    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP Printers - Printing from Android Smartphones or Tablets
This document is for HP network-connected or Wi-Fi Direct printers and Android smartphones or tablets.
Print from your Android OS 5.0 or later device to your printer using the HP Print Service Plugin.
Step 1: Install the HP Print Service Plugin
Install the HP Print Service Plugin on your Android OS 5.0 or later, and then turn on the plugin.
Menus, icons, and the location of the print settings vary by Android version and device manufacturer.
  1. Confirm your Android device is connected to the same network as your printer, or that Wi-Fi Direct on your printer and Android device is enabled.
  2. On your Android device, install or update the HP Print Service Plugin (in English).
  3. Once the installation or update is complete, choose your Android device to turn on the plugin:
    • Android 7 (Nougat) and later devices: The HP Print Service Plugin turns on automatically after installation. Continue with these steps.
    • Android 6 (Marshmallow) and earlier devices: Tap Settings, search for and open HP Print Service, and then tap On.
  4. Turn off any other print service plugins, if necessary.
Your Android device is now ready to print using the HP Print Service Plugin.
Refer to these frequently asked questions for more information about the HP Print Service Plugin for Android devices.
