HP t510 Flexible Thin Client - "There is not enough space" Error Message Displays When Copying a Large File
This document pertains to the t510 Flexible Thin Client.
When copying a large file from the server to a redirected USB device, the error message There is not enough space displays.
This issue occurs when file size is larger than the volume size of the t510 thin client, but smaller than the attached USB storage device.
Install the Remote Desktop Add-on
To resolve this issue, download and install the Remote Desktop Add-on.
  1. Download and install the Remote Desktop 6.0 Add-On (SP63851), and then save it to a convenient location on your hard drive. Make a note of the location where the downloaded file is saved.
  2. Double-click the downloaded file and follow the on-screen instructions.
  3. After the installation is complete, restart the tablet.
