HP Jetdirect 2800w NFC/Wireless Direct Accessory - How to print using HP near field communication (NFC)
After installing the HP Jetdirect 2800w NFC & Wireless Direct Accessory, use the following steps to verify that your HP printer is ready to print using HP NFC.
  1. Verify that the printer is in the Ready state.
  2. To confirm that NFC and HP wireless direct printing are enabled on your printer, print a configuration page from the control panel. If a page titled Wireless is included, NFC and HP wireless direct printing are enabled.
  3. Ensure that the latest version of HP ePrint Software (version 4.5 or newer) is installed on your mobile device. If you need to update:
    1. From the HP ePrint Software page, click Download software.
    2. Select your operating system, and then click Download from the Software - ePrint table.
    3. Save the file to your system. Then, double-click the file and follow the instructions.
  4. From a mobile device or a computer, verify that wireless capability is enabled (the Wi-Fi radio is on). This control is typically found in the Settings menu.
    Disable existing wireless connections (WLAN or Internet).
    When printing, closely align (within 1 inch (2.5 mm)) or touch the NFC icon of the mobile device and the NFC icon of the HP Jetdirect 2800w NFC & Wireless Direct Accessory. Hold the mobile device and the accessory together for at least one full second to ensure a connection.
    The HP ePrint Software displays the NFC tab or tile if the NFC antennas are correctly positioned and the compatible NFC hardware is installed and enabled in the mobile device.
Print from a Windows 8 mobile device
The following video demonstrates how to print from a Windows 8 mobile device.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Currently, the HP ElitePad 900 is the only supported Windows 8 mobile device.
ARM-based tablets using Windows RT are not supported.
  1. From the mobile device's application, select the File menu, and then select Print.
  2. From the available printers, select HP ePrint.
  3. Closely align (within one inch or 2.5 mm) or touch the NFC icons of the mobile device and the HP Jetdirect 2800w.
    Hold the mobile device and the HP Jetdirect 2800w NFC & Wireless Direct Accessory together for at least one full second.
    Once connected, you can move the mobile device away from the HP Jetdirect 2800w NFC & Wireless Direct Accessory.
    The mobile device might make a connection sound or display a pop-up symbol. Once a connection is established, the HP ePrint Software displays the printer’s service set identifier (SSID). The SSID is the HP wireless direct printer's name.
    The HP ePrint driver does not close any existing wireless network connections on the Windows 8 tablet computer (such as an access point or a printer's WDP access point).
  4. Touch the Settings button to define basic print options such as the number of copies, pages per sheet, and whether to print on both sides (duplex).
  5. Touch Print.
If the Windows 8 application does not have a Print option:
  1. With the Windows application open, swipe from the right edge of the screen to the left edge of the screen.
  2. Touch Devices, then touch HP ePrint from the list of available printers.
  3. Change basic print Settings, if required.
  4. Touch Print.
  5. Touch the Your printer requires attention message and then follow the instructions to print.
HP ePrint Software saves the printer to your recently used printers list located on the Recent tab/tile.
Select Automatically print upon successful connection so that future print jobs print automatically when the mobile device is touched to the HP printer. (If selected, the Settings option is not available.)
For more information
For additional information about HP ePrint Software including frequently asked questions, go to: www.hp.com/go/eprintsoftware. Click Documentation to download the user guide.
For additional setup, configuration, and troubleshooting information, go to www.hp.com/go/jd2800wSupport or scan the QR code with your mobile device.
