HP Split 13 m-000 x2 Notebook PCs - Default Setup Utility (BIOS) Settings Are Incorrect
The default Setup Utility (BIOS) settings for Secure Boot and Platform Key are incorrect. Secure Boot is Disabled and the Platform Key is Not Enrolled.
Computers:
  • HP Split 13-m000 x2 PC
Serial Number Range:
  • xxx326xxxx - xxx329xxxx
To resolve this issue, complete the following procedure:
  1. Boot into the Setup Utility (BIOS).
  2. Select System Configuration from the top menu. Under Boot Options, select Load HP Factory Default Keys.
  3. Select Yes.
  4. Press f10 to save the setting. Reboot into the Setup Utility (BIOS).
  5. Select System Configuration from the top menu. Under Boot Options, Select Secure Boot. Change Disabled to Enabled. Press f10 to save the setting.
