0.007 lb)
Operating voltage
3.3v +/- 9%
Temperature
Altitude
LED activity
  • V4.0 High Speed
  • V2.1+EDR
    • V 1.1
    • V 1.2
    • V 2.0
  • Synchronous Connection Oriented links up to 3, 64kbps, voice channels
  • Asynchronous Connection Less links 2178.1kbps/177.1 kbps asymmetric or 1306.9kbps symmetric
Transmit power
Power consumption
  • Peak (Tx) 330 mW
  • Peak (Rx) 230 mW
  • Sleep <17 mW
Antenna
Range
Up to 10 m (Up to 33 ft)
  • USB 2.0 compliant
Link topology
  • Point to Point
Security
Full support of Bluetooth Security Provisions
Power management
  • Support Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Certifications
  • All necessary regulatory approvals for supported countries, including:
    • CSA
    • CE Mark
  • FAX Profile (FAX)
Mobile Broadband is an optional feature sold separately or as an add on feature. Connection requires wireless data service contract, network support, and is not available in all areas. Contact service provider to determine the coverage area and availability. Connection speeds will vary due to location, environment, network conditions, and other factors.
4G LTE not available on all products, in all regions and only available on products featuring Intel processors. WWAN use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds will vary due to location, environment, network conditions, and other factors.
Audio/multimedia - dts sound+ specifications
  • Implementation: IDT 92HD91
  • Function key volume controls:
    • Volume up
    • Volume down
    • Mute
  • Full duplex: Yes
  • Microphone in: Stereo
  • Headphone/Line out: Stereo
  • Integrated microphone: Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
  • Frequency response: 20 Hz - 20 kHz
  • Signal to noise ratio: >85 dB
  • Total harmonic distortion: 0.01%
  • Noise floor: -110 dB
  • Play/Record sampling rate(s): 8 kHz - 48 kHz
  • DAC:
    • 16 bit
    • 20 bit
    • 24-bit
    ADC:
    • 16 bit
    • 20-bit
  • Power rating: 2 W
  • Impedance: 4 Ohms
Power specifications
HP 65 W Smart ac adapter
Dimensions
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
280 g (0.62 lb)
Input
  • 100 to 240 Vac
  • Input efficiency: 87% min at 115 Vac
  • Input frequency range: 47 to 63 Hz
  • Input ac current: 1.7 A at 90 Vac, 0.85 A at 180 Vac
Output
  • Output power: 65 W dc
  • output: 18.5 V
  • Hold-up time: 5 msec at 115 V ac input
  • Output current limit: <11A, Over voltage protection- 29V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Temperature
  • Operating: 0°C to 40°C (32°F to 104°F)
  • Non-operating (storage): -20°C to 65°C (-4°F to 149°F)
Altitude
0 to 3,048 m (0 to 10,000 ft)
Humidity
20% to 80%
Storage Humidity
10% to 90%
EMI and safety certifications
  • CE Mark - full compliance with LVD and EMC directives
  • Worldwide safety standards
    • IEC60950
    • EN60950
    • UL60950
    • Class1
    • SELV
  • Agency approvals
    • C-UL-US
    • NORDICS
    • DENAN
    • EN55022 Class B
    • FCC Class B
    • CISPR22 Class B
    • CCC
    • NOM-1 NYCE
  • MTBF - over 200,000 hours at 25°C ambient condition
HP 9-cell (100 WHr) Lithium-Ion primary battery
Dimensions (H x W x L)
2 x 6.6 x 20.5cm (0.8 x 2.4 x 8.1in)
Weight (max)
0.488 kg (1.1lb)
Cells type
Lithium-Ion
Energy
  • Voltage: 11.25 V
  • Amp-hour capacity: 8.85 Ah
  • Watt-hour capacity: 100 Wh
Temperature
  • Operating (Charging): 0°C to 45°C (32°F to 113°F)
  • Operating (Discharging): -10°C to 50°C (14°F to 122°F)
  • Non-operating: -20°C to 50°C (-4°F to 122°F)
Battery Re-Charge time
  • System in Off or Standby mode: 3.5 to 5 hours
  • System On: 4 to 7 hours
Fuel Gauge LED
No
1 year
Compatible with optional travel battery
Yes
HP 6-cell (55 WHr) Lithium-Ion primary battery
2.0 x 4.7 x 20.5cm (0.8 x 1.8 x 8.0 in)
Weight (max)
0.313 kg (0..70 lb)
Cells/type
Lithium-Ion
Energy
  • Voltage: 10.8 V
  • Amp-hour capacity: 5.1Ah
  • Watt-hour capacity: 55Wh
Temperature
  • System in Off or Standby mode: 2.5 hours
  • System On: 3 to 5 hours
Fuel Gauge LED
No
1 year
Yes
HP 6-cell (55 WHr) Long Life primary battery
2.0 x 4.7 x 20.5cm (0.8 x 1.8 x 8.0in)
Weight (max)
0.323 kg (0..72 lb)
Cells/type
Lithium-Ion
Energy
  • Voltage: 10.8 V
  • Amp-hour capacity: 5.1 Ah
  • Watt-hour capacity:55 Wh
Temperature
Fuel Gauge LED
No
3 years
Yes
HP 3-cell (33 WHr) Lithium-Ion primary battery
TBD cm (TBD in)
Weight (max)
TBD kg (TBD lb)
Cells/type
Lithium-Ion
Energy
  • Voltage: 11.1 V
  • Amp-hour capacity: 2.95Ah
  • Watt-hour capacity: 33Wh
Temperature
  • Operating (Discharging): -10°C to 60°C (14°F to 140°F)
  • System in Off or Standby mode: TBD hours
  • System On: TBD hours
Fuel Gauge LED
No
1 year
Physical specifications
Dimensions (W x D x H)
34.0 x 23.7 x 2.53 (front)/2.90 (rear) cm (13.39 x 9.33 x 0.99 (front)/1.14 (rear) in)
  • Starting at 2.0 kg (4.40 lb) with weight saver (weight will vary by configuration)
  • Starting at TBD kg (TBD lb) with optical drive (weight will vary by configuration)
Software/OS
Feature
Preinstalled
  • Windows 8 641
  • Windows 8 Pro 641
  • Windows 7 Professional 32 (available through downgrade rights from Windows 8 Pro 32)2
  • Windows 7 Professional 64 (available through downgrade rights from Windows 8 Pro 64)2
  • Windows 7 Professional 323
  • Windows 7 Professional 643
  • Windows 7 Home Premium 323
  • Windows 7 Home Premium 643
  • SUSE Linux Enterprise Desktop 11
  • FreeDOS 2.0
Preinstalled software with Windows Operating System
  • BIOS
    • HP driveLock/HP automatic drive lock
    • HP BIOS protection
    • HP Disk Sanitizer
    • HP SpareKey
    • Update via Network
    • Master Record Security
    • Power On Authentication
    • Pre-Boot Security
    • Secure Erase
    • Hybrid Boot
    • Measured Boot
    • Secure Boot
    • Absolute Persistence Module
  • MultiMedia
    • CyberLink PowerDVD
    • CyberLink Power2Go (Optical drives)
    • CyberLink YouCam BE (Windows 7 only)
  • Communication
    • HP Connection Manager (Windows 7 only)
    • HP GPS and Location (Windows 7 only)
    • HP Mobile Connect (Windows 8 only)
    • HP Wireless Hotspot (Windows 8 only)
    • Intel WiDi Software
    • HP Roaming Alert (Windows 8 only)
    • Intel My WiFi and Wireless Drivers
  • HP value add software
    • HP 3D DriveGuard
    • HP ePrint Driver (HP Exclusive)
    • HP PageLift (HP Exclusive)
    • HP Recovery Manager (Windows 7 only)
    • HP Support Assistant
    • HP Recovery Disc Creator (Windows 7 only)
    • UEFI System Diagnostics (Windows 8 only)
  • Security (Standard)
    • HP Client Security
    • HP Credential Manager
    • HP Password Manager
    • HP Drive Encryption (FIPS 140-2)
    • HP Trust Circles Standard
    • HP Device Access Manager with Just In Time Authentication
    • TPM 1.2 Embedded Security Chip (Common Criteria EAL4+ Certified)
    • HP File Sanitizer
    • HP Spare key
    • Integrated Smart Card Reader (FIPS 201)
    • Security lock slot
    • Security screw for bottom access door
    • Microsoft Security Essentials (Windows 7)
    • Microsoft Defender (Windows 8)
    • HP Fingerprint sensor
1: Not all features are available in all editions of Windows 8. Systems may require upgraded and/or separately purchased hardware, drivers and/or software to take full advantage of Windows 8 functionality. See http://www.microsoft.com for details.
2: This system is preinstalled with Windows® 7 Pro software and also comes with a license and media for Windows 8 Pro software. You may only use one version of the Windows software at a time. Switching between versions will require you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of your data.
3: Not all features are available in all editions of Windows 7. This system may require upgraded and/or separately purchased hardware to take full advantage of Windows 7 functionality. See http://www.microsoft.com/windows/windows-7/ for details.
Environmental data specifications
Eco-Label certifications & declarations
  • IT ECO declaration
  • US ENERGY STAR EPEAT
  • Gold registered in the United States
Security specifications
HP Fingerprint reader
  • Mobile voltage operation: 3.0 V - 3.6 V
  • Operating temperature: -10° - 75°C (14°F - 167°F)
  • Current consumption image: 36 mA peak
  • Low latency wait for finger: 950 uA
  • Capture rate: 3000. lines/sec
  • ESD resistance: IEC 61000-4-2 4B (±15KV)
  • Detection matrix:
    • 200*1 (plus another secondary line)
    • 508 dpi
    • 12*3 mm sensor area
Safety certifications specifications
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC compliance: Yes
  • ENERGY STAR: Select models1
  • EPEAT: Registered TBD in United States2
  • ICES: Yes
  • Australia / NZ A-Tick compliance: Yes
  • CCC: Yes
  • Japan VCCI compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian compliance (ICCP): Yes
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
  • CE Mark: Full compliance with LVD and EMC directives
    • IEC60950
    • EN60950
    • UL60950
    • Class1
    • SELV
  • Agency approvals
    • C-UL-US
    • NORDICS
    • DENAN
    • EN55022 Class B
    • FCC Class B
    • CISPR22 Class B
    • CCC
    • NOM-1 NYCE
  • MTBF - over 200,000 hours at 25°C ambient condition.
1: Configurations of the HP ProBook 645 and HP ProBook 655 that are ENERGY STAR qualified are identified as HP ProBook 645 ENERGY STAR and HP ProBook 655 ENERGY STAR on HP websites and on www.energystar.gov.
2: EPEAT registration varies by country. See www.epeat.net for registration status by country. EPEAT status listed above applies to U.S.
Important links
List of available documents for the HP ProBook 645 G1 Notebook PC:
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
