HP Z Display Z27i 27-inch IPS LED Backlit Monitor Specifications
Product description
HP Z Display Z27i 27-inch IPS LED Backlit Monitor has a viewable area display with 2560 x 1440 resolution, plus full-screen support for lower resolutions: includes custom scaling for maximum image size while preserving original aspect ratio.
Product features
Feature
Model
Z27i
Type
27-inch IPS Gen 2
68.58 cm (27 in) widescreen
Backlit
LED
Maximum pixel clock speed
200 MHz
User programmable modes
Yes, 10
Anti-glare
Yes
Default color temperature
6500K
Plug and play
Yes
4-Way comfort adjust
Easily adjust the display in height, tilt, swivel and pivot for maximum comfort.
Detachable stand
Yes, ships detached
Tilt range
-5° to + 20° vertical
Swivel range
45°L to 45°R
Height adjustable
Yes, 0 to 120 mm
Pivot rotation
Yes, 90°
Panel specifications
Specification
Type
27-inch IPS Gen 2
Panel active area (W x H)
63 x 36.82 cm (24.8 x 14.49 in)
Backlit
LED
Panel type
Gen 2 IPS (Gen 2 technology, also called AH-IPS, enables lower power consumption)
Resolution
2560 x 1440 @ 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)
350 cd/m2
Contrast ratio (typical)
1,000:1
Dynamic contrast ratio (typical)
5,000,000:1
Response time (typical)
8 ms gray to gray
Pixel pitch
0.233 mm
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
16.7 million colors
Electrical specifications
Specification
Power supply
Internal
Input power
100 - 240 V 50/60 Hz
ENERGY STAR power1
38.62 W
Default power2
60 W
Maximum power3
75 W
Sleep/Off mode power
> 0.5 W
Power cable length
1.9 m (6.2 ft)
Video/other input/output specifications
Specification
Input connectors
VGA, DisplayPort 1.2 (1.1 compatible), DVI-D; HDMI 1.4; HDCP support on DisplayPort, DVI, and HDMI
Sync input
Separate synch
Video cables included
(1) DVI-D Dual-Link 1.8 m (5.9 ft), (1) DisplayPort 1.8 m (5.9 ft)
Self-powered USB hub
4-port USB 3.0 hub (cable included)
USB cable included
(1) USB 3.0 cable 1.8 m (5.9 ft)
Audio
Audio output connector for driving speakers
Physical specifications
Specification
Dimensions (W x D x H)
Unpacked with stand (lowest setting): 64.1 x 24.24 x 42.04 cm (25.24 x 9.55 x 15.55 in)
Unpacked without stand (head only): 64.1 x 6.55 x 37.92 cm (25.24 x 2.58 x 14.93 in)
Packaged: 75,5 x 31,5 x 47,1 cm (25,98 x 17.72 x 11.85 in)
Head Only: 5,3 kg (11.68 lb)
Unpacked: 7,6 kg (16.74 lb)
Packaged: 9,8 kg (21.6 lb)
Environmental specifications
Operating
Temperature
5° to 35°C (41 to 95°F)
Humidity
20% to 80% non-condensing
Altitude
0 to 5,000 m (16,404 ft)
Non-operating
Temperature
-20° to 60°C (-4 to 140°F)
Humidity
5% to 95%, 38.7° C max wet-bulb
Altitude
0 to 12,192 m (0 to 40,000 ft)
Energy consumption
Specification
115 V, 60 Hz
230 V, 50 Hz
100 V, 60 Hz
Normal operation
33.1 W
32.5 W
33.3 W
Sleep
0.4 W
0.4 W
0.4 W
Off
0.4 W
0.4 W
0.4 W
Heat dissipation
Specification
115 V, 60 Hz
230 V, 50 Hz
100 V, 60 Hz
Normal operation
113 BTU/h
111 BTU/h
114 BTU/h
Sleep
1 BTU/h
1 BTU/h
1 BTU/h
Off
1 BTU/h
1 BTU/h
1 BTU/h
Safety certifications
certifications
Eco-label certifications & declarations
  • IT ECO declaration
  • US ENERGY STAR
  • TCO 6.0
  • EPEA
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
