    Apache Log4j Update
HP Z230 Tower Workstation - Spare Parts
New model specific parts list
To look up RoHS-compliant information in PartSurfer, use the component’s option part number or the sales order number for a system in which the component is used (available from the product QuickSpecs). Click here to visit the HP PartSurfer website.
Spare parts
Part Description
Spare Part Number
Power supply - Rated at 400 Watts, 92% efficient rating
705045-001
Chassis side panel assembly
727133-001
Front bezel assembly
727137-001
Plastic bezel blank filler - For slim ODD bay
727138-001
SATA drive power cable assembly
727143-001
Front I/O cable assembly
727147-001
Rubber foot kit - Includes four rubber feet
739685-001
Intel Xeon Quad-Core E3-1280 v3 processor - 3.60GHz (8MB Intel Smart Cache, 82 Watt Max (TDP) Thermal Design Power)
727379-001
Intel Xeon Quad-Core E3-1270 v3 processor - 3.50GHz (8MB Intel Smart Cache, 80 Watt Max (TDP) Thermal Design Power)
727378-001
Intel Xeon Quad-Core E3-1245 v3 processor - 3.40GHz (8MB Intel Smart Cache, 84 Watt Max (TDP) Thermal Design Power)
727377-001
Intel Xeon Quad-Core E3-1240 v3 processor - 3.40GHz (8MB Intel Smart Cache, 80 Watt Max (TDP) Thermal Design Power)
727376-001
Intel Xeon Quad-Core E3-1230 v3 processor - 3.30GHz (8MB Intel Smart Cache, 80 Watt Max (TDP) Thermal Design Power)
727375-001
Intel Xeon Quad-Core E3-1225 v3 processor - 3.20GHz (8MB Intel Smart Cache, 84 Watt Max (TDP) Thermal Design Power)
727374-001
Plastic PCI option card hold down lever
727134-001
727136-001
Hard drive mounting rails - For 3.5-inch drives
727139-001
Hard drive mounting rails - For 2.5-inch drives
727140-001
Chassis side panel
727144-001
Power on/off switch and LED indicator lite assembly
727146-001
727147-001
Chassis front bezel assembly
727148-001
64GB SATA SSD cache module - 2.5-inch form factor
724936-001
4GB, 1600MHz, 240-pin, PC3-12800E 512Mx8, CL=11, DDR3-1600 Dual In-Line Memory Module (DIMM)
745886-001
2GB, 1600MHz, 240-pin, PC3-12800E, Dual In-Line Memory Module (DIMM)
745885-001
MB PCA SFF W8Pro z230
698114-601
System board (motherboard) assembly - For use in SFF models
698114-001
System board (motherboard) assembly - For use in models using Windows 8 Professional Edition
698113-601
698113-001
Digital media card reader - Has 14-in-1 support, USB2/3 support, 3.5-inch form factor
716390-001
SPS-PCI SNAPS RIGHT/LEFT Z230 TWR
756997-001
SATA DVD±RW Super-Multi dual layer (SMD) optical drive (Jack Black color) - 12.7mm form factor
657958-001
