HP EliteDisplay E221c 21.5-inch Webcam LED Backlit Monitor Specifications
Product image
Product features
Feature
Model
D9E49AA
Panel type
IPS with LED backlight
Viewable image area
54,6 cm (21.5-inch) diagonally measured
Viewing angle
  • Horizontal: 178°
  • Vertical: 178°
Brightness
250 cd/m
Contrast ratio
  • Static: 1000:1
  • Dynamic: 5,000,000:1
Frequency
  • Horizontal: 24 KHz - 94 KHz
  • Vertical: 50 Hz - 76 Hz
Aspect ratio
16:9
Native resolution
1920 x 1080 @ 60 Hz
Input signal
VGA (analog), DVI-D, DisplayPort (HDCP support on DVI-D and DisplayPort)
USB
Integrated USB 2.0 hub with (2) Downstream and (1) Upstream ports
Audio
1-W channel built-in speakers (rear firing); PC audio in, headphone/speaker audio out
Integrated 720p webcam with dual microphones
Base features
  • Tilt: -5 to +30 degrees
  • Swivel: 360°
  • Height adjustable: 150 mm
  • Pivot rotation: 90°
Signal interface/ performance specifications
Specification
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic
1920 x 1080 @ 60 Hz
Modes (non-interlaced)
  • 1600 x 900 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 60 Hz
  • 640 x 480 @ 60 Hz
Maximum pixel clock speed
200 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Power specifications
Specification
Power supply
Internal
Input power
90 - 265 V @ 45 - 63 Hz
Typical power consumption
27 W
Maximum
42 W
Power saving
0.4 W
Power cable length
1.9 m (6.2 ft)
Physical specifications
Specification
Dimensions (W x D x H)
  • Unpacked with stand: 50.9 x 23.7 x 46 cm (20.05 x 9.34 x 18.12 in)
  • Unpacked without stand (head only): 50.9 x 5.1 x 30.9 cm (20.05 x 2.01 x 12.17 in)
  • Packaged: 57.5 x 18.3 x 50 cm (22.66 x 7.21 x 19.7 in)
  • Base area (footprint): 16.85 x 23.65 cm (6.63 x 9.31 in)
  • Head only: 3.3 kg (7.27 lb)
  • Unpacked: 5.4 kg (11.9 lb)
  • Packaged: 7.1 kg (15.62 lb)
Feature
Featured software
  • HP Display Assistant
  • Cyberlink You Cam
  • HP MyRoom
Environmental specifications
Specification
Operating
Temperature
5° to 35°C (41° to 95°F)
Relative
20% to 80% non-condensing
Altitude
0 to 5,000 m (16,404 ft)
Non-operating:
Temperature
-20° to 60°C (-4° to 140°F)
Relative humidity
5% to 95%, 38.7°C max wet-bulb
Altitude (unpressurized)
0 to 12,192 m (0 to 40,000 ft)
Safety certifications
Specification
Certification and compliance
  • CE
  • CB
  • KC
  • KCC
  • NOM
  • PSB
  • ICE
  • TUV-S
  • CCC
  • CEL Grade 1
  • CECP
  • SEPA
  • TCO Certified Edge
  • VCCI
  • FCC
  • Taiwan BSMI
  • ENERGY STAR
  • EPEA
  • Gold
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
