HP Photosmart C6300 Printers - Color or Black Ink Not Printing
This document is for HP Photosmart C6340, C6350, C6375, C6380, C6383, and C6888 All-in-One printers.
The printer is working, but the printed output is missing black or color ink, or the printed page is blank or has very little ink.
HP recommends that you use genuine HP ink or toner supplies. HP cannot guarantee the quality or reliability of non-HP or refilled cartridges. If you do not use genuine HP cartridges, the steps in this document might not resolve the issue. To check the authenticity of your cartridges, go to hp.com/go/anticounterfeit.
If using genuine HP ink cartridges does not resolve the issue, continue to the next step.
Step 2: Check estimated ink levels
Check estimated ink levels to see if any ink cartridges are critically low or empty. Ink must be available in each ink cartridge to run printhead-servicing tasks and prevent nozzles from clogging with ink.
Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low-ink levels, consider having a replacement ink cartridge available to avoid possible printing delays. You do not need to replace ink cartridges until print quality becomes unacceptable.
  1. Press the Setup button on the product control panel. The Setup Menu opens.
  2. Press the down arrow to select Tools, and then press OK. The Tools menu opens.
  3. Press the down arrow to select Display Estimated Ink Levels, and then press OK.
    The ink level indicator displays on the control panel.
    Figure : Ink level indicator on the control panel
  4. Press OK to return to the Tools menu.
  5. If necessary, press the Home button () to return to the main screen.
  • If none of the ink cartridges are low on ink, you do not need to replace them yet. Skip to the step to make sure the ink cartridges are properly vented and seated correctly.
  • If any of the ink cartridges are low on ink, continue to the next step to replace them.
Step 3: Replace any low or empty ink cartridges
Replace low or empty ink cartridges.
  1. Lift to open the ink cartridge access door until the door locks into place in the upright position.
    The carriage moves to the carriage access area.
    Figure : Opening the ink cartridge access door
    Image: Open the ink cartridge access door
  2. Wait until the carriage is idle and silent before you proceed.
  3. Press in the tab on the front of the ink cartridge, and then pull it up and out to remove it from its slot.
    Figure : Removing the ink cartridge from the slot
    Image: Remove the ink cartridge from the slot
    Do not lift the gray latch next to the carriage to remove the ink cartridges. Lifting the latch might result in incorrectly seated ink cartridges and printing problems. The latch must remain down in order to correctly remove the ink cartridges.
    Never turn off the printer when ink cartridges are missing. Make sure you replace any missing ink cartridges as soon as possible to avoid print quality issues and possible extra ink usage or damage to the ink system.
  4. Remove an ink cartridge from its package, and then pull the orange pull-tab straight back.
    Make sure you remove the orange pull-tab and plastic wrap completely before you remove the orange cap in the next step. Otherwise, ink might leak from the ink cartridge. When you remove the plastic wrap, the paper label on the top of the ink cartridge tears slightly, which is necessary to properly vent the ink cartridge.
    Figure : Removing the new ink cartridge from the plastic wrap
    Image: Pull the orange tab straight back
  5. Twist the protective orange cap counter-clockwise to snap it off the ink cartridge.
    Figure : Removing the orange cap from the new ink cartridge
    Image: Twist the orange cap to snap it off the ink cartridge
  6. With the nozzle and contacts facing down, slide the ink cartridge into its slot, and then press down on the ink cartridge until it snaps into place.
    Make sure the colored dot on the ink cartridge label matches the colored dot on the slot.
    Figure : Installing the new ink cartridge
    Image: Install the new ink cartridge
  7. If the ink cartridge does not snap into place, remove the ink cartridge from the carriage. Gently bend the tab away from the ink cartridge, and then reinsert the ink cartridge into the carriage.
    Be careful not to bend the tab out more than 1.27 cm (0.5 in). Moving the tab too far might damage the ink cartridge or cause the tab to break off.
      Figure : Bending out the ink cartridge tab
      Image: Adjust the ink cartridge tab
    1. Bend the tab away from the cartridge
    2. Do not bend the tab more than 1.27 cm (0.5 in)
  8. Repeat these steps for each ink cartridge that needs replacement.
  9. Close the ink cartridge access door.
    The carriage moves to the right side of the printer.
    Figure : Closing the ink cartridge access door
    Image: Close the ink cartridge access door
  10. Try the print job again.
If replacing any low or empty ink cartridges does not resolve the issue, continue to the next step.
Step 4: Make sure the ink cartridges are properly vented and seated correctly
If the vent on the top of the ink cartridge is clogged or obstructed, the ink cartridge might not work properly. Make sure the ink cartridges are properly vented and seated correctly.
    Do not lift the gray latch next to the carriage to remove the ink cartridges. Lifting the latch might result in incorrectly seated ink cartridges and printing problems. The latch must remain down in order to correctly install the ink cartridges.
  4. Locate and then examine the vent area on the top of the ink cartridge.
    Figure : Vent area on the top of the ink cartridge
    Image: Vent area on the top of the ink cartridge
  5. If the ink cartridge still has the orange pull-tab attached, pull to remove it.
    Figure : Orange pull tab
    Image: Orange pull tab.
  6. If the vent is clogged, use a straight pin to gently remove excess adhesive from the vent.
      Figure : Cleaning the clogged vent with a pin
      Image: Clean the clogged vent with a pin.
    1. Clogged vent
    2. With a straight pin, gently remove excess adhesive from the vent
    3. Unclogged vent
  7. Reinsert the ink cartridge. With the ink cartridge contacts facing the printhead, slide the ink cartridge into the empty slot. Press down on the ink cartridge until it snaps firmly into place.
    Make sure each ink cartridge is installed in the correct slot. Match the shape of the icon and the color of the ink cartridge with the slot that has the same shaped icon and color.
    Figure : Reinstalling the ink cartridge
    Image: Reinstall the ink cartridge
  8. Repeat these steps to inspect the vents on each of the ink cartridges.
  9. Make sure each ink cartridge is firmly in place in its slot. Run your finger along the top of the ink cartridges to feel for any that are protruding, and if any are, press down firmly until each ink cartridge snaps into place.
  10. Close the ink cartridge access door.
  11. Try the print job again.
If after making sure the ink cartridges are properly vented and seated correctly does not resolve the issue, continue to the next step.
Step 5: Clean the printhead
From the printer control panel, use an automated tool to clean the printhead.
To avoid issues that require cleaning the printhead, always turn the printer off with the Power button on the printer itself.
  1. On the printer control panel, press the Setup button .
  2. Press the down arrow to highlight Tools, and then press OK.
  3. Press the down arrow to highlight Clean Printhead, and then press OK.
    The printer cleans the printhead and then prints a test page.
  4. Evaluate the test page for print quality.
    Figure : Example of a Print Quality Report
    Image: Print Quality Report
    • If the print quality on the test page is satisfactory, return to the current print job.
    • If the print quality on the test page is unsatisfactory, continue with the process to perform a secondary cleaning of the printhead.
      There are two printhead cleaning stages. Complete both stages if necessary. If the printhead is badly clogged, it might require another cleaning cycle. If so, wait 30 minutes after the last cleaning stage to start the first stage of the cleaning process over again.
In general, if your printer is within warranty, so is the printhead. Additionally, if HP has replaced your printhead or if you have purchased a replacement, the replacement printhead is covered under warranty for 90 days, regardless of printer warranty. If you are not sure if your printhead is under warranty, see HP’s Warranty Check Tool to determine if your printer is still under warranty or refer to the receipt documentation that came with your replacement printhead.
  • If the printhead is in warranty, contact HP to see if the printer's condition warrants a replacement printhead based on the terms of your printer warranty. Do not continue with the following steps if your printhead is in warranty. Skip to the step to service the printer.
  • If the printhead is out of warranty, continue to the next step to manually clean the printhead.
Gather the following items:
  • A clean disposable container capable of holding enough water to submerge the printhead
  • Two clean lint free cloths such as coffee filters
  • Filtered or distilled water (tap or mineral water may contain contaminants that could damage the printhead)
  • A pan and stove or other means of heating water
  • Disposable gloves
  • Paper towels
When manually cleaning the printhead, the printhead nozzles are soaked in very warm water for no longer than ten minutes. Use these steps only as a last resort and if the printhead would be disposed of otherwise.
Manually cleaning the printhead should only be performed if the printhead is no longer under warranty.
  1. Set the pan on the stove, and then fill the pan with filtered or distilled water.
    Do not use alcohol or other solvents. This might damage the printhead, causing the printhead layers to separate, requiring replacement of the printhead.
  2. Heat the water until the water is very warm to the touch, but do not boil the water.
  3. Stack the paper towels at the bottom of the disposable container until the stack is about 6.5 mm (1/4 inch) deep.
  4. Pour the warm water from the pan into the disposable container so that it is 5 cm (2 inches) deep and covering the paper towels.
  5. Put on disposable gloves to prevent ink from transferring to your skin or clothes.
  6. Press the tab on the front of the ink cartridges to release them, and then lift the ink cartridges out of the printhead.
    Do not leave the ink cartridge outside the printer for longer than 30 minutes. The printhead and ink cartridges can be damaged by being exposed to air outside of the printer.
    Figure : Removing the ink cartridges
    Image: Remove the ink cartridge from the slot.
  7. Set the ink cartridges upside down on a paper towel.
    Figure : Placing the ink cartridges upside down
    Image: Place the ink cartridges upside down
  8. Lift the latch handle on the carriage until it stops, and then carefully lift up on the printhead to remove it from the printer.
    Figure : Removing the printhead
    Image: Remove the printhead
  9. Moisten one of the clean, lint-free cloths with some of the warm water and use it to clean the underside of the printhead. Repeatedly wipe the nozzle area gently until excess black or color ink does not transfer to the cloth. Do not press into the nozzle area as this can cause damage.
    Do not force water into the printhead, this can cause printhead delamination.
    Figure : Wiping the nozzles
    Image: Wipe the nozzles
  10. Place the printhead into the disposable container so that the bottom rests on the paper towels, and then let it soak for 10 minutes.
      Figure : Soaking the printhead
      Image: Soak the printhead
    1. Paper towels
    2. Water level
  11. Remove the printhead, and then gently wipe the excess water with a dry lint free cloth.
    Do not use a hair dryer to dry off the printhead. This could cause the nozzles to dry out and clog.
  12. Let the printhead air-dry on a paper towel for 15 minutes with the nozzles facing up.
    Do not use compressed air to blow out the printhead. This can cause delamination of the printhead.
    Figure : Printhead drying with the nozzles up
    Image: Printhead drying with the nozzles up
  13. Lower the printhead into the carriage, and then carefully lower the latch handle.
    Make sure the colored shapes on the sides of the printhead line up with the colored shapes on the carriage.
    Figure : Installing the new printhead
    Image: Install the new printhead
    Figure : Lowering the latch handle
    Image: Lower the latch handle
  14. With the ink cartridge contacts facing the printhead, slide the ink cartridge into the correct slot. The color-coded icons on the ink cartridge and in the printhead indicate the correct slot.
    Figure : Inserting the ink cartridge
    Image: Insert the ink cartridge.
  15. Repeat these steps for each ink cartridge.
If you encounter the 'Printhead Problem' error message, turn the printer off and back on again.
The automated printhead cleaning tool must run after manually cleaning the printhead.
Continue to the next step.
Step 9: Clean the printhead
From the printer control panel, use an automated tool to clean the printhead again after manually cleaning the printhead.
If cleaning the printhead does not resolve the issue, continue to the next step.
Step 10: Replace the printhead
If cleaning the printhead did not resolve the issue, order a new printhead from HP or an authorized retailer.
Wait until you have a new printhead assembly available before you remove the ink cartridges. HP recommends that you do not leave the ink cartridges outside the printer longer than 30 minutes. This could damage both the printer and the ink cartridges.
This information applies to all countries/regions, except Asia Pacific and United States.
If HP replaces your printhead assembly under warranty, you will receive a new printhead assembly, cleaning materials, and a full set of new cartridges.
If your printhead assembly is no longer under warranty, you can purchase a new one online.
  1. Go to How to Buy HP, and then click your country-language.
    A Buy HP page displays.
  2. Look for the HP Parts store on this page. The location of the HP Parts store varies depending on your region. Click HP Parts store.
  3. Under Find your part(s), type one of the part numbers below in the Search by part number text box.
    • If your printer uses 4 ink cartridges, type CN643A
    • If your printer uses 5 ink cartridges, type CN642A
  4. Follow the online instructions to order the printhead assembly.
This information applies to Asia Pacific only.
If HP replaces your printhead assembly under warranty, you receive a new printhead assembly, cleaning materials, and a full set of new ink cartridges. If your printhead assembly is no longer under warranty, call the HP Customer Care Center for assistance.
When you have the replacement printhead, use these detailed instructions to remove the old printhead and install the new one.
If replacing the printhead does not resolve the issue, continue to the next step.
Step 11: Service the printer
If the previous steps did not resolve the issue, contact HP to service the printer.
Keep a print sample that shows the problem. If the ink cartridges, printhead, or printer is replaced under warranty, the support agent will request the print sample. If the printer is returned to HP, the print sample must be returned with the printer. Place the sample in the output tray when you package your printer for shipping.
