HP ProDesk 405 G1 Microtower Business PC - Specifications
Physical specifications
Specification
Chassis (W x D x H)
182.9 x 402 x 357 mm (7.2 in x 15.82 in x 14.05 in)
Approximate weight
7.15 kg (15.75 lb)
Power specifications
Specification
Operating voltage range
90-264 V
Rated voltage range
100-240 V
Rated line frequency
50-60 Hz
Operating line frequency
47-63 Hz
Standard efficiency
300 W active PFC(230 V ac input only)
High efficiency
300 W active PFC EStar 6
Graphics specifications
Integrated AMD Radeon HD 8240, 8330 & 8400 graphics
Specification
Memory
Variable and user selectable in BIOS settings
Controller clock speed
Variable depending on the installed APU model
Maximum color depth
32 bpp (8-8-8-8)
Multidisplay support
Yes (2)
Graphics /API support
DX 11.1, Shader model 5, UVD 4.2, VCE 2.0, OpenGL 4.2 (4.1+), OpenCL 1.2, and Directcompute 11
Output connectors
1 VGA and 1 DVI-D (with HDCP support)
1: other resolutions may be available but are not recommended as they may not have been tested and qualified by HP
AMD Radeon HD 8470 graphics card
Specification
Form factor
Full height
Graphics controller
AMD Radeon HD 8470
Core clock
775 MHz
Memory clock
900 MHz
Memory
2GB, DDR3, 64-bit wide
Bus type
PCIe Gen2
Max. power
< 30 W
Power source cupport
12V and 3.3 V
3D API support
DX11
HDCP support
Yes
Display maximum resolution
  • Digital 2560 x 1600
  • Analog 2048 x 1536
Supported graphics APIs
DX11, OpenGL, full 1080p BD (H264) playback in hardware, HDMI 1.4 support
NVIDIA NVS 310 graphics card
Specification
Form factor
Low Profile: 2.713 × 6.15 in
Graphics controller
NVIDIA NVS 310
Memory clock
875 MHz
Memory size
512 MB DDR3
Memory bandwidth
14 GB/s
Maximum power
19.5 W
Up to 2560 x 1600 (digital display) per display
Display output
Up to 2 displays in the following configurations
  • DisplayPort output:
    1. Drives two DisplayPort enabled digital display at resolutions up to 2560 × 1600 at 60 Hz with reduced blanking, when connected natively using the 2 DisplayPort connectors on the NVS 310 graphics card
    2. Supports 2 monitors up to resolution of 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort Multi-Stream topology technology.
  • DVI-D output:
    1. Drives two digital display at resolutions up to 1920 × 1200 at 60 Hz with reduced blanking using DisplayPort to DVI-D single-link cable adaptors
    2. Drives two digital display at resolutions up to 2560 × 1600 at 60 Hz with reduced blanking using DisplayPort to DVI-D dual-link cable adaptors
  • HDMI output: NVS 310 is capable of driving two high definition (HD) panels up to resolutions of 1920 × 1080P at 60 Hz using DisplayPort to HDMI cable adaptors
  • VGA display output: Drives two analog display at resolutions up to 1920 × 1200 at 60 Hz using DisplayPort to VGA cable adaptors
NVIDIA GeForce GT630 graphics card
Specification
Form factor
PCIe x16 card
Graphics controller
NVIDIA Kepler architecture GPU
Core clock
875 MHz
Memory clock
891 MHz
Memory size
2GB DDR3 128 bit
Memory bandwidth
28.5GB/s
2560 x 1600 digital, 2048 x 1536 analog
Display support
Integrated 400 MHz RAMDAC
NVIDIA NVS 315 1GB PCIe x 16 graphics card
Specification
Form factor
Graphics controller
NVIDIA NVS 315
Memory clock
875 MHz
Memory size
512MB DDR3
Memory bandwidth
14 GB/s
Connectors
DMS-59 , with support for dual VGA, dual DVI or dual DisplayPort with the appropriate adapter cable
Up to 2048 x 1536 VGA; 1920 x 1200 DVI; 2560 x 1600 DisplayPort
Display output
  • Dual DVI : Drives two DVI displays using optional HP DMS59 DVI Dual-head connector cable DL139A
  • Dual DisplayPort : Drives two DisplayPort using optional HP DMS-59 to Dual DisplayPort kit XP688AA
  • Dual VGA : o Drives two analog using the included HP DMS-59 to Dual VGA Cable
AMD Radeon HD 8350 1GB PCIe x16 DH graphics card
Specification
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8350
Core clock
GPU engine operates at 523 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
875 MHz
HDCP support
Yes
Digital 1920 x 1200, Analog 2048 x 1536
AMD Radeon HD 8490 1GB PCIe x16 graphics card
Specification
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8490
Core clock
GPU engine operates at 875 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
900 MHz
HDCP support
Yes
Digital 2560 x 1600, Analog 2048 x 1536
Memory specifications
Specification
Form factor
Microtower
Type
  • DDR3 non-ECC
  • Up to 1600 m
Maximum
16GB
Number of slots
2 UDIMM
Hard disk and solid state storage specifications
HP 1-TB SATA 6G 2.5 in 8GB Solid State Hybrid Drive (SSHD)
Specification
Formatted capacity
1TB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Solid State Hybrid Drive (SSHD) technology with NAND flash
Interface
Serial ATA (SATA)
Cache buffer
64MB
NAND flash Commercial Multilevel Cell (cMLC)
8GB
Number of sectors
976,773,168
Seek time (typical reads)
Single track:
2.0 ms
Average:
12 ms
Height
0.374 +/-.008 in (9.5 +/- 0.2 mm)
Width
2.750 +/- 0.010 in (69.85 +/- 0.25 mm)
Length
3.951 +0.008 / -0.010 in (100.35 +0.20 / -0.25 mm)
0.254 lb/115 g (max)
Operating temperature
0° to 60°C (32° to 140°F)
HP 500GB SATA 6G 2.5 in 8GB Solid State Hybrid Drive (SSHD)
Specification
Formatted capacity
500GB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
Interface
Serial ATA (SATA)
Cache buffer
64MB
8GB
Number of sectors
976,773,168
Single track:
2.0 ms
Average:
12 ms
Height
0.268 +/-.008 in (6.8 +/- 0.2 mm)
Width
Length
0.209 lb/95 g (max)
HP 128GB Solid State Drive
Specification
Unformatted capacity
128GB
Architecture
Multi Level Cell (MLC) NAND
Interface
SATA 6 GB/sec
Dimensions (W x H x D)
2.75 x 0.276 x 3.96 in (6.985 x 0.7 x 10.05 cm)
0.16 lb (73 g)
Bandwidth performance
Sustained sequential read:
Up to 450 MB/s
Sustained sequential write:
Up to 260 MB/s
Random read (4KB):
up to 46K IOPs
Random write (4KB):
up to 56K IOPs
Latency
Read:
55ms (TYP)
Write:
55ms (TYP)
Power
DC power requirement:
  • Min 4.5 V
  • Max 5.5 V
Total power consumption:
  • 160 mW (Active)
  • <85 mW (Idle)
Useful drive life
1.2 million device hours
Environmental (all conditions, non-condensing)
Operating temperature:
0° to 70°C (32° to 158°F)
Relative humidity (operating):
5% to 95%
Shock:
1,500 G/1.0 ms
1: For solid state disk drives, GB means 1 billion bytes. 128GB is the unformatted capacity of this drive before a portion of the drive is reserved for flash management features. Actual capacity will vary by content.
The product achieves a mean time between failure (MTBF) based on population statistics not relevant to individual units.
HP 256GB SATA 2.5 in Self-Encrypting (SED) Solid State Drive
Specification
256,186,209,271 bytes
Architecture
Self-Encrypting (SED) Solid State Drive with 25nm MLC NAND Flash and SATA interface
Interface
Serial ATA 2.0 (3.0 Gb/s)
NAND flash
25nm MLC NAND flash
Height
.275 in/7mm
Width
2.75 in/69.85 mm
Length
3.95 in/100.5 mm
0.161 lb (73 g)
Sustained sequential 128k Read:
Up to 450 MB/s
Sustained sequential 128k Write:
Up to 260 MB/s
Random 4k read:
Up to 46K IOPs
Random 4k write:
Up to 56K IOPs
Latency
Read:
55 µs
Write:
55 µs
Power
SATA power consumption:
160 mW (active average); <85 mW (idle average)
Useful drive life
72TB written, up to 40GB/day for 5 years
Relative humidity:
5% to 95%
Shock:
1,500 G/1 ms
HP 1-TB 7.2K rpm SATA 6.0Gb/s 3.5 inHard Disk Drive
Specification
Capacity
1,000,204,886,016 bytes
Rotational speed
7,200 rpm
Interface
Serial ATA 3.0 (6.0 Gb/s)
Buffer size
32MB
Logical blocks
1,953,525,168
Seek time (typical reads, includes controller overhead, including settling)
Single track:
2.0 ms
Average:
11 ms
Full stroke:
21 ms
Height (nominal)
1 in/2.54 cm
Width (nominal)
Media diameter: 3.5 in/8.89 cm
Physical size: 4 in/10.2 cm
5° to 55°C ( 41° to 131°F)
HP 2-TB 7.2K rpm SATA 6.0Gb/s 3.5 in Hard Disk Drive
Specification
2TB
Rotational speed
7,200 rpm
Interface
SATA 6Gb/s NCQ
Cache, Multisegmented (MB)
64MB
Seek time (average)
Read
<8.5 ms
Write
<9.5 ms
Height
1.028 in/26.11 mm
Width
4.0 in/101.6 mm
Depth
5.787 in/146.99 mm
1.38 lb/626 g
5° to 55°C ( 41° to 131°F )
Removable storage specifications
HP Blu-ray BDXL Writer Drive
Specification
Height
5.25 in, half-height, tray-load
Orientation
Either horizontal or vertical
Interface type
SATA
Disc capacity
Blu-ray: 128 GB QL, 100 GB TL, 50 GB DL or 25 GB standard DVD: 8.5GB DL or 4.7GB standard
Dimensions W x H x D (maximum)
5.8 x 1.7 x 7.1 in (14.8 x 4.2 x 18.0 cm) max
Weight (max)
2.1 lb (950g)
Performance
CD-ROM Read access time:
Random
140 ms (typical)
Full stroke
230 ms (typical)
BD-ROM Read access time
Random
150 ms (typical)
Full stroke
240 ms (typical)
Random
250 ms (typical)
Full stroke
350 ms (typical)
Startup time
(Time to drive ready from tray loading)
BD-ROM (SL/DL)
28S / 28S
BD-R (SL/DL/TL/QL)
28S / 28S / 40S / 40S
BD-RE (SL/DL/TL)
28S / 28S / 40S
DVD-ROM (SL/DL)
18S / 18S
DVD-R (SL/DL)
25S / 25S
DVD-RW
25S
DVD+R (SL/DL)
25S / 25S
DVD+RW
25S
DVD-RAM
35S
CD-ROM
15S
CD Read speeds
CD-ROM up to 40X
CD-R up to 40X
CD-RW up to 40X
DVD Read speeds
DVD-RAM up to 5X
DVD+/-RW up to 10X
DVD+/-R up to 16X
DVD+/-R DL up to 8X
DVD-ROM up to 16X
Blu-ray Read speeds
DVD-ROM DL up to 8X
BD-ROM (SL/DL) up to 8X
BD-R (SL/DL) up to 8X
BD-R (TL/QL) up to 6X
BD-RE (SL/DL) up to 6X
BD-RE TL up to 4X
CD Write speeds
CD-R up to 40X
CD-RW up to 24X
DVD Write speeds
DVD+/-R up to 16X
DVD+/-R DL up to 8X
DVD+RW up to 8X
DVD-RW up to 6X
DVD-RAM up to 5X
Blu-ray Write speeds
BD-R (SL/DL) up to 6X
BD-R (TL/QL) up to 4X
BD-RE (SL/DL/TL) up to 2X
Power
Source
SATA DC power receptacle
DC Power requirement
  • VDC ± 5%-100 mV ripple p-p
  • 512 VDC ± 5%-200 mV ripple p-p
DC current
  • 5 VDC -1200 mA typical, 1500 mA maximum
  • 12 VDC -1000 mA typical, 1500 mA maximum
Environmental (all conditions non-condensing)
Temperature (operating)
5° to 50°C (41° to 122°F)
Relative humidity
10% to 90%
Maximum wet bulb temperature
30°C (86°F)
HP SuperMulti DVD Writer Drive
Specification
Height
5.25-inch, half-height, tray-load
Orientation
Interface type
SATA
5.8 x 1.7 x 6.9 in (14.8 x 4.2 x 17.5 cm) maximum
Weight (max)
2.1 lb (950g)
Performance
CD-ROM read access
Random
120 ms typical
Full Stroke
200 ms typical
DVD-rOM read access
Random
130 ms typical
Full Stroke
240 ms typical
CD Media read transfer
CD-ROM, CD-R read
Up to 6000 KB/s (40X)
CD-RW read
Up to 4800 KB/s (32X)
Digital/Analog audio playback
Up to 2400 KB/s (16X)
Digital audio extraction (CD-ROM, CD-R)
Digital audio extraction (CD-RW)
Video CD playback
DVD media read transfer
DVD Video DL (other than playback)
Up to 10800 KB/s (8X)
DVD+/-R
Up to 21600 KB/s (16X)
DVD+/-R DL
DVD+/-RW
DVD-RAM
Up to 6750 KB/s (5X)
Media compatibility
Media:
Read:
Write:
CD-ROM
Yes
No
CD-R
Yes
Yes
CD-RW
Yes
Yes
DVD-ROM
Yes
No
DVD-ROM DL
Yes
No
DVD-RAM
Yes
Yes
DVD+/-R
Yes
Yes
DVD+/-R DL
Yes
Yes
DVD+/-RW
Yes
Yes
Power supply
Source
5 VDC ± 5%
100 mV ripple p-p
12 VDC ± 5%
200 mV ripple p-p
DC current
5 VDC
  • 1000 mA (typical)
  • 1600 mA (max.)
12 VDC
  • 1200 mA (typical)
  • 2000 mA (max.)
Total drive power (Standby Mode)
<2.5 W
Rear panel
  • SATA power Connector, 15-pin
  • SATA data connector, 7-pin
  • Markings to identify each connector
Environmental conditions (all conditions non-condensing)
5° to 50°C(41° to 122°F)
Storage temperature
–30° C to 60°C(–22° F to 140°F)
Relative humidity
10% to 90%
30°C (86°F)
Processor specifications
Specification
Processor
AMD Quad-Core A6 APU with AMD Radeon high defination Graphics: AMD Quad-Core A6-5200 Accelerated Processor with AMD Radeon HD 8400 Discrete-Class Graphics (2.0 GHz 2MB L2 cache, 25 W)
Networking and communications specifications
Realtek RTL8151GH-CG GbE LOM network adapter
Specification
Connector
RJ-45
System interface
Integrated on PCA
Controller
Realtek RTL8151GH-CG Gigabit Ethernet Controller
Memory
16 KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mbps
IEEE compliance
  • 802.1P
  • 802.1Q
  • 802.3
  • 802.3ab
  • 802.3az
  • 802.3u
Bus architecture
PCI express
Data transfer mode
PCIe-based interface for active state operation (S0 state)
Power requirement
Requires 3.3 V and 1 V or just 3.3 V with integrated regulators power consumption 0.425 W
Network transfer mode
  • Full-duplex
  • Half-duplex (not supported for the 1000BASE-T transceiver)
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mb/s
  • 10BASE-T (full-duplex) 20 Mb/s
  • 100BASE-TX (half-duplex) 100 Mb/s
  • 100BASE-TX (full-duplex) 200 Mb/s
  • 1000BASE-T (full-duplex) 2000 Mb/s
Environmental
  • Operating temperature: 0° to 70°C(32° to 158°F)
  • Operating humidity: 60% RH
Management
WOL, auto MDI crossover, PXE, Muti-port teaming, Advanced cable diagnostic
Intel ethernet I210-T1 gigabit network adapter
Specification
Connector
RJ-45
System interface
PCI express x1
Controller
Intel I210 Gigabit ethernet controller
Memory
Integrated dual 48K configurable transmit receive FIFO Buffers
10/100/1000 Mb/s
IEEE Compliance
  • 802.1P
  • 802.1Q
  • 802.3
  • 802.3ab
  • 802.3az
  • 802.3x flow control
Bus architecture
PCI-E 2.1
Data path width
X1, 250 MB/s, Bi-directional interface
Data transfer mode
Bus-master DMA
Hardware certifications
Full-duplex
FCC, B, CE, TUV-c, TUVus Mark canada and united states, TUV-GS Mark for european union
Power requirement
Aux 3.3 V, 3.0 W in 1000 base-T and 1.0 W in 100 base-T
Boot ROM support
  • Yes
  • 1000BASE-T (full-duplex) 2000 Mb/s (actual rate limited by PCI bus)
Environmental
  • Operating temperature: 0° to 55°C (32° to 132°F)
  • Operating humidity: 55°C (85% at 131°F)
Management
WOL, PXE, DMI, WFM 2.0
Intel dual band wireless-N 7260 802.11 a/b/g/n (2x2) wireless network interface connection
Specification
Wireless LAN standards
IEEE 802.11a/b/g/n
Interoperability
  • Wi-Fi certified (802.11 a/b/g/n WMM, WPA, WPA2 and WPS)
  • Cisco Compatible extensions program compliant with Microsoft Windows 7, Windows Vista and XP.
Frequency band
802.11b/g/n: 2.402-2.482 GHz
802.11a/n:
  • 4.9 - 4.95 GHz (Japan)
  • 5.15 - 5.25 GHz
  • 5.25 - 5.35 GHz
  • 5.47 - 5.725 GHz
  • 5.825 - 5.850 GHz
Antenna structure
2 transmit; 2 receive (2x2)
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: MCS 0 - MCS 15, (20 MHz, and 40 MHz)
Modulation
  • Direct sequence spread spectrum
  • CCK, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • IEEE and WiFi compliant 64 / 128 bit WEP encryption for a/b/g mode only
  • AES-CCMP: 128 bit in hardware
  • 802.1x authentication
  • WPA, WPA2: 802.1x. WPA-PSK, WPA2-PSK, TKIP, and AES.
  • WPA2 certification
  • IEEE 802.11i
  • Cisco certified extensions, all versions through CCX4 and CCX Lite
  • WAPI
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access point required)
Roaming
  • 2.4G: +13.5dBm minimum
  • 5G: +12dBm minimum
Power consumption
  • Transmit: 2.0 W
  • Receive: 1.6 W
  • Idle mode: 250 mW (WLAN associated) In power save polling mode and on battery power.
  • Idle mode: 100 mW (WLAN unassociated)
  • Radio off: 100 mW (WLAN unassociated)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Power management
Receiver sensitivity
  • 802.11g:- 90 dBm (6 Mb/s), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mb/s), -74 dBm (54 Mb/s)
  • 802.11b:- 95 dBm (1 Mb/s), -93 dBm (2 Mb/s), -91 dBm (5.5 Mb/s), -88 dBm (11 Mb/s)
  • 802.11g:- 90 dBm (6 Mb/s), -89 dBm (9 Mb/s), -87 dBm (12 Mb/s), -85 dBm (18 Mb/s), -82 dBm (24 Mb/s), -79 dBm (36 Mb/s), -76 dBm (48 Mbps), -74 dBm (54 Mb/s)
Antenna connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form factors
PCI-Express Half-MiniCard
0.0068 lb (3.1 g)
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
Operating Voltage
3.3V +/- 9%
Operating:
Temperature
-10° to 70°C (14° to 158°F)
Humidity
10% to 90% (non-condensing)
Altitude
3,048 m (0 to 10,000 ft)
Non-operating:
Temperature
-40° to 80°C (-40° to 176°F)
Humidity
5% to 90% (non-condensing)
Altitude
15,240 m (0 to 50,000 ft)
LED Activity
LED Amber - Radio Off; LED White - Radio On
Audio specifications
High definition audio
Specification
Type
Integrated
HD stereo codec
Realtek 2-channel ALC221 codec
Audio input output ports
  • Front microphone-In (150-K ohm Input Impedance)
  • Rear Line-In/Microphone input (150-K ohm Input Impedance, function is configurable by audio driver)
  • Rear Line-Out(190 ohms Output impedance, expects at least a 10-K ohm load)
  • Front headphone-Out (0.5 Ohm Output impedance, expects at least a 32 ohm load) Front Microphone/Headphone jack is re-task able to provide microphone input, line-in or Headphone output to support connecting two headphones to the front of the system. When configured as a second front headphone output, both front headphone outputs are always driven with the same signal.
  • All ports are 3.5mm
Internal speaker amplifier
1.5 W amplifier for the internal speaker only. External speakers must be powered externally. Rear Line-in audio port is re-taskable as either Line-in or Microphone-In.
Multi-streaming capable
Multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes – Uses OS soft wavetable
Analog audio
Yes
number of channels on Line-Out
Stereo (Left & Right channels)
Internal speaker
Yes
External speaker jack
Yes
Environmental specifications
Operating
Temperature range
10° to 35°C (50° to 95°F)
Relative humidity
10-90% (non-condensing)
Maximum altitude (unpressurized)
3048 m (10,000 ft)
Non-operating
Temperature range
-30° to 60°C (-22° to 140°F)
Relative humidity
5% to 95%, 38.7°C max wet-bulb
9144 m (30,000 ft)
