HP Scitex FB500/FB700/FB900 Industrial Printer/ColorSpan Legacy Printers/HP Designjet H35000/H45000 Commercial Printer series - About the Ink-Blocking Air Tube Assemblies
Environment
HP Scitex FB500
HP Scitex FB700
HP Scitex FB950
HP Scitex FB910
HP Designjet H-series (H35100, H35500, H45100, H45500)
ColorSpan CS5400uv series (CS5440, CS5445, CS5460, CS5465)
ColorSpan Legacy 72UVR
ColorSpan Legacy 72UVX
ColorSpan Legacy 98UVX
Carriage
Ink Delivery System (IDS) Vacuum
Questions/Symptoms
Identify and explain the ink-blocking air tube assemblies.
Cause
N/A
Answer/Solution
The HP Scitex FB500, FB700, FB950, FB910, and HP Designjet H-series, and the ColorSpan Legacy UV Printers, all use an air vacuum (negative pressure) system to maintain ink in the printheads. Ink is delivered to the on-carriage reservoirs by opaque tubing, and air vacuum is applied to the printheads by clear or semi-transparent tubing. When operating normally, ink remains only in the reservoirs for delivery to the printheads.
In some situations, usually due to an underlying problem with another printer component, the ink in the reservoir(s) migrates into the air tubes. This event is known as an "overfill". If this problem goes undetected and unchecked, eventually the ink can travel up the air tubes and into the air valve & manifold assembly and possibly even further into the air system, causing those components be contaminated with ink and rendering them unusable. An expensive repair is required to restore operation.
To prevent such collateral damage due to an overfill event from occurring, each air tube assembly includes an ink-blocking "filter", i.e., a device that is normally permeable to air but impermeable to ink. If overfill does occur and ink travels into the air tubes, the filter will stop the progress of the ink before it reaches the susceptible components of the air system. When the ink contacts the filter, the filter is no longer air-permeable, and the operation of the air vacuum system is disrupted. The observable effect is the printheads of the affected color begin to drip ink. This observable symptom is typically what alerts the operator to overfill, having occurred.
There are three versions of the ink-blocking air tube assembly, which are each specific to a particular printhead and carriage architecture. The three architectures and tube assemblies are described in Table 1.
Table 1: Air Tube Assemblies by Printer Model
Printer Model Where Used
Component Description
Related Part Number
FB500, FB700
Overfill filter and tubing assembly. Tygon tubing from the manifold to a single ink-blocking filter; Tygon tubing to an F-fitting; Tygon tubing from the F-fitting to each on-carriage reservoir.
CQ114-67016
FB950, Designjet H-Series (CS5400uv series)
Tube/filter/fitting assembly - Used between the printhead and the air manifold . Short semi-rigid tube from manifold to an elbow fitting; Tygon tubing to a single ink-blocking filter; short Tygon tube to an F-fitting; Tygon tubing from the F-fitting to each of the two printhead reservoirs. The tubing connects to the reservoirs with Luer-lock connectors.
CH104-67020
FB910, ColorSpan Legacy UV
Air filter - For use in any location where an air filter is used (inside Vacuum Pressure (VP), inline vacuum tube, ink-blocking filter). Short Tygon tubing to a single ink-blocking filter; A Luer-lock connector connects the filter to a long Tygon tube; the Tygon tube connects to the left-slave (#1 of each set of 4) printhead reservoir only. Depending on reservoir type, the tube either presses directly onto a barbed fitting on the reservoir, or connects via a Luer-lock connector.
No single part number obtains the complete assembly as described to the left. The ink-blocking filter only is orderable by CH971-91421
These three assemblies are depicted below in Figures 1, 2, and 3 & 4.
Figure 1: Ink-blocking tube assembly for FB500 and FB700
Item
1
Tygon tube from manifold to filter
2
Filter
3
Tygon tube from filter to F-fitting
4
F-fitting
5
Tygon tube to carriage reservoir (2 pieces)
6
Complete assembly
Figure 2: Ink-blocking tube assembly for FB950 and Designjet H-Series
Item
1
Semi-rigid tube and elbow fitting
2
Filter
3
F-fitting
4
Tygon tube and Luer-lock connectors to printhead reservoir(s) (2 pieces)
Figure 3: Ink-blocking tube assembly for FB910 and UVR-UVX near manifold
Item
1
Short Tygon tube
2
Filter
3
Luer connector to filter
4
Long Tygon tube to printhead reservoir
Figure 4: Ink-blocking tube assembly for FB910 and UVR-UVX near printheads
Item
1
Composite reservoir. This reservoir type may be found on FB910, UVX, and UVR.
2
Luer connector for use with composite reservoirs. This fitting is considered part of the tube assembly.
3
Long Tygon tube from filter. In this photo, a small overfill has occurred and the tube is partially filled with ink.
4
Aluminum reservoir. This reservoir type is found only on UVR.
5
Barbed metal fitting used with aluminum reservoirs. This fitting is considered part of the reservoir assembly.
6
This example is from a UVR. This use of both aluminum and composite reservoirs may be found only on the 72UVR.
Additional information for FB910 and ColorSpan Legacy UVR-UVX printers
As noted in Table 1, there is no complete replacement tube and filter assembly that can be ordered for FB910 or UVR-UVX printers, only the ink-blocking filter itself. In the event that replacement of the tubes and/or fittings is desired or required, Table 2 shows part numbers that may be used to obtain these components separately.
Table 2: Supplemental Part Numbers for FB910 and ColorSpan Legacy UVR-UVX
Item
Part Number
Tubing
CH971-91056
Long tube - For air that runs through the track assembly. Provides 563 cm (222 in) of the Tygon tubing.
Fittings
CH971-91322
Fittings kit - Used for servicing the UV printers series. Provides the Luer fittings used at the ends of the tubing along with numerous other fittings used elsewhere on the printer.
NOTE: Part numbers can change without notice, please verify the part numbers from HP PartSurfer website.Click here to view HP PartSurfer website.
